Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Продукты Z3X-Team > Z3X Easy Jtag
Z3X Easy Jtag Z3X Easy Jtag
Старый4 10.01.2019, 16:54   #21
Points: 82,487, Level: 100 Points: 82,487, Level: 100 Points: 82,487, Level: 100
Поблагодарил(а): 1,329
Поблагодарили 9,075 раз(а) в 3,126 сообщениях
Вес репутации: 54
По умолчанию Easy JTAG Plus Suite Released v1.5.3.0
Fixed:
- Bugs that have been found through your crash report
- Scatter file processing (MTK)
- Contact Extractor
- Preloader parser
- FAT partitions mounting
- Minor interface changes
- Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
- Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
- Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
- Auto/Manual loaders select for Qualcomm HS-USB QDLoader 9008 interface
- Samsung firmware lz4 unpack support (Write by vendor - Samsung)
- Import from cm2qlm xml backups (Write by vendor - Qualcomm)
- Unpack Bootloader.img archive from Motorola firmware files
- Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
- Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
- Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
- Explorer: Pin and Password decoding (only English and Russian letters)
Старый4 11.04.2019, 16:03   #22
Вес репутации: 54
По умолчанию EasyJTAG Classic Software 3.5
EasyJTAG Classic Software 3.5 Changes:
- UFS 2.0/2.1 Memory Chip Identification added (World First USB2.0). *
- UFS 2.0/2.1 Memory Multi LUN Read/Write/Erase added (World First USB2.0). *
- UFS 2.0/2.1 Memory Advanced Configuration added (World First USB2.0). *
- UFS 2.0/2.1 Memory GPT Partitioning Support added (World First USB2.0). *
- eMMC RPMB Region Status added.
- eMMC RPMB Key writing added.
- eMMC RPMB Read without key added.
- eMMC RPMB Write with key added.
- Apple NAND Support improved for many devices.
- NAND Detection Bugs Fixed.
- Partitions tool menus advanced options.
- Fixed Support of 4K block devices.
- Scripting core is improved.
UFS EASY-JTAG Sockets 3 types:
BGA UFS153 Socket - more details here
BGA UFS95 Socket - more details here
BGA UFS254 Socket - more details here
Attention: Sockets is protected by DSN ECSDA Chips and only trusted manufacturers
and sellers bring you high quality tested and verified products.
EasyJTAG Plus Box Firmware 2.38 Changes:
- UFS Memory Protocol Added ( UFS2.0,UFS2.1,UFS3.0 )
- UFS Sockets Genuine Verification added.
- NAND Timing Bugs Fixed
- I2C Bus Protocol Added
- Box security improved
- Many bugs are fixed!
31 New Devices is added to support!
UPDATED:
- ALCATEL 9001D (Read/Write/Dump/ISP eMMC Pinout)
- ASUS ZENFONE 5 T00G (ISP eMMC Pinout)
- BLU STUDIO 7 (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR PGN-403 (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR TAB785R-3G (Read/Write/Dump/ISP eMMC Pinout)
- HUAWEI ASCEND P8 (ALE-CL00) (ISP eMMC Pinout)
- HUAWEI MEDIAPAD T2 7.0 LTE (BGO-DL09) (ISP eMMC Pinout)
- HUAWEI P8 Lite (PRA-LA1) (Read/Write/Dump/ISP eMMC Pinout)
- LG K121L (ISP eMMC Pinout)
- MICROMAX A068 (ISP eMMC Pinout)
- MICROMAX Q385 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1635-02 MOTO Z PLAY (ISP eMMC Pinout)
- MOTOROLA XT1677 MOTO G5 (ISP eMMC Pinout)
- SAMSUNG SM-A320F (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-G550FY (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-G720N0 (ISP eMMC Pinout)
- SAMSUNG SM-G903W (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J320VPP (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J327P (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J330F (ISP eMMC Pinout)
- SAMSUNG SM-J337A (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J400G (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J720M (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J730GM (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J810F_DS (ISP eMMC Pinout)
- SAMSUNG SM-S550TL (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-Z400F (Read/Write/Dump/ISP eMMC Pinout)
- SONY E5823 Z5 Compact (ISP eMMC Pinout)
- VIVO 1723 (Read/Write/Dump/ISP eMMC Pinout)
- YUREKA YU5510A (ISP eMMC Pinout)
- ZTE Z833 (ISP eMMC Pinout)
Старый4 28.05.2019, 16:29   #23
Вес репутации: 54
По умолчанию EasyJTAG 3.6
EasyJTAG 3.6 Update Released!
