Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Ultimate Multi Tool ( UMT )
Ultimate Multi Tool ( UMT ) Форум поддержки программатора UMT
Старый4 04.01.2020, 10:34   #81
Points: 135,656, Level: 100 Points: 135,656, Level: 100 Points: 135,656, Level: 100
Поблагодарил(а): 1,462
Поблагодарили 9,652 раз(а) в 3,464 сообщениях
По умолчанию UMTv2 / UMT Pro - QcFire v5.2
UMTv2 / UMT Pro - QcFire v5.2 - First Twenty20 Update
- Phab Plus (PB1-770M)
- X20A
Added No Auth Loaders for Xiaomi - Test
- These loader are for test only.
- You must select Xiami No Auth as Brand and then required Model from list
- These loaders are Anti Level dependent.
- Please let us know with logs if it works for you.
No Auth Loaders Added for
- CC9 Pro
- Mi 9T Pro
- Mi CC9
- Mi Note10 Mi
- Mi9 Lite
- Poco F1
- Redmi 6 Pro
- Redmi 7
- Redmi K20 Pro
- Redmi Note 7
- Redmi Note 7 Pro
- Redmi Note8
Updated Internal Loaders
Some Minor Tweaks
4 пользователя(ей) сказали cпасибо:
Asilbek93 (04.01.2020), baxa (06.01.2020), ilhom-uz (04.01.2020), Nurziyod (04.01.2020)
Старый4 08.01.2020, 13:02   #82
По умолчанию Avengers Box / UMT Pro Android MTK v0.6.6
Avengers Box / UMT Pro Android MTK v0.6.6 Update Released - [07/01/2020]
Hisence
F16 - Read Info/FRP/Repair IMEI/Factory reset (flash & meta mode)/Backup& Restore nvram (flash & meta mode)/Write Firmware.
Lava
Iris 88 - Read Info/FRP/Repair IMEI/Factory reset (flash & meta mode)/Backup& Restore nvram (flash & meta mode)/Write Firmware.
X5516B - Read Info/FRP/Repair IMEI/Factory reset (flash & meta mode)/Backup& Restore nvram (flash & meta mode)/Write Firmware.
X5516C - Read Info/FRP/Repair IMEI/Factory reset (flash & meta mode)/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-9029G - Read Info/FRP/Factory reset (flash & meta mode)/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-9029W - Read Info/FRP/Factory reset (flash & meta mode)/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-5008R - Read Info/FRP/Factory reset (flash & meta mode)/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-8068 - Read Info/FRP/Factory reset (flash & meta mode)/SimLock/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-A501DL - Read Info/FRP/Factory reset (flash & meta mode)/SimLock/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-5008Y - Read Info/FRP/Factory reset (flash & meta mode)/SimLock/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-5008D - Read Info/FRP/Factory reset (flash & meta mode)/SimLock/Backup& Restore nvram (flash & meta mode)/Write Firmware.
OT-5008U - Read Info/FRP/Factory reset (flash & meta mode)/SimLock/Backup& Restore nvram (flash & meta mode)/Write Firmware.
Fixed saving firmware for some new helio models.
Scater saving improved.
Added support(beta) for new helio phones imei repair in meta mode without database.
Must work for MT6739, MT6761, MT6763, MT6765, MT6771 cpu(not work phones with OTP imei or locked nvram)
Complete Rewrited format function, now user can erase by specific adress or can select multiple partitions to be erased(need to load scatter in exe for this function)
Added aditional /vendor location for database search patch, sometimes database is not stored in /system folder
Added fastboot read info function, for phones what support fastboot.
