Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Ultimate Multi Tool ( UMT )
Ultimate Multi Tool ( UMT ) Форум поддержки программатора UMT
Старый4 02.04.2019, 10:50   #61
Points: 90,378, Level: 100 Points: 90,378, Level: 100 Points: 90,378, Level: 100
Поблагодарил(а): 1,405
Поблагодарили 9,271 раз(а) в 3,235 сообщениях
Вес репутации: 56
По умолчанию UMTv2 / UMTPro - QcFire 4.0
Added
Archos
- 50D Helium
- U50 (5044S)
Mobiistar
- XQ Dual
Wiko
- Tommy
Xiaomi
- Mi A2
- Mi Pad 4
Lock Reset for Vivo Devices
- Reset in 1 Click without Data Loss
- Phone settings may be restore to default in process
- No need to Backup / Restore / Flash phone
Fixed System/Userdata Flashing Bug
- Sometimes process directly finished on System/Userdata Flashing
- This bug was rare, but found and fixed
Disable Locks Enabled for Un-Encrypted (Non-FDE) Userdata
- Now you can disable lock on Userdata with File Based Encrytion
- Userdata is detected Normal on such devices
Improved Flash Read/Write Routine
- It should be little faster than before
Lock Related Functions Re-Arragned
- Disable/Restore Locks are in a list now
- Select desired operation and click on Execute
gsmservice.uz на форуме   Ответить с цитированием
Старый4 15.04.2019, 10:44   #62
Вес репутации: 56
По умолчанию UMTv2 / UMTPro - QcFire 4.1
- Pop 4 (5051D)
Coolpad
- A8
JAZZ
- Digit1
OKWU
- YU Fly
OBRIC
- RC555L
Panasonic
- Eluga Ray Max
- Improved Vivo Lock Reset without Data Loss
- Format Chip is back again
- Fixed System/Userdata Write Error
- Improved BL Lock/Unlock to support more generic devices
Furqat92 (15.04.2019)
Старый4 28.05.2019, 18:25   #63
Вес репутации: 56
По умолчанию UMTv2 / UMTPro - QcFire 4.2
Added
iTel
- A22 Pro
LeEco
- X820
- X829
- Tab 3 10 (YT3-X50M)
- TB2-X30F
Micromax
- E460
- Q415
- Mirror 3
Plus One Japan
- FTU18A00
TP-Link
- Neffos Y5 (TP802A)
UMI
- eMax Mini
Xiaomi
- Mi A2 Lite
ZTE
- Overture 3 (Z851M)
Added Safe Format FS Function
- Software will ask if you want to use Safe Format on Format FS
- It will use factory method to Format FS
- Specially useful for Xiaomi Devices where userdata size was shrunk after Format
Added Heuristic Mode Tab
- This method is for protected phones like Vivo Nex etc.
- You need to select XML Firmwre folder to use this function
- If will auto detect if Read/Write is allowed and will use heuristic Format method
- It will work only if erase is allowed on such device
Updated Xiaomi Factory Reset in sideload
- Now it will read info and will confirm to Factory Reset
- Useful if you want to read only Firmware Version
Updated QCN Read/Write Method
- Now SPC error on many phones solved.
Updated IMEI Repair Function
- Hopefully it should fix null IMEI after repair process
Старый4 15.06.2019, 12:33   #64
Вес репутации: 56
По умолчанию UMTv2 / UMT Pro - QcFire v4.3
Karbonn
- Aura 1
LG
- G4 (H811)
Mobicel
- Icon
Nokia
- TA-1000
- TA-1007
- TA-1024
- TA-1027
- TA-1035
- TA-1039
- TA-1044
- TA-1053
- TA-1083
- TA-1103
- TA-1116
Sony
- Xperia R1 Plus
Xiaomi
- Redmi Go
- Redmi Note 7
- MI 8 Lite
Updated Sparse Image Handling Routine
- system, userdata flashing of latest firmware should work fine now
- Overall flashing speed should improve too
Added Device Codename Reading on Read Info
- It will help to identify Xiaomi Devices properly, like ysl, whyred etc.
