Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Gsm & CDMA Professional Key ( GcPro key )
Gsm & CDMA Professional Key ( GcPro key ) Форум поддержки продуктов GcPro key
Старый4 23.01.2019, 15:29   #21
Points: 75,210, Level: 100 Points: 75,210, Level: 100 Points: 75,210, Level: 100
Поблагодарил(а): 1,293
Поблагодарили 8,744 раз(а) в 2,954 сообщениях
Вес репутации: 51
По умолчанию GCPROGSMTOOL V1.0.0.0062
Added Samsung Sprint new firmware support sim unlock for older models.
via combination modem
Added Samsung Sprint spc read support over adb for all new and older models without root.
Added LG Most models (new and old both) Bypass Locks & enable adb method without data lost.
Note:Modem port need if device do not make modem port can not be done.
Improved adb related functions.
Improved exynos unlock code read for SS308
Старый4 23.02.2019, 10:25   #22
Вес репутации: 51
По умолчанию GCPROGSMTOOL V1.0.0.0063
Added samsung SM-G960 SM-G965 QCOM code read support via credits.
(use newqc unlock) beta
Added samsung Read Basic Info to see cert and basic details over adb.
(useful for C type connctor phones where no uart yet.)
Improved s9/s9+ spr.
Improved comports.
Improved exynos cert write.
Improved exynos unlock.
Improved qcom code read.
Improved adb.
Improved ask/rpl.
Improved scudb.
Старый4 Вчера, 10:32   #23
Вес репутации: 51
По умолчанию GCPROGSMTOOL V1.0.0.0064
Added samsung SC-02J QCOM code read support via credits.(use newqc unlock)
Added samsung Flash_Zip function for flashing Tar,img,zip with improved speed.
Added samsung safe MODEMSTX_RESET software will confirm you want to reset full or safe.
Note:This function help on SCxx phones which do not show enter unlock code option normally.
Warning: Do not make Yes else it will full reset and you will lost network,cert,imei etc.
Added Samsung Exynos msl reset on older modems in case of imeicert_write_usb is used.
Note: This will only work exynos phone with older basebands. in sort no need to use exynos unlock for reset msl from now.
Improved SS333 without root support directly use adb unlock.
Improved upload mode.
Improved samsung flashing speed.
Improved samsung upload mode reading speed.
Improved samsung G570M and other SS305 read cert,code read etc.
cdma, gcpro, gcprogsmtool, gsm, samsung, tool
Текущее время: 02:41. Часовой пояс GMT +5.
