Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Продукты Z3X-Team > Z3X Easy Jtag
Z3X Easy Jtag Z3X Easy Jtag
Старый4 10.01.2019, 16:54   #21
Points: 129,727, Level: 100 Points: 129,727, Level: 100 Points: 129,727, Level: 100
Поблагодарил(а): 1,461
Поблагодарили 9,619 раз(а) в 3,446 сообщениях
По умолчанию Easy JTAG Plus Suite Released v1.5.3.0
Fixed:
- Bugs that have been found through your crash report
- Scatter file processing (MTK)
- Contact Extractor
- Preloader parser
- FAT partitions mounting
- Minor interface changes
- Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
- Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
- Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
- Auto/Manual loaders select for Qualcomm HS-USB QDLoader 9008 interface
- Samsung firmware lz4 unpack support (Write by vendor - Samsung)
- Import from cm2qlm xml backups (Write by vendor - Qualcomm)
- Unpack Bootloader.img archive from Motorola firmware files
- Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
- Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
- Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
- Explorer: Pin and Password decoding (only English and Russian letters)
Старый4 11.04.2019, 16:03   #22
По умолчанию EasyJTAG Classic Software 3.5
EasyJTAG Classic Software 3.5 Changes:
- UFS 2.0/2.1 Memory Chip Identification added (World First USB2.0). *
- UFS 2.0/2.1 Memory Multi LUN Read/Write/Erase added (World First USB2.0). *
- UFS 2.0/2.1 Memory Advanced Configuration added (World First USB2.0). *
- UFS 2.0/2.1 Memory GPT Partitioning Support added (World First USB2.0). *
- eMMC RPMB Region Status added.
- eMMC RPMB Key writing added.
- eMMC RPMB Read without key added.
- eMMC RPMB Write with key added.
- Apple NAND Support improved for many devices.
- NAND Detection Bugs Fixed.
- Partitions tool menus advanced options.
- Fixed Support of 4K block devices.
- Scripting core is improved.
UFS EASY-JTAG Sockets 3 types:
BGA UFS153 Socket - more details here
BGA UFS95 Socket - more details here
BGA UFS254 Socket - more details here
Attention: Sockets is protected by DSN ECSDA Chips and only trusted manufacturers
and sellers bring you high quality tested and verified products.
EasyJTAG Plus Box Firmware 2.38 Changes:
- UFS Memory Protocol Added ( UFS2.0,UFS2.1,UFS3.0 )
- UFS Sockets Genuine Verification added.
- NAND Timing Bugs Fixed
- I2C Bus Protocol Added
- Box security improved
- Many bugs are fixed!
31 New Devices is added to support!
UPDATED:
- ALCATEL 9001D (Read/Write/Dump/ISP eMMC Pinout)
- ASUS ZENFONE 5 T00G (ISP eMMC Pinout)
- BLU STUDIO 7 (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR PGN-403 (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR TAB785R-3G (Read/Write/Dump/ISP eMMC Pinout)
- HUAWEI ASCEND P8 (ALE-CL00) (ISP eMMC Pinout)
- HUAWEI MEDIAPAD T2 7.0 LTE (BGO-DL09) (ISP eMMC Pinout)
- HUAWEI P8 Lite (PRA-LA1) (Read/Write/Dump/ISP eMMC Pinout)
- LG K121L (ISP eMMC Pinout)
- MICROMAX A068 (ISP eMMC Pinout)
- MICROMAX Q385 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1635-02 MOTO Z PLAY (ISP eMMC Pinout)
- MOTOROLA XT1677 MOTO G5 (ISP eMMC Pinout)
- SAMSUNG SM-A320F (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-G550FY (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-G720N0 (ISP eMMC Pinout)
- SAMSUNG SM-G903W (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J320VPP (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J327P (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J330F (ISP eMMC Pinout)
- SAMSUNG SM-J337A (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J400G (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J720M (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J730GM (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J810F_DS (ISP eMMC Pinout)
- SAMSUNG SM-S550TL (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-Z400F (Read/Write/Dump/ISP eMMC Pinout)
- SONY E5823 Z5 Compact (ISP eMMC Pinout)
- VIVO 1723 (Read/Write/Dump/ISP eMMC Pinout)
- YUREKA YU5510A (ISP eMMC Pinout)
- ZTE Z833 (ISP eMMC Pinout)
Старый4 28.05.2019, 16:29   #23
По умолчанию EasyJTAG 3.6
EasyJTAG 3.6 Update Released!
