Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Best Smart Tool ( BST )
Best Smart Tool ( BST ) Раздел поддержки программных продуктов Best Smart Tool ( BST )
Старый4 07.06.2018, 14:46   #61
Points: 87,827, Level: 100 Points: 87,827, Level: 100 Points: 87,827, Level: 100
Поблагодарил(а): 1,382
Поблагодарили 9,198 раз(а) в 3,198 сообщениях
Вес репутации: 55
По умолчанию BST Dongle Released V3.42.00
Added Xiaomi/OPPO/VIVO "Partition Tool" Tab, supported erase/read/write partition (via EDL mode) for the qualcomm base devices!
Added Xiaomi "Factory Reset (Sideload)" function, supported latest model factory reset, reset screen lock via Sideload mode!
Added Xiaomi "Reset FRP" function, supported Reset FRP lock for xiaomi latest devices!
[Xiaomi]
Added Xiaomi "Partition Tool" Tab, supported erase/read/write parition (via EDL mode) for the follow (Qualcomm base) devices:
2014813, 2014811, 2014812, 2014817, 2014816, 2014818, 2013062, 2013063, 2014216, 2014218, 2014719, 2014215, 2014716, 2014616, 2014618, 2014619, 2015015, 2014910, 2014916, 2014912, 2014915, 2014911, 2015112, 2015116, 2015021, 2015022, 2015811, 2015817, 2016030, 2016033, 2016036, 2016090, 2016060, 2016111, 2016112, 2016116, 2016117, MAE136, MAT136, MAI132, 2016100, 2016101, 2016102, MDE1, MDT1, MEE7, MET7, 2015561, 2015911, MCE3B, MCT3B, MDE6, MDT6, MDE6S, MDT6S, MDE2, MDT2, MDG2, M1803D5XA, M1803D5XE, M1803D5XT, M1803D5XC, M1804D2SG, M1804D2SE, M1804D2ST, M1804D2SC, 2015211, 2015201, 2015628, 2015711, 2016070, 2016001, 2016002, 2016006, 2016007, 2016080, MCE16, MCT1, MEE7S, MET7S, MEI7S, MDE5, MDT5, MDE40, MDT4, MCE8, MCT8
> Added M1803D5XA(MI MIX2S) {Flash,Erase/Read/Write Partition,Factory Reset,AccountLock,Reset FRP}
> Added M1803D5XE(MI MIX2S) {Flash,Erase/Read/Write Partition,Factory Reset,AccountLock,Reset FRP}
> Added M1803D5XT(MI MIX2S) {Flash,Erase/Read/Write Partition,Factory Reset,AccountLock,Reset FRP}
> Added M1804D2SG(MI 6X/A2) {Flash,Erase/Read/Write Partition,Factory Reset,AccountLock,Reset FRP}
> Added M1804D2SE(MI 6X) {Flash,Erase/Read/Write Partition,Factory Reset,AccountLock,Reset FRP}
> Added M1804D2ST(MI 6X) {Flash,Erase/Read/Write Partition,Factory Reset,AccountLock,Reset FRP}
> Added 2015211(MI Note2) {Reset FRP}
> Added 2015201(MI 5) {Reset FRP}
> Added 2015628(MI 5) {Reset FRP}
> Added 2015711(MI 5S) {Reset FRP}
> Added 2016070(MI 5S Plus) {Reset FRP}
> Added 2016001(MI Max) {Reset FRP}
> Added 2016002(MI Max) {Reset FRP}
> Added 2016006(MI Max) {Reset FRP}
> Added 2016007(MI Max) {Reset FRP}
> Added 2016080(MI MIX) {Reset FRP}
> Added MCE16(MI 6) {Reset FRP}
> Added MCT1(MI 6) {Reset FRP}
> Added MEE7S(Redmi Note5) {Reset FRP}
> Added MET7S(Redmi Note5) {Reset FRP}
> Added MEI7S(Redmi Note5) {Reset FRP}
> Added MDE5(MI MIX2) {Reset FRP}
> Added MDT5(MI MIX2) {Reset FRP}
> Added MDE40(MI Max2) {Reset FRP}
> Added MDT4(MI Max2) {Reset FRP}
> Added MCE8(MI Note3) {Reset FRP}
> Added MCT8(MI Note3) {Reset FRP}
[OPPO]
Added OPPO "Partition Tool" Tab, supported erase/read/write parition (via EDL mode) for the follow (Qualcomm base) devices:
1100, 1105, 1107, 1206, 3000, 3001, 3005, 3006, 3007, 3008, A11, A30, A31, A31c, A31t, A31u, A33m, A33t, A33, A33f, A37f, A51, A51f, A51W, A51kc, A53, A53m, A53t, A57, A57t, F1f, F1w, N5206, N5207, N5209, R5s, R7c, R7f, R7g, R7kf, R7Plusf, R7Plusm, R7sf, R7sm, R7sPlus, R8107, R8106, R8109, R8200, R8201, R8205, R8206, R8207, R8306, R9PlusmA, R9PlustA, R9PlustmA, R9s, R9sk, R9skt, R9st, R9sPlus, R9sPlust, X9079, CPH1607, CPH1701, CPH1611, CPH1613, N5110, N5111, N5116, N5117, R2010, R2017, R6006, R6007, R7005, R8000, R8001, R8006, R8007, R830S, R831S, R831L, X9000, X9006, X9007, X9070, X9076, X9077