Other fastboot functions in progress
Старый4 28.01.2020, 12:04   #83
По умолчанию UMTv2 / UMTPro - UltimateMTK v2.6
UMTv2 / UMTPro - UltimateMTK v2.6 Released - More Devices Added
Added Support for following functions:
- Read Info
- Reset FRP (For devices supporting this feature)
- Reset Locks (All Android Versions, Encrypted Userdata NOT Supported)
- Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported)
- Format FS
- Format FS (Advance)
- IMEI Repair in META / Boot Mode
- Backup NVRAM
- Restore NVRAM
- Reboot to META / FACTORY / FASTBOOT Mode
- Added Support for Helio CPU (MT6750, MT6755, MT6763, MT6739 etc)
- Disable Lock / Restore Lock for Encrypted Userdata
- Remove Lcoks for Encrypted Userdata for Vivo
- Factory Reset in META Mode (Vivo, Oppo and others)
- SafeFormat Option to let device format itself safely in recovery
Gionee
- X1s
Huawei
- Y360-U61
- Y5 (MYA-L22)
- Hot 4 (X557)
- Smart 2 (X5515i)
Panasonic
- P75
- T44
QMobile
- Infinity E Lite
- J7 Pro
- X700 Pro Lite
- i6 Metal One 2017
- Camon iAir2+ (ID3K)
- Spark Go (KC1)
Some Minor Improvements
Старый4 02.02.2020, 20:35   #84
Points: 11,659, Level: 71 Points: 11,659, Level: 71 Points: 11,659, Level: 71
Аватар для Mardanov.T
Поблагодарил(а): 43
Поблагодарили 381 раз(а) в 188 сообщениях
Вес репутации: 16
По умолчанию [02-02-20] UMTv2 / UMT Pro - QcFire v5.3 - LYF New Security and More...
We are pleased to announce
UMTv2 / UMT Pro
Innovative and Intelligent
QcFire v5.3
The Ultimate Qualcomm Too
Supported Functions
- Read / Write Firmware
- Backup / Restore QCN
- IMEI Repair in FTM/Diag + Flash Mode
- Backup / Reset / Restore Security (EFS)
- Reset FRP (Google Factory Reset Protection)
- Format UserData
- Read Pattern Lock (Android < 6.0, Un-Encrypted Devices Only)
- Reset Locks (PIN, Password, Pattern w/o Data Loss, Un-Encrypted Devices Only)
- Enable Diag (Need OEM Unlock, May not work on BL Locked Devices)
- Reboot to EDL from Fastboot
- Reset Mi Account for Xiaomi Devices
- Disable Mi Account for Xiaomi Devices
- Factory Reset (sideload Mode) for Xiaomi Devices
- Disable / Restore Locks for Encrypted Userdata
- Motorola Boot Repair
- Xiaomi EDL Locked Device Service
- Bootloader Unlock in EDL Mode for some Xiaomi Devices
- One Click Root in EDL Mode for Generic Qualcomm Devices
- Forensic Functions (Read Contacts / Messages in EDL Mode)
- One Click Lock Reset for Vivo Phones (Encrypted Userdata)
- Factory Method for Format FS
- EDL Authentication using Xiaomi Auth App (Service Account Required)
- Xiaomi Wipe EFS in Sideload Mode
- Xiaomi IMEI Repair for RSA Protected Phones
- Xiaomi Boot Loader Unlock
- Unique Method for Vivo Reset Locks for Protected Devices
- Xiaomi EDL Auth Using UMT Server
- Xiaomi Flashing in Fastboot Mode
Note : Some features are device/brand specific, may not work on all devices.
Added
Huawei
- 8C (BKK-LX2)
- G8 (RIO-L01)
LYF
- Updated New Security Loaders for following devices:
- F10Q
- F30C
- F50Y
- F90M
- F120B
- F210Q
- F220B
- F250Y
- F300B
- LF2403N
- LF2403S
NEC
- Lavie Tab E (PC-TE508HAW)
- Y11
- Select model and use Vivo FS / FRP if normal method does not work.
Fixed Auth Server Message for Find Device ON phones
Updated Internal Database
Special Thanks to:
- Anil Kumrawat
- Anna
- Bimal Shah
- Ramraj Sahu
- Sanjeev Kaushik
- Sonu Kumawat
- Unlockinfo
- a2zworld
- profkefah
- wohlstand
It Has Begun...
