Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Gsm & CDMA Professional Key ( GcPro key )
Gsm & CDMA Professional Key ( GcPro key ) Форум поддержки продуктов GcPro key
Старый4 19.10.2014, 17:17   #1
Points: 309,685, Level: 100 Points: 309,685, Level: 100 Points: 309,685, Level: 100
Activity: 16.7% Activity: 16.7% Activity: 16.7%
Аватар для Nurziyod
Поблагодарил(а): 6,713
Поблагодарили 8,965 раз(а) в 3,475 сообщениях
Вес репутации: 42
Профессионализм Герой Форума Архивариус За Активность За 100 сообщений
Lightbulb Обновление: GcPro Key
GcProKeyV1.0.0.0011, All MTK Network Unlock, Samsung Pattern Reset, HTC & Much More..
GCProKey Update 0011 Released. Happy to Release
GcProKey GSMTool Version 1.0.0.0008 Released at 17-10-2014
What's new?
  1. Added MOST phones,tablet WITH MTK CPU base SAFE READ UNLOCK CODE..ADB+ROOT need.HUAWEI,ZTE,Many others.
  2. Added Samsung ICS(4.0.x) TO KITKAT(4.4.0) no root pattern reset with just ADB. World first.
  3. Added Basic HTC Android device support. FASTBOOT MODE ONLY.
  4. Added HTC SIM-LOCK STATUS CHECK LOCK OR UNLOCK read on readinfo in FASTBOOT MODE.(WITHOUT S-OFF) World first.
  5. Added HTC IMEI1,IMEI2 READ WRITE SUPPORT FASTBOOT MODE(S-OFF need). World first.
  6. Added HTC SUPER CID 1 CLICK SUPPORT FASTBOOT MODE(S-OFF need).
  7. Added HTC CHANGE CID 1 CLICK SUPPORT FASTBOOT MODE(S-OFF need).
  8. Added G900H,G900F,N750 super imei files.
  9. Added "Read info ADB" in samsung tab easy for all users.
  10. Improved NVRAM IMEI will check for current imei in NVRAM and show to user.
  11. Improved Fastboot Device format will report if phone not allow it.
  12. Improved GUI MTK have his own tab now.user can do all from it.
  13. Improved Android tab "Full Details" option will be by default ticked to avoid user read non usefull details..
  14. Improved working with adb on read file.
  15. Improved reset efs will warn user if backup is fail some reason.
ALL new htc s-off,sim unlock may come soon.
Download
All Updates & History :
Successful Stories
Follow Us on Twitter for always Update to Date:
Follow us on Facebook
"sh"ни "w" қилиб ёзманг илтимос!!!
Последний раз редактировалось Nurziyod; 19.10.2014 в 17:20.
Nurziyod вне форума   Ответить с цитированием
Akbar_as (19.10.2014), Furqat92 (19.10.2014), Zver_i (18.11.2014)
Старый4 18.11.2014, 08:24   #2
Аватар для Nurziyod
Вес репутации: 42
Exclamation GcproKey0012 World's 1st All Sprint All Vers, All Models, Gsm & Cdma Unlock-Relock
GCProKey Update 0012 Released. Happy to Release
GcProKey GSMTool Version 1.0.0.0009 Released at 17-11-2014
What's new?
Added Samsung Sprint all version all models GSM & CDMA super safe and fast SIM UNLOCK / RELOCK .World First & Only in world(ADB UNLOCK)
{L520,L600,L720,L720T,N900P,G860P,G900P}MANY OTHERS..NO NEED ROOT AT ALL..(without rooting,without any java or installtion 4.2 to 4.4.4 tested )
Improved adb work when ever any one else using adb ports it will show error.
Improved mtk sim unlock code display & unlocking support should work fine now on 8 digit,10digit,16digit.
Improved samsung no root gtalk,pattern,password remove method now work more better.
Improved resized GUI for more easy for users..
Note: we are the only tool who work perfect with all model with imeicerts.. not like others who need model to be in there exe to be supported.
some of users who tested I9195 imeicert with us.while others till not manage G900F,G900I,G900M too.we can do N910T with certs files.
Note2: imeicerts is not come free at moment.and we do not provide it.
Код:
Phone Found Wait...
TEST MODE OK..
Model := GT-I9515
UNIQID := C16B04B91A3E411
Phone IMEI := 35xxxxx
Damaged MSL found can continue..