[VIVO]
Added VIVO "Partition Tool" Tab, supported erase/read/write parition (via EDL mode) for the follow (Qualcomm base) devices:
V1, V1Max, V3, V3A, V3L, V3Max, V3MaxA, V3MaxL, X5F, X5M, X5ML, X5Max, X5MaxF, X5MaxL, X5MaxV, X5Pro, X5ProV, X5V, X6A, X6PlusA, X6SA, X6SL, X6SPlusA, X6SPlusD, X6SPlusL, X7, X7L, X7Plus, X7PlusL, Xplay5A, Xplay5S, Y13L, Y613F, Y913, Y21L, Y23L, Y623, Y923, Y27, Y27(8G), Y627, Y627(8G), Y927, Y927(8G), Y28L, Y628, Y928, Y29L, Y31A, Y31L, Y35A, Y37A, Y37L, Y937, Y51, Y51A, Y51L, Y51E, Y51N, Y51tL, 1611, X9, X9I, X9L, X9S, X9Plus, X9PlusL, X9sPlus, Xplay6, Y53, Y53L, Y55A, Y55L, Y55S, Y66, X20, X20A, X20L, X20PlusA, Y66I, Y79A, X3F, X3L, X3V, Y18L, Y22L, X520A, X520F, X520L, X710F, X710L, X21, X21A, X21UD, X21UDA, X20PlusL, X20PlusUD, X9SL, X9sPlusL, Y66L, Y66IA, Y79L, V7Plus, V9, V9Lite, Y85, Y85A
Fixed:
> Modify Xiaomi "Read Userdata Partition" moved to "Service" tabs;
> Optimized Qualcomm MPRG protocol flash function;
Information:
* About Xiaomi "Factory Reset (Sideload)" function operation steps:
1). Switch to Recovery Mode (Vol Up + Power)
2). Select "Connect with MIAssistant" Use Power key to confirm (for MI-Recovery 3.0 and above version only)
3). Connect phone to pc via usb cable
4). Press "Scan" to confirm the phone connected
5). Press "Factory Reset (Sideload)"
6). Operation done, waiting phone reboot.
Старый4 07.06.2018, 23:46   #62
Points: 1,637, Level: 23 Points: 1,637, Level: 23 Points: 1,637, Level: 23
Аватар для clay_ios
Поблагодарил(а): 5
Поблагодарили 13 раз(а) в 9 сообщениях
clay_ios вне форума   Ответить с цитированием
Furqat92 (14.06.2018), gsmservice.uz (08.06.2018), SunnaT.STen (08.06.2018)
Старый4 31.08.2018, 22:46   #63
Аватар для clay_ios
Поблагодарил(а): 5
BST_V3.42.02 Full Installer
[Xiaomi]
> Added M1803D5XA(MI MIX2S) {Test Point}
> Added M1803D5XE(MI MIX2S) {Test Point}
> Added M1803D5XT(MI MIX2S) {Test Point}
> Added M1804D2SG(MI 6X/A2) {Test Point}
> Added M1804D2SE(MI 6X) {Test Point}
> Added M1804D2ST(MI 6X) {Test Point}
Fixed:
> Optimized Xiaomi disabled MIX2S and latest model flash function (MIX2S and latest model EDL mode authorization flash problem not solved yet)
> Optimized Xiaomi/OPPO/VIVO "Partition Tool" Tab, solving the bugs in erase/read/write partition operations of a single partition!
> Optimized Xiaomi "Factory Reset (Sideload)" function.
Information:
Последний раз редактировалось gsmservice.uz; 01.09.2018 в 10:57.
Alixan (01.09.2018)
Старый4 26.07.2019, 16:20   #64
Вес репутации: 55
По умолчанию BST Dongle Released V3.50.00
[OPPO]
> Added OPPO R11 Factory Reset (Deep Erasing)
> Added OPPO R11t Factory Reset (Deep Erasing)
> Added OPPO R11 Plus Factory Reset (Deep Erasing)
> Added OPPO R11 PlusT Factory Reset (Deep Erasing)
> Added OPPO R11 Pluskt Factory Reset (Deep Erasing)
Optimizing and Bug Fixing:
> Optimized module loading mechanism, reduce module loading speed.
> Optimized logs output, add more detail information about operation and model selection.
> Optimized some support issuse in different OS.
4 пользователя(ей) сказали cпасибо:
Abduvohid (31.07.2019), Akbar_as (03.08.2019), BOTIR (26.07.2019), Ulugbek (26.07.2019)
bst, htc, samsung, smart, tool, xiaomi
Текущее время: 11:42. Часовой пояс GMT +5.