Changes:
- UFS Erase operation is added*
- Android Userdata Format on UFS ( Unencrypted devices )
- Android Userdata Wipe on UFS (Encrypted Devices )
- EXT4 Driver is improved for handling UFS 4K devices
- 3-in-1 Moorc Sockets Supported
- Some Samsung UFS Serial number fixed
- Fixed support of THGLF2G8J4LB* UFS chips
- Fixed support of KLUCG4J1EB-B0B1 UFS chip
- UFS Operations ufs length autocorrect
- Fixed random stack overflow when Reading or Writing UFS IC
- UFS UPIU Wait response Error fixed
- Fixed API error in Autorun Agent
- Some UI fixes and improvements
*Attention: Erase operation behavior depend of ProvisioningType flag of current
LUN and may keep data contents instead wiping them. More
Information you can read in JESD220A UFS1.1 standard.
EasyJTAG Firmware 2.40
- Added - SCSI UNMAP command.
- SK Hynix UFS timing fix
- Sandisk UFS detection FIX
- AFC Credit FIX
- Hynix UFS Boot timeout FIX
- Added BGA254 UFS Sockets support
- Added MOORC 3-in-1 Sockets support
New Pinouts and Dumps
- ASUS A006 ZenFone V (Read/Write/Dump/ISP eMMC Pinout)
- BQ AQUARIS V (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR TFX711G (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR TFX712G (Read/Write/Dump/ISP eMMC Pinout)
- HTC DESIRE 530 (Read/Write/Dump/ISP eMMC Pinout)
- HUAWEI MEDIAPAD T2 10.0 PRO (Read/Write/Dump/ISP eMMC Pinout)
- JIO LYF F120B (ISP eMMC Pinout)
- LEECO LE S3 X626 (ISP eMMC Pinout)
- LENOVO A6000 (ISP eMMC Pinout)
- LeTV X500 (ISP eMMC Pinout)
- LG LMX210EMW (Read/Write/Dump/ISP eMMC Pinout)
- LG MP260 (Read/Write/Dump/ISP eMMC Pinout)
- MICROMAX E460 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1069 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1675 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1774 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1799-2 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1922 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1922-7 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1924-1 (Read/Write/Dump/ISP eMMC Pinout)
- NOKIA TA-1011 (Read/Write/Dump/ISP eMMC Pinout)
- OPPO A3S (ISP eMMC Pinout)
- OPPO A5 CPH1809 (Read/Write/Dump/ISP eMMC Pinout)
- OPPO K1 (ISP eMMC Pinout)
- OPPO R15 (ISP eMMC Pinout)
- OPPO R15X (ISP eMMC Pinout)
- PRESTIGIO PMP7280C 3G DUO (ISP eMMC Pinout)
- SAMSUNG SM-G615F (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J260F (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J700M (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-T113 (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-T800 (Read/Write/Dump/ISP eMMC Pinout)
- SONY E6653 Xperia Z5 (ISP eMMC Pinout)
- SONY XPERIA XZ DUAL F8332 (ISP eMMC Pinout)
- TEXET TM-7877 3G (ISP eMMC Pinout)
- TomTom VIA (ISP eMMC Pinout)
- VIVO V1813BA (Read/Write/Dump/ISP eMMC Pinout)
- XIAOMI REDMI 5 PLUS (Read/Write/Dump/ISP eMMC Pinout)
- XIAOMI REDMI Y1 (ISP eMMC Pinout)
- ZTE BLADE Z10 A512 (ISP eMMC Pinout)
- ZTE Z832 (Read/Write/Dump/ISP eMMC Pinout)
Текущее время: 04:36. Часовой пояс GMT +5.