MSL Autho Pass..
Update IMEI Ok..
Version of Script is..GCPRO_I9515_SKEY_0239_V1
Script imei..3521xxxxxxx
Update Simlock Ok..
Wifi_mac := E412xxxx
Wifi_mac update ok.
Update SerialNumber ok..
Fixing FTM ok..
Repairing finish...
All Finish..
!!! Success !!!!
Total Time Take...00:00:59
Download
Successful Stories
Furqat92 (26.12.2014), Zver_i (18.11.2014)
Старый4 23.11.2014, 15:25   #3
Аватар для Nurziyod
Вес репутации: 42
Smile GcProKey0013 Added Zte S188 Reliance Sim Unlock & Improved S183 & M131 & Flashing.
GCProKey Update 0013 Released. Happy to Release
GcProKey ZTE Version 1.0.0.0003 Released
What's new?
Added ZTE S188 RELIANCE SIM UNLOCK SUPPORT.
(if people don't know its our solution made at 3 year before for S160 RIL)
Improved older S183 and M131 unlock support.
Improved flashing style.
Download
Successful Stories
Старый4 07.12.2014, 09:07   #4
Аватар для Nurziyod
Вес репутации: 42
Smile GcProKey0015 World's 1st Usb Debug Enable for All Samsung.Plan format IMEICERT & More
Gsm & Cdma Professional Key Team
Happy To Announce
GCProKey Update 0015
World's 1st & Unique Solution & Only Introduced by GcProKey
Added Samsung ENABLE USB Debug option for MOST Samsung Phones.
How to Enable Usb Debug Option While Phone is Locked ?
Power On Phone
Connect Phone with Pc by Normal Usb Cable
Install Samsung Drivers if Needed
Open GcProKey GSMTool Version 1.0.0.0011
Click on Scan Ports
Select Modem Port ( of your connected Samsung Phone )
Click on "Enable ADB"
!!! Success !!!!.. As you see Success Written. It's SuccessFully Now Enabled Usb Debug
What is Enable ADB is for ?
If you want to Remove Pattern Lock without getting Lost Data. just Connect phone and Enable Usb Debug and bypass Pattern Lock
If you want to Remove User Code without getting Lost Data. just Connect phone and Enable Usb Debug and bypass User Code
If you want to Remove Screen Lock without getting Lost Data. just Connect phone and Enable Usb Debug and bypass Screen Lock
Many other things can be done... Many Locks can be Bypass by this way. OR if you want to do some thing with phone with ADB commands on LOCKED phones.... This is What Solution we MADE for you.
Added Samsung plan format imeicert handling
Gcpro is only tool can write all samsung certificate
Added handle samsung msl code if present in certificate file.
no need reset efs for imei,unlock etc
no need write qcn if not erased efs.
Added factory unlock possible if msl code present in certificate file.
Improved adb related task.
Improved samsung imei write method.
Note:
ENABLE ADB option is used by most samsung. i can not test all phones made by samsung. But it should work on MOST of them.incase if your phone not worked with it, then you can write CUSTOM recovery and use remove pattern adb. There is no other option to enable adb if this solution fail.
Note2:
Imeicert in plan text format like all other tools use.you can use any other tool imei certs now for write with GCPROKEY. All model should work 100%. Tested on N910C,N910T,G800H most other qualcomm etc use repair imei button when ask for certificate, select file if you want to do imeicert write.. if you are using imeicert file you do not need to write anything on imei,imei2 all automatic.
Sample 1
Using Version...1.0.0.0011
Selected Port VCP0 = COM11
Selected Model Samsung GSM
Selected Task SAM IMEI1
SAMSUNG IMEI REPAIR & CERT WRITE STARTED...
Searching Phone Please wait...
Phone Found Wait...
TEST MODE OK..
Model := GT-I8552
UNIQID := CKxxxx
Phone IMEI := 35xxx
MSL CODE FOUND USING IT..
MSL Autho Pass..
Update IMEI Ok..
Update IMEI2 Ok..
SKEY := 0246
QCOM(QUALCOMM) detected..
Checking imeicert...
IMEISIGN PASS..
Checking imeicert2...
IMEISIGN2 PASS..
Update Simlock Ok..
Wifi_mac := 34xxx
Wifi_mac update ok.