Changes:
- UFS Erase operation is added*
- Android Userdata Format on UFS ( Unencrypted devices )
- Android Userdata Wipe on UFS (Encrypted Devices )
- EXT4 Driver is improved for handling UFS 4K devices
- 3-in-1 Moorc Sockets Supported
- Some Samsung UFS Serial number fixed
- Fixed support of THGLF2G8J4LB* UFS chips
- Fixed support of KLUCG4J1EB-B0B1 UFS chip
- UFS Operations ufs length autocorrect
- Fixed random stack overflow when Reading or Writing UFS IC
- UFS UPIU Wait response Error fixed
- Fixed API error in Autorun Agent
- Some UI fixes and improvements
*Attention: Erase operation behavior depend of ProvisioningType flag of current
LUN and may keep data contents instead wiping them. More
Information you can read in JESD220A UFS1.1 standard.
EasyJTAG Firmware 2.40
- Added - SCSI UNMAP command.
- SK Hynix UFS timing fix
- Sandisk UFS detection FIX
- AFC Credit FIX
- Hynix UFS Boot timeout FIX
- Added BGA254 UFS Sockets support
- Added MOORC 3-in-1 Sockets support
New Pinouts and Dumps
- ASUS A006 ZenFone V (Read/Write/Dump/ISP eMMC Pinout)
- BQ AQUARIS V (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR TFX711G (Read/Write/Dump/ISP eMMC Pinout)
- CONDOR TFX712G (Read/Write/Dump/ISP eMMC Pinout)
- HTC DESIRE 530 (Read/Write/Dump/ISP eMMC Pinout)
- HUAWEI MEDIAPAD T2 10.0 PRO (Read/Write/Dump/ISP eMMC Pinout)
- JIO LYF F120B (ISP eMMC Pinout)
- LEECO LE S3 X626 (ISP eMMC Pinout)
- LENOVO A6000 (ISP eMMC Pinout)
- LeTV X500 (ISP eMMC Pinout)
- LG LMX210EMW (Read/Write/Dump/ISP eMMC Pinout)
- LG MP260 (Read/Write/Dump/ISP eMMC Pinout)
- MICROMAX E460 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1069 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1675 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1774 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1799-2 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1922 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1922-7 (Read/Write/Dump/ISP eMMC Pinout)
- MOTOROLA XT1924-1 (Read/Write/Dump/ISP eMMC Pinout)
- NOKIA TA-1011 (Read/Write/Dump/ISP eMMC Pinout)
- OPPO A3S (ISP eMMC Pinout)
- OPPO A5 CPH1809 (Read/Write/Dump/ISP eMMC Pinout)
- OPPO K1 (ISP eMMC Pinout)
- OPPO R15 (ISP eMMC Pinout)
- OPPO R15X (ISP eMMC Pinout)
- PRESTIGIO PMP7280C 3G DUO (ISP eMMC Pinout)
- SAMSUNG SM-G615F (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J260F (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-J700M (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-T113 (Read/Write/Dump/ISP eMMC Pinout)
- SAMSUNG SM-T800 (Read/Write/Dump/ISP eMMC Pinout)
- SONY E6653 Xperia Z5 (ISP eMMC Pinout)
- SONY XPERIA XZ DUAL F8332 (ISP eMMC Pinout)
- TEXET TM-7877 3G (ISP eMMC Pinout)
- TomTom VIA (ISP eMMC Pinout)
- VIVO V1813BA (Read/Write/Dump/ISP eMMC Pinout)
- XIAOMI REDMI 5 PLUS (Read/Write/Dump/ISP eMMC Pinout)
- XIAOMI REDMI Y1 (ISP eMMC Pinout)
- ZTE BLADE Z10 A512 (ISP eMMC Pinout)
- ZTE Z832 (Read/Write/Dump/ISP eMMC Pinout)
Старый4 13.02.2020, 12:19   #24
По умолчанию EasyJtag_v3.6.2.3
EasyJtag_v3.6.2.3
AFC Credit FIX
Add Many More..........