Fixed a rare bug in Customized Flashing
Updated Internal Loader Database
Ulugbek (15.06.2019)
Старый4 29.06.2019, 11:59   #65
Вес репутации: 56
По умолчанию UMTv2 / UMT Pro - UltimateMTK v2.1
UMTv2 / UMT Pro - UltimateMTK v2.1 - Vivo Y17, Oppo A5s FS and Vivo IMEI..
Added Support for Following Devices:
Coolpad
- Note 3 Lite (CP8298_I00)
- Note 8
Gionee
- Pioneer P5L
ICE Phone
- i999
InFocus
- Vision 3 (IF9031)
iTel
- S13 Pro
- A616
- TB3-710I
- Vibe B
- Vibe C2 (K10a40)
Multilaser
- MS50G
Nokia
- Nokia 3
Nomi
- i504
Philips
- S309
QMobile
- X700 Pro
Symphony
- Roar (V95)
Videocon
- Krypton 2
- Y17
- Y91i
Updated META Factory Reset
- Update BROM to META reboot function
- Tested Factory Reset with Oppo A5s
New IMEI Repair Method Added for Vivo
- You need to Patch Firmware to use this method
- You can use this method for other phones too
Patch Firmware for Vivo Y81, Y83 and Y83 Pro
- Select Model and Patch Firmware
- You can use META (Vivo) Method to Repair IMEI
Ulugbek (29.06.2019)
Старый4 08.07.2019, 14:23   #66
Вес репутации: 56
По умолчанию UMTv2 / UMT Pro - QcFire v4.4
- Pixi 4 (6) (9001D)
- Hot 6x (X623)
Meitu
- T9 (MP1718)
OnePlus
- OnePlus 5T
- Camon iTwin (IA5)
Vsmart
- Joy 1 Plus
Xiaomi
- Redmi 7
Added Xiaomi Auth Account Support
- Now you can work with all phones including AUTH required
- If Auto Loader does not work for latest phone, use loader from firmware
- QcFire can automatically authenticate using Xiaomi Auth App
- You need to have Xiaomi Auth Account
- PLEASE NOTE : We do NOT sell/provide such accounts
Updated Bootloader Unlock Function
- Tested to Work on Redmi 7, should work on other Xiaomi too.
Updated Internal Loaders
Ulugbek (08.07.2019)
Старый4 12.07.2019, 15:51   #67
Вес репутации: 56
По умолчанию UMTv2 / UMT Pro - QcFire v4.5 - Minor Update
ZTE
- T85
- Z5151V
- Axon 10 (A2020G) Pro - BETA (Must select Model)
- Axon 10 (A2020N3) Pro - BETA (Must select Model)
Rewritten Auth Request Routine
- Now auth request from Auth Exe should work smoothly
- Slower connections or slow server may cause auth timeout
Fixed Auth Bug for Older Phones
- Updated loader caused some old phones to ask for Auth
- Affected phones were Y2, S2, Redmi 5 Plus etc
- Note 5 Pro may ask for Auth sometimes, its normal, just retry
Fixed System Destroyed Message Bug on Redmi 7 / Note 7 Bootloader Relock
WE DEEPLY REGRET THE INCONVENIENCE CAUSED
Старый4 19.07.2019, 12:41   #68
Вес репутации: 56
По умолчанию UMTv2 / UMT Pro - UltiamteGSM v5.4
OnePlus 7 (GM1901) IMEI Repair
ZTE
- Added Models for FRP in Sideload Mode
- Z899VL
- Z986DL
- Z353VL
- Z610DL
- Z716BL
- Z717VL
- Z818L
- Z819L
- Z836BL
- Z837VL
- Z861BL
- Z862VL
- Z558VL
- Z916BL
- Z917VL
- Z936L
- Z955L
- Z962BL
- Z963VL
- Z986DL
Fixed Enable Diag without Root
- Works on some new phones like Y2/S2 etc
Fixed Samsung FRP New Method Bug
Added Motorola Network Repair
- XT1926-8
Старый4 01.08.2019, 11:19   #69
Вес репутации: 56
По умолчанию UMTv2 / UMTPro - QcFire v4.6
What's New:
Gigaset
- Me Pure (GS53-6)
Huawei
- Y7 Prime (2018)
- Vibe C
- R9 Plus
- Y66
Added Xiaomi IMEI Repair of RSA Protected Phones
- First Read QCN using Read QCN option
