Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Infinity Box
Infinity Box Форум поддержки программатора Infinity Box
Старый4 13.08.2020, 15:18   #21
Points: 153,943, Level: 100 Points: 153,943, Level: 100 Points: 153,943, Level: 100
Поблагодарил(а): 1,474
Поблагодарили 9,747 раз(а) в 3,529 сообщениях
Вес репутации: 64
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.06
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.06 - Android 10, FastRead, FastFlash
As ordinary, unique functions and methods released
Core
Changed : FlashCore Protocol updated
Changed : DiagCore Protocol updated
Changed : NAND protocol adaptation
Changed : Operations speed increased
Flasher
Changed : Flash Engine updated
Changed : Handling for 64bit files optimized
Changed : Activated FastFlash V1 protocol *
Changed : Activated FastFlash V2 protocol *
!* FastFlash protocol allow increase flashing speed for big unsparsed images
!* FastFlash protocol reduce flashing time up to 4-6 times, depend on device configuration - 3-4 minutes against 20-25
!* FastFlash activated automatically, if can be performed
!* GOOD USB cable and GOOD USB port must be used - do not use USB HUBs !
Changed : Support for new PAC formats activated: v2.x.x line
Service
Changed : Identify scheme : Read more accurate and complete info *
!* Include modern Android 9 and Android 10 devices
Changed : Precise FileSystem settings detection ( Type and Encryption algo )
Changed : Better security detection
Changed : Format FS / Reset settings updated
Firmware Reader
Changed : Reading speed up to 30% faster ! *
!* Test feature, support modern UniSoc devices: SC7731E, SC9832E, SC9863
!* Test feature, only RS-featured loaders supported !
Changed : Android 10 support activated! *
!* Support latest Android 9 and modern Android 10 devices from now!
!* Allow read complete firmware image from Android 10 devices without loss any ota/vendor abilities
Changed : X64 devices/loaders native support activated for complete reading
Changed : SW now create Android-version depend images for better compatibility
Changed : SW now create correct FileSystems bundle according device settings *
!* Almost reducing "hang" case after flashing
Changed : Improved structure identification
Changed : Support more different types
Changed : Structure identification and NAND reader more stable now (complete E-series NAND adaptation is on the way)
Model DB
Changed : New loaders included for various set of devices
Changed : New Generic loaders included and updated existing ones
Other
Changed : Removed outdated options from platform tab, many options changed to atomatic mode
BugFix : Minor changes and fixes
Info
Android 10 enabled devices : SC7731E, SC9832E, SC9863
FastFlash enabled devices : SC9832E, SC9863
Старый4 07.09.2020, 15:31   #22
Вес репутации: 64
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.07
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.07 released - UltraReading & New Features activated
Core
BugFix : SC9832E line support updated
BugFix : SC9820E line support updated
BugFix : SC9863x line support updated
NewFeature : eMMC ReadOnly check for DLv4 and later ( automatic during boot )
Changed : All service features speed under FlashMode increased
Flasher
Changed : FastFlash protocol updated
Service
BugFix [Identify] : FS state detection may fail for legacy SPD line, fixed
Changed [Identify] : SelfLearn / Automatic DB update during "Identify" rebuild
Changed [Identify] : Support detection of AES and RSA-enabled auth in devices/loaders
Changed [Identify] : Support correct BASE <-> DEVICE verification for optimal loader selection
BugFix [Read Privacy] : Privacy Lock reading on some devices may fail , fixed
NewFeature [Read Privacy] : Mobile AntiTheft password reading ( another version of "privacy lock" )
BugFix [Format FS] : Fixed Format FS in DiagMode for Android 10 and modern Android 9 devices
Firmware Reader
Changed : Complete FWReader rebuild to cover most count of different devices, existing on market *
!* Almost all Flashing issues has been fixed, FWRead repeat required for problematic cases/models!
Changed : UltraReading option activated ! *
!* Now reading of UniSoc devices 3-5 times faster, than before
- approx 20 mins instead of 70 for SC9853i (2.2 GiB) comparing to older releases
- approx 12 mins instead of 40 for SC9832E (2.5 GiB) comparing to older releases
- approx 20 mins instead of 60 for SC9863 (4.4 GiB) comparing to older releases
- approx 15 mins instead of 50 for SC7731 (1.5 GiB) comparing to older releases
!* Most generic loaders now support FastReading ( RS,SS,0S,1S,2S )
- Use USB-2 port !
- DO NOT use USB-3 port !
- DO NOT use USB-HUB !