Fixing FTM ok..
Repairing finish.
All Finish..
!!! SUCCESS !!!!
Total Time Take...00:00:56
Log Saved
Sample 2 Enabling Usb Debug
Selected Port ssudmdm0000 = COM39
Selected Task SAMSUNG ENABLE ADB
SAMSUNG ENABLE ADB STARTED...
Searching Phone...
Phone Found Please Wait...
Sending Loader...
BASE(SM-N900)
VER(I9300XWUGML4/I9300ODDGML4/I9300DDUGNB1/I9300XWUGML4)
HIDVER(I9300XWUGML4/I9300ODDGML4/I9300DDUGNB1/I9300XWUGML4)
MNC(24)
MCC(404)
PRD(GT-I9300RWDINS)
SN(RZ1C9192V9R)
IMEI(353743050349073)
UN(CVTF1DA877BCF6F)
PN()
CON(AT,MTP)
LOCK(NONE)
LIMIT(FALSE)
SDP(RUNTIME)
HVID(Data:196609,Cache:262145,System:327681)
USER(OWNER)##
Loader Ready..
ADB IS NOW ENABLE ENJOY...
!!! Success !!!!
All job finish..
Restart Phone Manually before doing anything...
Sample 3
Selected Port VCP0 = COM4
Phone Found Wait...
TEST MODE OK..
Model := SM-G850Y
UNIQID := CRxxxxx
Phone IMEI := 35xxxxxx
MSL Autho Pass..
Update IMEI Ok..
SKEY := 0932
EXYNOS Type Detected..
Cert write ok..
IMEICERT PASS..
Update Simlock Ok..
Wifi_mac := F4xxxxx
Wifi_mac update ok.
Fixing FTM ok..
Repairing finish.
All Finish..
!!! SUCCESS !!!!
Total Time Take...00:01:50
Successful Stories
Старый4 26.12.2014, 08:28   #5
Аватар для Nurziyod
Вес репутации: 42
Smile GcProKey0017 Merry ChristMass - Samsung Explode Update - Too Much For Samsung
!! Happy New Year !!
Added Samsung NOTE4 backup security data with reset efs option
Still no reset efs yet via adb yet
root need
Added Samsung G357M bcm base efs reset and backup tar of security units
cert dump possible from backup
Added Samsung more better readinfo with rootkey check and reactivation check.
Added Samsung msl imei repair
same as msl unlock use msl by enter or from localmsldb if enter before
Added Samsung localmsldb method so user not need to keep enter same msl each time for same phone
Added Samsung QCN read
pc must have qpst installed
Added Samsung QCN write
Added Samsung QCN write will handle automatic remove imei from qcn file and write no buggy like others.
Improved Enable adb
some qualcomm before was not worked
should work now
Still Exclusive & only in World
Improved
reset EFS.
HTC task.
factoryrestoretar.
certwrite
imeirepair
dualimei
and Much More
Samsung NEW easy handle GUI with task list.
Previous World's 1st Update
GcProKey Support Area !! All Updates, Files can be Download From here !!
Successful Stories
Последний раз редактировалось aldilshod; 26.12.2014 в 09:39. Причина: хеч ким уришмаса керак...
Старый4 17.06.2017, 15:14   #6
Points: 69,736, Level: 100 Points: 69,736, Level: 100 Points: 69,736, Level: 100
Поблагодарил(а): 1,249
Поблагодарили 8,544 раз(а) в 2,845 сообщениях
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0048
GCPROGSMTOOL V1.0.0.0048 released.
Exynos Shannon phones cert read via exynos unlock
(till QAx basebands.)
With no Root.
Note: Only tool in market support code read & cert read same time..(till QAx basebands.)
World's exclusive J727P Samsung sprint new models unlocking support etc.
Note: Some of you already noticed combination firmware may help you to sim unlock latest firmware without root
Старый4 15.08.2017, 18:10   #7
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0049
GCPROGSMTOOL V1.0.0.0049 released.
Samsung FRP_UFS via uart support.
Note: Please read help-file for steps.
Samsung MTK base simlock code read support (use ADB unlock)
Need Root
Samsung qcom efs reset method (use reset efs Button)
without root.
MTK new security imei Repair support.
Improvements:
Improved spd imei repair.
MTK imei repair via ADB.
Samsung sprint unlock fail on some 6.x androids.