- Now Reset EFS in EDL/Sideload/Fastboot Mode
- Now enter IMEI and click Repair button and select QCN if asked
- Please note, this method will repair only 1 IMEI at the moment
Added Wipe EFS in Sideload Mode (Xiaomi) - Exclusive
- No need to wait for Firehose Loader or Bootloader Unlock
- Just put device in Sideload Mode and Reset EFS
- Beware, this method can not make EFS Backup
Added Wipe EFS in FastBoot Mode (Universal)
- Usefull for phones having Unlocked Bootloader
Added Enable Diag (ADB) in QcFire (Root/No Root)
- Same method as in GSM Module
- No more headache to switch module or open Command prompt
Moved Xiaomi related functions to Xiaomi Special Tab
- All Xiaomi related tasks have been move to new Tab
Auto Xiaomi Firmware Search on Factory Reset
- It may help you to search Google with information read in Sideload
- You can use this function whether you say YES or NO to Factory Reset prompt
Fixed rare bug with rawprogram.xml with no PHYSICAL PARTITION entry
Ulugbek (01.08.2019)
Старый4 17.08.2019, 10:41   #70
Вес репутации: 56
По умолчанию UMTv2 / UMTPro - UltimateMTK v2.2
[17-08-19] UMTv2 / UMTPro - UltimateMTK v2.2
Acer
- One 7 4G
Gionee
- F103 Pro (select F103)
- P7 Max
- Pioneer P5W
Intex
- Aqua Ace
iTel
- S11 Pro
Lava
- Iris Fuel 50
- Z60E
- Vibe K4 Note (A7010a48)
- Vibe X3 (K51c78)
Micromax
- A114
- Q392
- Q409
Nomi
- i5001
- i5532
QMobile
- Q Infinity Cinema
- Q Infinity D
- J7
- Spark 3 (KB7)
VGOTEL
- Venture V10
Walton
- Primo GH5 Plus
- Primo NX4 Mini
YU
- YU5014
ZTE
- V7 Lite (V0720)
Added SafeFormat Option
- It is the safest way as phone with format itself
- You must enter recovery directly after SafeFormat
Revised All Format Methods
- Format FS, Erase FS and SafeFormat listed together
- Use Format FS method to avoid Tool DL Image Fail Error
Improved Connection Routine
Improved Custom DA Selection Routine
Старый4 30.08.2019, 15:55   #71
Вес репутации: 56
По умолчанию UMTv2 / UMT Pro - QcFire v4.7
ASUS
- Zenfone Lite L1
- Zenfone Max M1 (X00PD)
- Zenfone Max M2 (ZB633KL)(X01BD)
Billion
- Capture Plus
Huawei
- Y6 (SCL-L21)
- Tab 4 10 (X104F)
- Tab 4 10 (X104L)
LG
- M700n
- M700DSK
TP-Link
- Neffos Y5s (TP804A)
Vodafone
- Tab Prime 7 (VFD 1400)
Wiko
- Tommy2 Plus
- View 2 Plus
- View XL
Xiaomi*
- Mi 9 SE
- Redmi Note 7 Pro
- Redmi Note 7A
- Redmi Note 7S
- Redmi Y3
ZTE
- Blade A711 (N939Sc)
- Blade Max 2s (Z6410S)
- Nubia NX551J
Bootloader Unlock via Patch
- Mi 8 Lite
- Mi 9 SE
- Mi Max 2
- Redmi 6 Pro
- Redmi 7
- Redmi Note 5A
- Redmi Note 3
- Redmi Note 5 Pro
- Redmi Note 7
- Redmi S2
- Redmi Y2
- Redmi Y3
Xiaomi Bootloader Unlock in Fastboot Mode
- You may need to use Fastboot Method after Patch
- First try Fastboot Method, then patch, if necessary
Updated Wipe EFS in Fastboot Mode
- Bootloader must be Unlocked to use this method
- Software will auto try new method if old method fails
Improved Wipe EFS in Sideload Mode
Some Cosmetic Changes
asus, download, edl, firmware, motorolla, nck, qualcomm, umt, zte, бесплатно, бокс, дастурлаш, донгл, код, программа, прошивка, скачать, текин, узбекистан
Текущее время: 17:56. Часовой пояс GMT +5.