Старый4 23.06.2020, 13:02   #25
По умолчанию EasyJtag Release v3.7.0.11
EasyJtag Release v3.7.0.11. Lot of changes. Speed Increased Up to 10x times.
Gui/Core Changes:
Added: automatic resize of USERDATA.
Added: smart resize of any partition.
Added: new QC loaders.
Added: new functions in EasyAPI
Added: asynchronous disk i/o for UFS/eMMC/NAND.
Improved: UFS Read/Write Speed Increased up to 6Mb/s.
Improved: GPT partitions manager.
Improved: gui for Windows 10.
Fixed: software crash in reading GPT in some cases
New EasyJTAG Plus 2.52 Firmware changes:
Added: New UFS High performance Core.
Improved: UFS operations stability.
Fixed: Toshiba UFS Write NAK Error bug.
Added ISP pinouts for such devices:
- Acer Iconia Tab A3-A10
- Asus Zenfone Max Pro M1 (X00Td Zb601Kl)
- Asus Zenfone Max Pro M2 (X01Ad Zb633Kl)
- Bush Tablet Ac101Bu
- Digma Plane 7700T 4G Ps1127Pl
- Htc Desire X T329E Pm66100
- Huawei Honor 7 Plk-L01
- Huawei Honor 8A Jat-Lx1
- Huawei Honor 8S Ksa-Lx9
- Huawei Mate 20 Lite Sne-Lx1
- Huawei P Smart Ine-Lx1
- Infinix Hot S 573
- Kyocera E6560
- Lenovo Zuk Z2 Plus Z2132
- Lg H522Y
- Lg Lmq610Ta
- Lg Lmx410As
- Lg Lmx410Um
- Lg Lmx420Emw
- Lg Lmx510Wm
- Lg M322
- Motorola Moto G7 Play Xt1952
- Nokia 6 1 Plus Ta-1116
- Nokia Lumia 510 Rm-889
- Oppo A71K
- Oppo A71 Mtk (Cph1717)
- Oppo A83 Cph1729
- Oppo F3 (Cph1609)
- Oppo F3 Plus
- Oppo F9 Cph1823
- Realme 1
- Realme 2 Pro
- Realme 2 Rmx1805
- Realme 3 Pro Rmx1851 Bga254
- Realme 5
- Realme C1 Rmx1811
- Realme C2 Hipower(Usb Powered)
- Realme C2 Rmx1841 Rmx1845 Rmx1945
- Realme U1
- Samsung A10S Sm-A107F
- Samsung Galaxy A10 A105
- Samsung Sm-A015F
- Samsung Sm-A015G
- Samsung Sm-A015M
- Samsung Sm-A260F
- Samsung Sm-A750Fn
- Samsung Sm-G398Fn
- Samsung Sm-J510F
- Sony Xperia Xa1 Ultra G3212
- Vivo 1807 Y95
- Vivo S1
- Vivo U10 1916 (Pd1928F)
- Vivo U10
- Vivo Y51 Pd1510F
- Xiaomi Mi 8 Se
- Xiaomi Redmi 7A
- Xiaomi Redmi Note 7
- Google Pixel 2 G011A
- Google Pixel Sailfish G-2Pw4100
- Lenovo Zuk Z2 Pro (Z2121)
- Lg Ls993
- Lg Ls998
- Oneplus 3T A3010
- Samsung Sm-A920Fn-X
- Samsung Sm-G930A
- Samsung Sm-G930Vl
- Samsung Sm-G950F
- Samsung Sm-G950N
- Samsung Sm-G955F
- Samsung Sm-G955U
- Samsung Sm-G965U
- Samsung Sm-G973F
- Samsung Sm-N950U
- Samsung Sm-N960F
- Samsung Sm-N960N
- Samsung Sm-N975F
- Xiaomi Black Shark Skr-A0
Ulugbek (24.06.2020), XURSAND (23.06.2020)
Старый4 Сегодня, 15:37   #26
По умолчанию Easyjtag software v:3.7.1.17
Easyjtag software v:3.7.1.17 Released. World First
Added new function:
- Support mircon JZ150. World first.
Improved:
- eMMC ISP connection (CMD Errors )
- QC EDL Protocol stack in FH/DL
Fixed:
- UFS ISP errors on BGA254 socket.
Lot of GUI Fixes and improvements
Текущее время: 23:09. Часовой пояс GMT +5.