Keep Following Us...
Some Nice Updates Are On The Way...
SPECIAL THANKS TO OUR VALUABLE USERS FOR THEIR LOVE AND SUPPORT FOR MORE THAN [SIZE=20px]4 [/SIZE]YEARS
WARNING :
ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI.
ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS.
WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE.
STATUTORY WARNING - READ CAREFULLY
Using International Edition of our software is prohibited by Indian Law.
We strictly advice you to use Indian Edition if you are in India.
If you use International Edition in India, it may cause legal action against you by local law enforcement agencies.
We will not be liable for any loss or damaged caused.
:: NO FAKE ADVERTISEMENT ::
:: NO FAKE UPDATES ::
:: NO FAKE WORLD'S FIRST ::
:: NO FAKE BLA BLA BLA ::
How to Download:
- Download UMT [Only Registered and Activated Users Can See Links. Click Here To Register...]
- Connect UMT Box/Dongle to PC and Run UMT Support Access.
- Download required Executable from Installer folder.
- Enjoy!
- [Only Registered and Activated Users Can See Links. Click Here To Register...]
BEST REGARDS
Mardanov.T вне форума   Ответить с цитированием
black-energy (03.02.2020)
Старый4 24.02.2020, 11:14   #85
По умолчанию UMTv2 / UMT Pro UltimateMTK v2.7
Read Info
Format FS
Format FS (Advance)
Backup NVRAM
Restore NVRAM
Huawei
- Y5 (MYA-L22)
Hot S4 (X626B)
Hot 8 Lite (X650)
Note 4 (X572)
Smart 4 (X653c)
iTel
- IT1460 Pro
Karbonn
- Titanium S5 Plus
Lava
- Iris 820
- Vibe K5 Note (A7020a48)
Micromax
- Bharat 5
QMobile
Fancy 5
Noir E1
S8
Camon I2 (ID5A)
WX3
Telenor
- Infinity K (L105)
ZTE
- Blade L2
Important
Features introduced may work on other devices too, which are not litsed here.
User needs to untick By Model checkbox to be able to select Platform manually.
For manual work, just select Platform and DA.
For new secured devices, you may need to seleft AUTH and/or Preloader.
Rest operations will work same.
Note : Some features are device/OS specific and may not work on all devices.
Furqat92 (25.02.2020)
Старый4 17.03.2020, 17:50   #86
По умолчанию UMTv2 / UMT Pro - QcFire v5.4
Added
C5
- Mobile Noa 4.5G
Huawei
- Enjoy 8e (ATU-AL10)
- Honor T3 (AGS-W09)
- MediaPad T3 10 (AGS-L03)
- MediaPad T3 10 (AGS-L09)
- Y6 2018 (ATU-AL20B)
- Y6 2018 (ATU-L11)
- Y6 Prime 2018 (ATU-L31)
- Y6 Prime 2018 (ATU-L42)
- Moto Tab (TB-X704A)
- Tab 4 10 Plus (TB-X704V)
- Tab M10 (TB-X505X)
- Tab P10 (TB-X705F)
- Tab P10 (TB-X705L)
- VIBE X3 ROW (X3a40)
- Yoga Smart Tab (YT-X705L)
- Yoga Smart Tab (YT-X705X)
Nokia
- 2.1 (TA-1086)
Xiaomi
- Mi A3
- Redmi Note 7 Pro
- Updated No Auth Loader for Redmi Note 7 (lavender)
Updated Firehose Protocol
Update Internal Loader Database
Старый4 26.03.2020, 16:07   #87