ADB methods for unsecured roots.
ADB internal functions.
All Card Firmware updated to version 2. You many need to update your card with update tool.
Card issue on many case..
GCPROLGCDMA
GCPROZTECDMA
GCPROHUAWEICDMA
GCPROMULTICDMA
Usmonov Rustam (16.08.2017)
Старый4 12.09.2017, 00:16   #8
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0050
GCPROGSMTOOL V1.0.0.0050 released.
Added Samsung MSL send support via adb
without root or reflash any combination..
(use same option MSL Unlock USB)
Note 1: Model like s8 or new don't have UART cable yet in market you can use this option to send MSL code and direct unlock.
Note 2: We do not provide MSL service. MSL16 must be get from other sources,3rd party etc.
Improvements:
Samsung efs reset for qcom without root.(careful no backup is made because of no root.)
Samsung sprint unlock for non rooted 6.x
MODGC method should work now on almost qcom old to latest.
Samsung repair imei,cert write etc MSL auth issue.
Samsung MTK code reader.
Samsung bypass knox.
ADB handling with some custom root.
Старый4 05.10.2017, 20:00   #9
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0051
GCPROGSMTOOL V1.0.0.0051 released.
Added
World's First Samsung MSL Unlock support for Warranty void phones network unlocking.
beta
Note:We do not provide any MSL16 please check sales section or wanted section for such service.
Note2: May not work on some security totally depend on phone & simlock type.
How?
Use option MSL Unlock USB when ask for ADB Press Yes.
World's First Android FRP Remove ADB alternative method for almost all Androids.
beta
Note: Phone should have adb and security patch older 11-2016 without ROOT.
How?
Use option FRP Remove ADB Press YES when ask for new method.(will remove pattern,pin,password etc too)
Improvements:
Motorola adb enable older then jun 2017.
Samsung msl unlock adb.
LG sprint 6.x/7.x unlocking.
FRP remove adb if rooted will remove pattern,password,pin etc too same time.
Samsung FRP_UFS method connection,verification for ufs storage or not.
imei cert write usb improved.
imei cert write adb improved.
Старый4 04.12.2017, 11:34   #10
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0052
Added support for Samsung Reactivation Lock Remove for QCOM & others phone
World First & Very Exclusive !!
Must have eng root or adb with root.
Added support for Samsung APP Locked Phone ASK/RPL Base Unlocking...
ASK read need root & must select modem port. write RPL do not need root.
RPL will be provide by GPG resellers check main sales section or GPG reseller list.
Added support for samsung qcom old phones bypass Knox ..
Bypass Knox is use to avoid combination firmware flashing for warranty void phones.. if combination not worked on your phone possible BYPASS KNOX will not work too.
It's BETA
Added Motorola new security patch & models Enable ADB Support.
Steps are exactly same as before no need fastboot mode just Factory Mode.
Improvements
GCMOD method.
adb_unlock fail to read full info.
sprint unlock for N910P rev 5.
sprint unlock with root come case its show false success.(J727P rev 3,J327P rev 3 is not possible to unlock at present)
improved adb handler.
Старый4 28.12.2017, 17:09   #11
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0053
GCPROGSMTOOL V1.0.0.0053 released.
Added
Exclusive support for Samsung APP Locked
QCOM Phone
instant Unlocking via credits..
World First & Exclusive support for Samsung APP Locked
Exynos Phone
Supported Models
SM-G368T
SM-G360T
SM-G360T1
SM-G530T
SM-G530T1
SM-J327T
SM-J327T1
SM-J727T
SM-J727T1
SM-G892U
SM-G930T
SM-G930T1
SM-G935T
SM-G935T1
SM-G950U
SM-G950U1
SM-G955U
SM-G955U1
SM-N950U
SM-N950U1
Improvements:
Exynos unlock.
Shannon read/write certs.
SS315
SS335
Sprint unlock domestic for Samsung.
S card Manager.
Note: 1 application locked Samsung phone will take 10 credits till 01-01-2018.
1 application locked Samsung phone will take 16 credits after01-01-2018.
Старый4 17.01.2018, 16:20   #12
Вес репутации: 49
Lightbulb GCPROGSMTOOL V1.0.0.0054
GCPROGSMTOOL V1.0.0.0054 released.