Changed : Android 10 devices support improved
Model DB
Changed : SC9820E(eMMC), SC9832E, SC9863x loaders updated
Other
Changed : Power Reset/Switch off scenario operation-depend now
Option : GUI ( File -> GUI ) : Allow select other interface mode*
!* Default interface - standard V2 line GUI
!* Wide interface - best for big screen / big distance to monitor
!* Wide log - extend log window to screen size - optimal for most cases
Старый4 03.11.2020, 19:52   #23
Вес репутации: 64
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.08 - NAND, Forensic and more features !
Core
Changed : FlashCore protocol updated
Changed : NAND support rebuild
Changed : X64 SS/RS loader line handling optimized
New SOC : SC9820E with NAND support
New SOC : SC7731E with NAND support
Flasher
Changed : Big files handling optimized
Changed : NVM manager updated
Firmware reader
New Feature : UniSoc NAND SC9820E/SC7731E support activated !
- Allow backup FW from range of phones, based on SC9820E/SC7731E SoC with NAND flash memory
- Firmware is complete, not damage any security, ota or any other compatibility
Changed : Forced reading ( disable deep verify ) option enabled - Use WITH CAUTION!
Changed : Android 4.x / Mocor 5 specific changes
Changed : UBI defragmentation for NAND devices activated by default
Service
New Feature : Security Repair allow change BT/WiFi MAC
- Useful only in DiagMode for UniSoc(E-line), Flash/Diag for SPRD line
Changed : Security Repair options - Generate MAC's - double click at MAC field to generate and activated
Changed : Security Repair options - AutoIncremental set SEC2/SEC3 fields, when SEC1 set. Just double click in next field
Changed : Security Repair : NVM Manager updated according latest devices changes
Changed : Identify : Support identify for UniSoc NAND line
Changed : Identify : NAND identify speed increased
UserData
Changed : Privacy reading types increased to 4 ( +2 new types )
New Feature : UserData DeepVerify and DUMP activated!
- Available for users with active Infinity Data Explorer module!
- Ignore ALL sprd protocol limitations, which require MEMORY DESOLDER and EXTERNAL MEMORY PROGRAMMER using!
- Allow verify and dump COMPLETE USER image for wide range of types and filesystems
1. eMMC with EXT3/EXT4 filesystem. FDE check may differs from Identify!
2. eMMC with F2FS filesystem. FDE check may differs from Identify!
3. NAND with UBIFS. Result image defragmented and prepared for further forensic analyze
- Internal checks during dumping make differ, than Identify option, analysis. Even if Identify say FDE - device can be not encrypted.
- Ability to resume dumping in case of read fails, can be used much times, as need
- After dumping device must be flashed!
1. Get FW or make FW backup from WORKING/GOOD device with complete options if SW asks
2. Complete Flash device
or
2. If need revert device to initial state
2.1 : Select FW, uncheck all items ( Rmouse - > Uncheck all )
2.2 : Select UBOOT/SPL
2.3 : All other settings must be default, not touch anything
2.4 : Flash device
Model DB
Changed : New generic loaders included, changes some existing once for better compatibility
Changed : Generic SC9820E NAND loaders included
Changed : Generic SC7731E NAND loaders included
QIN QF9 ( QIN1 SC9820E ) - full support : Read/Write FW,Reset Settings,Security,Service
- Firmware can be found on support area
- Boot key : Call button
- Change Lang sequence : Ok, Left, down, ok, 15 times - down, ok, ok, select need language ( English )
Password for files: 12345678
Ulugbek (04.11.2020)
Старый4 17.11.2020, 19:29   #24
Вес репутации: 64
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.09 - SPUnlock for most SPD/UniSoc
Core
Flasher
Changed : NVM manager updated. Recovery mode rebuild
Firmware reader
Changed : SPRD Android 4.x line minor changes
Changed : New types supported (Android 9/10)
Service
New Feature: SP (Network) Unlock activated !
- Support Legacy SPRD phones on SC7715/SC7731/SC9820/SC9832/SC9850
- Support modern UniSoc phones on SC9820e/SC7731e/SC9832e/SC9850/SC9853i/SC9863
- Support unlock in FlashMode ( ! recommended way, permanent )
- Support unlock in DiagMode ( ! may relock in some certain cases )
- Support unlock for signed and unsigned devices
-- Unsigned/Legacy devices supported standalone without server
-- Modern devices require server support
Changed : NVM manager updated ( Read/Write process revised )
Other
- Setting tab activated
1. Allow setup user details to use remote/server functions
2. Allow select Firmware path
- Changed default paths for different operations
- Minor changes and fixes
ilhom-uz (18.11.2020), Nurziyod (17.11.2020), Ulugbek (17.11.2020)
chinese, download, forum, free, infinity, miracle, spd, spreadtrum, tashkent, update, uzbekistan, бепул, обновления, форум, юклаш, янгилаш
Текущее время: 11:38. Часовой пояс GMT +5.