По умолчанию UMTv2 / UMTPro - QcFire v5.5
Added
Hisense
- F30
- F31M
- F32
Huawei
- Ascend G7-L03
- Ascend G7-L11
- Ascend G7-UL20
- Enjoy 6s (DIG-AL00)
- Enjoy 6s (DIG-L01)
- Enjoy 6s (DIG-L03)
- Enjoy 6s (DIG-L21)
- Enjoy 6s (DIG-L21HN)
- Enjoy 6s (DIG-L23)
- Enjoy 6s (DIG-TL10)
- Honor 5A (CAM-AL00)
- Honor 5A (CAM-AL10)
- Honor 6A Pro (DLI-AL10)
- Honor 6A Pro (DLI-L22)
- Honor 6A Pro (DLI-L42)
- Honor 6A Pro (DLI-TL10)
- Honor 6A Pro (DLI-TL20)
- Honor 6C
- Honor Holly 4
- Nova (CAN-AL10)
- Nova Plus (MLA-AL10)
- Nova Plus (MLA-L01)
- Nova Plus (MLA-L02)
- Nova Plus (MLA-L03)
- Nova Plus (MLA-L11)
- Nova Plus (MLA-L12)
- Nova Plus (MLA-L13)
- Nova Smart
- Zero 6 (X620B)
- Zero 6 Pro (X620)
- Beta Test! Need to select Model manually
Xiaomi
- Redmi Note7 (lavender) 64GB
- Need to select Xiaomi_No_Auth > RedmiNote7_64GB
ZTE
- Blade A330
Fixed Read Error if QcFire HighSpeed Driver was not installed
Старый4 09.04.2020, 20:28   #88
По умолчанию UMTv2 / UMT Pro UltimateEMMC v0.2
Firmware Tool
- Both MTK Scatter and Qualcomm RawProgram Supported
- Automatic Identification of Scatter / RawProgram XML
- GPT Flashing Supported for Qualcomm Devices
- Automatic Patch Application like in EDL mode
- You can flash full firmware now, even on erased userarea
Sign to Unsigned
- A simple tool to extract *-sign.* files
- Useful for flashing singed files using Firmware Tool functions
Partition Tool
- Added Support to write sparse image
- Added Check to avoid writing unsupported RAW dump
Common
- Read build.prop in Build_Props folder on Connect
- It will help to identify some device properly
- build.prop can not be read if device has damaged or erased system partition
Fixed some minor UI bugs
Ulugbek (09.04.2020)
Старый4 18.04.2020, 13:34   #89
По умолчанию UMTv2 / UMT Pro UltimateMTK v2.8
Supported functions:
- Read Info
- Format FS
- Backup NVRAM
- Restore NVRAM
- 5058I
Comio
- X1
Condor
- Infinity i5
E-Tachi
- A5 Slim
Gionee
- Pioneer P3s
HTC
- Desire 728 Dual SIM
InnJoo
- Halo 3
- Halo 4 LTE
Intex
- Aqua Trend Lite
iTel
- A44
- S13
Micromax
- Q462
- Q4204
Mobiistar
- C2
Mtech
- Eros Star
QMobile
- LT900
- M350
- Noir i10i Pro
- S1 PRO
- S5
- i6i
Symphony
- V75
Tambo
- TA-40
- Camon i4
- Camon iAce 2X (KBJ2)
- Y15
Important
- Features introduced may work on other devices too, which are not litsed here.
- User needs to untick By Model checkbox to be able to select Platform manually.
- For manual work, just select Platform and DA.
- For new secured devices, you may need to seleft AUTH and/or Preloader.
- Rest operations will work same.
Ulugbek (19.04.2020)
Старый4 13.05.2020, 15:03   #90
По умолчанию UMTv2 / UMTPro - QcFire v5.6
UMTv2 / UMTPro - QcFire v5.6 Release - More Huawei, Lenovo and ZTE...