What's New:
Added samsung RLOCK ADB for some models & temp rooted phones.
Improvements:
Ask/rpl process will not make RPL if already exist.
Users who tick on use server will only use connection.
server connection method.
S card manager with failed with some card readers and result locked cards.
GCPROUPDTOOL V1.0.0.22 Released.
Improvements:
Error handling with function to report error via log to GCPro Team in case of crash/close/bug.
Server connection method.
S card manager.
1 application locked samsung phone will take 10 credits.
Старый4 03.03.2018, 12:50   #13
Вес репутации: 49
Lightbulb GCPROGSMTOOL V1.0.0.0055
GCPROGSMTOOL V1.0.0.0055 released.
Older firmware without root unlock via credits.
G360T
G360T1
G530T
G530T1
Samsung SHANNON cert read support over DIAG
305
308
310
315
333
335 etc
Note: Process is exactly easy dial *#0808# select last option for diag port. select port and make exynos unlock. need older then RA firmware.
beta
Samsung SHANNON code read support over DIAG.
308
310
315
333
335 etc
beta
Samsung QCOM code read support for model
G935A
J320
J327
J727
J510F
T337A
N950 etc
Note: use option READ_CODE_QCOM connect in normal mode and make sure adb is on.. do not need root.. for unsupported model please contact us.
Note2: this process will make ASK file send to reseller for code return time instant to few minutes.
beta
Improvements:
RLOCK ADB.
Frp ufs uart detection.
Comport sub system to support maxim 9999 ports.
Comport scan.
adb scan show real adb device only.
Samsung flasher,reactivation remove,frp remove,eelock remove etc which stuck application if new bootloader.
Старый4 29.03.2018, 17:12   #14
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0056
GCPROGSMTOOL V1.0.0.0056 released.
Samsung QCOM code read support for model SM-J250F via ask to code.
SAMSUNG Exynos APPLOCKED J327T Unlocking any version unlock via server for FREE..
beta
Note:Need to tick on use server & TMobile Unlock option. Need valid credit in account.
SAMSUNG Exynos older models via Tmobile Unlock need RA or older modem
NO ROOT
beta
Note:Need to tick on use server & TMobile Unlock option.This will charge 2 credits.
LG QCOM APPLOCKED Phone unlock via credits
Need ROOT
beta
Note:If you have any issue on unlocking LG APPLOCKED, please make your own thread with log credits will be refunded only with full log.This will charge 10 credits.
Improvements:
Exynos unlock over diag for
SS305
SS308
SS315
new models still need RA or older firmware.
Comport selection method.
Ask/read write crash some time on write rpl.
Exynos unlock for ask read will verify full security before make ask.
Exynos unlock over diag cert read for STL old model.
Comport scan method.
Sprint unlock, may help on J327P U3 temp unlock. Make sure diag port is selected.
Sprint unlock with root show spc.
qcom code read.
GCPROUPDTOOL V1.0.0.25 Released.
Added
option to check replacement card or empty card.
Improvements:
server connection.
checking of card which have issue on update last time.
Старый4 24.04.2018, 18:25   #15
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0057
GCPROGSMTOOL V1.0.0.0057 released.
Added
SAMSUNG MSL Unlock via credits older then 8.x Android os..
Note:Need to tick on use server & MSL Unlock usb or adb.This service is not instant take 24hrs to 72hrs.
Note2:User have to tick on use server & one more time MSL Unlock usb or adb same phone after 24hrs to 72hrs.
Note3:No cancel or refund for MSL counter blocked or S9 or applocked phones.
SAMSUNG QCOM older then 8.x android code read via server.
Note:Need to tick on use server & qcom code read. This service is not instant.
Note2:User have to tick on use server & one more time qcom code read same phone after few minutes to display codes.
SAMSUNG Exynos older then RAx firmware code read via server.
Note2:User have to tick on use server & one more time Exynos Unlock same phone after few minutes to display codes.
Credits check option in setting menu.
Improvement:
Ask/rpl methods if rpl exist software will auto read and write only RPL not use server.
Qcom code read.
Comports method.
HTC sprint diag port unlocking.
Старый4 15.06.2018, 13:22   #16
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0058
GCPROGSMTOOL V1.0.0.0058 released.
Added
World First SS333 all models all version simlock code read.
without root
beta
World First SS333 all models all version imeicert read.
without root
beta
SS333 all models all version TMB Unlock via credits..
without root
Note:You can unlock such phones without credits via root also.
Note:for SS333 No root read helpfile How to use SS333 Without root.txt
Improvements:
Exynos unlock for ss333,310,308 scuid was not saved.
Lg rpl write.
imei cert write adb when nv is corrupted or baseband is unknown.
RLOCK ADB even after success on UART report FAIL.
Старый4 14.08.2018, 13:04   #17
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0059
GCPROGSMTOOL V1.0.0.0059 released.
What's New:
S9/S9+ TMB Unlock support via credits.
beta
Android 5.x to 8.x set upload support.
beta
Android 8.x TMB/MTR RPL Write support.
beta
Android 8.x MSL Unlock support via credits.
beta
Note:You can not unlock S9 or MSL cert base phones currently,do not waste credits on msl code.
Improvements:
qcom code read will stop if read fail more then 10time.
qcom code read should work now on older device with 5.1.1
SS333 No root for S6,S6edge invalid hmac error non lz4 nv issue.
SS310 imeicert write adb.
Exynos unlock over modem port for older models cert read issue and backup path.
Exynos J727T,J727T1 Unlock scudb was not saved.
Старый4 29.10.2018, 18:44   #18
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0060
GCPROGSMTOOL V1.0.0.0060 released.
Samsung Qcom Code Read Via Server
New Method.
LG TMB & MTR Unlock Support
Android 8.x
Samsung Qcom EFS Reset Support
All Android version
Improved
S9 Base T-Mobile Unlock.
EFS Reset Without Root For Qcom on Older Firmware.
ADB Related with Magisk SU.
Sprint Unlock Issue For Older Models.
APP Locked Samsung & Lg Unlocking Method.
Последний раз редактировалось gsmservice.uz; 29.10.2018 в 18:48.
Старый4 03.01.2019, 18:14   #19
Вес репутации: 49
По умолчанию !!! GCPro UPDATE Information..!!!
!!! GCPro UPDATE Information..!!! UPDATE [01-01-19]
Hello
Please every one make sure you update your GCPro to OS 0003 till 30-01-2019
If you forget or not updated card in OS 0003 YOU WILL NO LONGER SUPPORTED or able to update on next version..
From date 30-01-2019 GCPro UPDATE TOOL and server will not accept any card other then OS 0003
!!! Важная информация GCPro !!! UPDATE [01-01-19]
Убедитесь что OS вашего GCPro - 0003.
Обновить OS необходимо до 31 января 2019 года.
После 31 января 2019 года - сервер не будет поддерживать другие OS кроме 0003 и вы можете остаться без поддержки!
!!! GCPro мухим маълумот !!! UPDATE [01-01-19]
Сиз GCPro OSни - 0003 версияга update килишингиз керак.
OS update 31 январ 2019 йилгача амалга оширилиши керак!
31 январ 2019 дан бошлаб - сервер GCPRO OS-0003 дан бошкасини кулламайди!
GCPro OSни - 0003 версияга update булмаса - support сиз колишингиз мумкин!
Последний раз редактировалось gsmservice.uz; 03.01.2019 в 18:22.
Ulug'bek84 (04.01.2019)
Старый4 09.01.2019, 10:31   #20
Вес репутации: 49
По умолчанию GCPROGSMTOOL V1.0.0.0061
GCPROGSMTOOL V1.0.0.0061 released.
Added Sprint S9(G960U),S9+(G965U) Rev 1,Rev 2,Rev 3(via combination modem) sprint direct unlock.(use sprint unlock)* beta
Note:You must enable diag for such phone via ##3424#.
Added G892U,S8(G950U),S8+(G955U),S9(G960U),S9+(G965U) Rev 1,Rev 2,Rev 3(via combination modem) application locked direct unlock.
Note:You must enable diag for such phone via *#0808#.
Added MSL ID,IMEICERT check,IMEI CERT CPID Read over adb.
Added MSLCERT base device over uart You must have valid MSLCERT in cert file. * beta
Improved qcom code reader.
Improved samsung frp_ufs.
Improved comport faster then before.
Improved applocked unlocking.
Improved J327P U3 temp unlock.
Improved smartcard manager.
PS. you will be charged 4 credit each time you use even same phone.
Текущее время: 05:16. Часовой пояс GMT +5.