Added
Huawei
- Ascend Y530 (Y530-U051)
- Honor 7A (AUM-AL00)
- Honor 7A (AUM-AL00IN)
- Honor 7A (AUM-AL20)
- Honor 7A (AUM-L29)
- Honor 7A (AUM-L33)
- Honor 7A (AUM-TL20)
- Honor 7C (AUM-L41)
- Honor 7C (LND-AL30)
- Honor 7C (LND-AL40)
- Honor 7C (LND-L29)
- Nova (CAN-AL00)
- Nova (CAN-L01)
- Nova (CAN-L02)
- Nova (CAN-L03)
- Y7 2017 (TRT-LX1)
- Y7 2017 (TRT-LX3)
- K10 Plus (L39051)
- Z5 Pro GT (L78032)
ZTE
- Blade T2 (Z559DL)
- Blade V9 [P450L10]
- Zpad 8 (K83V)
Updated Support For HiSpeed Driver on Windows 10
Improved Firehose Protocol to Fix Slow Read with some devices
Alixan (15.05.2020), Ulugbek (13.05.2020)
Старый4 22.05.2020, 13:24   #91
По умолчанию UMTv2 / UMTPro - UltimateMTK v2.9
UMTv2 / UMTPro - UltimateMTK v2.9 Released - Oppo Reset Locks and more...
ATouch
- X8
Archos
- 97c Platinum
Four
- Sky 2 Dual SIM (S185)
Gionee
- A1
- A1 Lite
- Smart X5010
Jivi
- Xtreme 3X
- A606
- A880
Mobiistar
- X1 Notch
Onn
- Tab 10.1
QMobile
- Noir A3
- Noir I6i
- Noir W80
- Phantom P2 Max
- QTab Q400
QSmart
- Mark 2
- B1F 16+1
- Spark Go Plus (BB4K)
Wiko
- Rainbow
Added Oppo Reset Locks
- This method will erase all except Gallery/Photos
Added DL Image Failed Error Fix
- It can fix DL Image Failed Error which comes after Format/FRP
Fixed Vivo Reset Locks
- It was broken in last update
Старый4 16.06.2020, 12:28   #92
По умолчанию UMTv2 / UMTPro - UltimateMTK v3.0
[16-06-20] UMTv2 / UMTPro - UltimateMTK v3.0
- 5022D
Eurostar
- ePad Genie Gold (ET7583G-H16)
Haier
- Esteem i90
- Hot 7 (X624)
- Smart 3 Plus (X627)
Oale
- X1
QMobile
- Blue 5 Plus
- HD1+
- LT700 Pro
- Noir E2
- X700 Pro II
SeaShark
- V15
- A37m
Telenor
- Infinity A2
- Spark 4 Air (KC1J)
- Spark 4 Lite (KC2)
Touchmate
- TM-SM540
Walmart
- ONN 10.1 (ONA19TB007)
Yuho
- O2 Pro
Dany
- Genius Tab (T470)
Some minor improvements
Ulugbek (16.06.2020)
Старый4 26.06.2020, 11:39   #93
По умолчанию UMTv2 / UMT Pro UltimateEMMC v0.3
Supported Brands
ASUS
Acer
Advan
Coolpad
HTC
Huawei
Intex
LG
LYF
Motorola
Nokia
Realme
Samsung
Sharp
Sky
Smartfren
Sony
Xiaomi
ZTE
Qualcomm EMMC Device
other devices are also supported...
Supported Functions
Read Any Partition
Write Any Partition
Erase Any Partition
Format Userdata
Format Userdata in Safe Mode
Reset Userlock on Vivo Phones without DataLoss
Read Full Dump
Write Full Dump
Supports both 512 byte / 4 KB Sectors
Supports Qualcomm Phones appearing as Qualcomm EMMC Device
Supports SD Card Image Read
Supports SD Card Image Write
Flash Full Firmware for Qualcomm Devices
Flash Full Firmware for MediaTek Devices
Disable Screen Locks without Data Loss for Encrypted userdata
Added/Updated ISP Pinouts
Realme 3 Pro RMX1851
Samsung SM-A105G
Samsung SM-A205F
Samsung SM-A207F
Samsung SM-A260F
Samsung SM-A305F
Samsung SM-A307F
Samsung SM-A750F
Xiaomi Phones with Encrypted Userdata Supported
Generic Phones with Encrypted Userdata Supported
We recommend to make system partition before using this operation
To revert backup to initial condition, you need to write system backup
Added Support for NON-UEFI Disk Images Writing
- Now you can write OS images to SDCARD or Flash Drives
Fixed "Not a valid integer value" on Scatter loading
Improved Write Method
Updated Erase Method
Updated EMMC Activation Handling to avoid wrong Firmware Update Required message
Some cosmetic changes
Старый4 10.07.2020, 10:20   #94
По умолчанию UMTv2 / UMTPro - QcFire v5.7
UMTv2 / UMTPro - QcFire v5.7 - Nokia NB0 Direct Flash, Xiaomi Disable ...
Added
Haier
- Andromax A16C3H
- Esteem L50
Huawei
- Nexus 6P
- Y7 2019 (DUB-LX3)
- Y7 Pro 2019 (DUB-LX2)
- Tab4 8 (TB-8504X)
LG
- Q6 (LG-M700)
Nokia
- 4.2
Vestel
- Venus Go
Xiaomi Disable Screen Locks
- MIUI8/9/10/11 Supported
- Use Xiaomi Special > Disable Screen Locks
- Device software must be untouched for this to work properly
Direct Nokia NB0 Firmware Flashing Added
- Both eMMC and UFS Storage Type Supported
- Option to choose partitions manually
- Only Factory NB0 is supported at the moment
- If your firmware is not supported, please contact support
Use Package Loader
- If ticked, it will use loader from NB0 package
Safe Format on Finish
- If ticked, software will Safe Format Userdata after successful flash
- Useful to avoid bootloop after flashing different firmware
Старый4 22.07.2020, 13:53   #95
По умолчанию UMTv2/UMTPro - UltimateMTK v3.1
UMTv2/UMTPro - UltimateMTK v3.1 Release - More Devices Added...
Airtel
- Airpad 7s
C-Idea
- Tab CM488
E-Tachi
- A10 Smart
GOME
- C7 Note
HOTWAV
- Pearl K2 Prime
Huawei
- Enjoy 5s (TAG-AL00)
- Honor Holly (Hol-U19)
Karbonn
- K9 Smart Selfie
Lava
- Iris 65
Meizu
- M3 Note
Micromax
- Q350
Panasonic
- Eluga A2
QMobile
- Fire
- X20
Spice
- V801
Tambo
- TA-3
- Camon 12 Air (KC3)
- Camon 15 (CD7)
ZTE
- Blade G (V816W)
Enabled Flashing using Brand and Model
- You can use either Brand/Model, or by CPU
- It should work almost same as in Tools/FRP tab
Added Support for MTK Helio X20 (MT6797) - Beta
Ulugbek (22.07.2020)
Старый4 07.08.2020, 10:53   #96
По умолчанию UMTv2 / UMTPro - QcFire v5.8
UMTv2 / UMTPro - QcFire v5.8 - Vivo V15 Pro, V17, V17 Pro and more...
Added
General Mobile
- GM 8
Haier
- Leisure L7 (HM-N700-FL)
Huawei
- Honor 8C (BKK-AL10)
Nokia
- 2.1 (TA-1092)
- 2.1 Plus (TA-1136)
Panasonic
- P95
- S1 Pro (Untested, may not work)
- U20
- V15 Pro
- V17
- V17 Pro
- X27 (PD1829)
- X27 (PD1838)
- X27 Pro
** Need to select Brand/Model
YU
- Yutopia (YU5050)
Supported Functions for Vivo Secured Phones:
- Read / Write Partitions
- Safe Format
- Reset FRP
- Reset Locks (Vivo)**
- Some phones may not let you open any app after reset locks without dataloss
- In such case, you need to wipe from recovery, all data will be lost!
asus, download, edl, firmware, motorolla, nck, qualcomm, umt, zte, бесплатно, бокс, дастурлаш, донгл, код, программа, прошивка, скачать, текин, узбекистан
Текущее время: 22:13. Часовой пояс GMT +5.
