Ultimate Multi Tool ( UMT ) Форум поддержки программатора UMT |
Опции темы |
#101 | ||||||||
UMTv2 / UMT Pro UltimateMTK v3.4
Added: Ace - Buzz 1 Plus Blu - Grand M3 Citycall - Life 10 Pro Gright - Inspire A380 Mini Infinix - S5 Lite (X652B) Lava - Z10 Oukitel - K6000 Pro QMobile - Noir X250 - Q Infinity Prime Starlight - My Star X Stream - B1s Tecno - Camon 12 Pro (CC9) iTel - IT1520 Some Minor Improvements Important - Features introduced may work on other devices too, which are not litsed here. - User needs to untick By Model checkbox to be able to select Platform manually. - For manual work, just select Platform and DA. - For new secured devices, you may need to select AUTH and/or Preloader. - Rest operations will work same. |
[Only Registered and Activated Users Can See Links. Click Here To Register...] |
#102 | ||||||||
UMTv2/UMTPro - QcFire v6.4 - Vivo Y20, V19, V20 and more...
Added Asus - Zenfone Live L1 (X00RD) Lenovo - K10 Note (L38111) Vivo (Vivo Heuristic) - V19 (PD1969F) - V20 (PD2039F) - Y20 (PD2034F) Wiko - View2 Go Rewritten Code for Vivo Heuristic Mode - Automatic detection of possible method - Alt. Write method wil be used whenever supported by device/loader - Manual Method improved to support future devices/loader without any update Updated Internal Loader Database |
#103 | ||||||||
UMTv2 / UMT Pro UltimateMTK v3.5
Added: Condor - Griffe T7 Gionee - F205 IRIS - Vox Fortis - Vox Steel Infinix - Hot 8 (X650C) iTel - A45 Karbonn - K9 Smart Grand Meizu - M6T Mobiistar - X1 Selfie OLLA - M8 Plus Panasonic - P91 Starlight - Future - My Star X Stream - B2 Plus Tecno - Camon iSky3 (KB3) - IN1 Pro - Spark Power 2 (LC8) Some Minor Improvements |
Пользователь сказал cпасибо: | Ulugbek (02.01.2021) |
#104 | ||||||||
UMTv2 / UMTPro - QcFire v6.5
Added Asus - ZenFone Live L1 (ZA550KL_X00RD) LYF - F320B Samsung - SM-A015F - SM-A015F/DS - SM-A015G - SM-A015G/DS - SM-A015M - SM-A015M/DS - SM-A015T1 - SM-M015F - SM-M015F/DS - SM-M015G - SM-M015G/DS - SM-S111DL Vivo - Z1x (PD1921F) (Vivo Heuristic) Updated Nokia NB0 Flasher - Added option to Format/FRP witout flashing anything. - Just load NB0 firmware, unselect all parts, and tick Format/FRP - Useful if loader not found in Internal Database, and you have NB0 firmware. - Use Pakcage Loader is now selected by default for better compatibilty. - Reset FRP on Finish is now selected by default. Updated OFP Extracter - Added Support for newer OFP format - Fixed extraction issue for some OFP files ie. CPH1611 Updated Vivo Heuristic Method - Added option Always use Erase Method even if Alt. Write Method is allowed. - Should be useful for Vivo V19 or other devices with Wait a second issue after format. Добавлено через 5 минут 18 секунд UMTv2/UMTPro - UltimateMTK v3.6 Added: Added Oppo/Realme Factory Reset in META - No need select any DA / Model - Done in less than 10 seconds Should work on Oppo Devices with following CPUs: - MT6771 - MT6762 - MT6763 - MT6765 Supported Models: - A1 - A11k - A12 - A1k - A1s - A3 - A31 - A5s - A72 - A73 - A79 - A7n - A8 - A83 - A83 PRO - A9 - A91 - A9x - F11 - F11 Pro - F15 - F5 - F5 Youth - F7 - F7 Youth - F9 - F9 Pro - R15 - Realme 1 - Realme 3 - Realme 3i - Realme C11 - Realme C12 - Realme C15 - Realme C2 - Reno 2f - Reno Lite |
#105 | ||||||||
UMTv2 / UMT Pro
UltimateMTK v3.7 Added: iVoomi - i2 Lite Lava - Z80 Namira - Titanic T-2 X-Age - G1 Yuho - O2 Pro Updated Oppo MTK Meta Format - Method 1 for all phones till January 2021 Patch (may work on later too) - Method 2 for all phones with UFS memory, if Method 1 failed Updated META Mode Operations |
#106 | ||||||||
UMTv2 / UMT Pro UltimateMTK v3.8
- Added Disable Auth to disable SLA/DAA - New!!! - Added Mi Account Reset - New!!! Added Support for following chipsets: - MT6757D - MT6758 - MT6759 - MT6768 - MT6771 - MT6779 - MT6785 - MT6799 - MT6873 - MT8167 - MT8695 Added: IRIS - Tab G7100 Infinix - Note 7 (X690) - S5 Pro (X660) Jivi - Xtreme 1 Micromax - Q4311 Oppo - A5s (CPH1909) - A11k (CPH2083) Vivo - Y19 (PD1934F) - Y81i Xiaomi - Note 8 Pro - Note 9 - Redmi 6A - Redmi 9A - Redmi 9 Prime Added Disable Auth (SLA/DAA) - Supported Chipsets: - MT6261 - MT6572 - MT6580 - MT6582 - MT6735 - MT6737 - MT6739 - MT6755 - MT6757 - MT6761 - MT6763 - MT6765 - MT6768 - MT6771 - MT6785 - MT6799 - MT6873 - MT8127 - MT8163 - MT8173 - MT8695 - It will disable SLA and DAA in BROM Mode - You can perform any operation after Disable Auth without disconnecting device - Need to install libusb filter driver (Available on support) Thanks for this exploit goes to: - bkerler - chaosmaster - Dinolek It was almost impossible to make it without them! Added Mi Account Reset for Xiaomi Devices Added Oppo MTK OFP Extracter Updated Internal Libraries to newer version |
Пользователь сказал cпасибо: | Ulugbek (28.02.2021) |
#107 | ||||||||
UMTv2 / UMTPro - UltimateMTK v3.9 - UFS Support , Oppo, Xiaomi and more...
- Added Disable Auth to disable SLA/DAA - New!!! - Added Mi Account Reset - New!!! Added: Infinix - S5 (X652A) Meizu -M3s Motorola - XT2025-3 Oppo - A15 (CPH2185) - A1K (CPH1923) - A3 (CPH1837) - A31 (CPH2015) - A83 (CPH1729) - A83 (CPH1827) - A9 (CPH1938) - A91 (CPH2001PU) - AX5s (CPH1912) - F11 (CPH1911) - F11 Pro (CPH1987) - F15 (CPH2001) - F17 Pro (CPH2119) - F5 (CPH1723) - F7 (CPH1819) - F7 Youth (CPH1859) - F9 (CPH1881) - F9 Pro (CPH1823) - F9 Pro (CPH1825) - R5 (CPH1835) - Realme 1 (CPH1861) - Realme 3 (RMX1821) - Realme C11 (RMX2185) - Realme C2 (RMX1941) - Realme C3 (RMX2020) - Reno 2F (CPH1989) - Reno 3 Pro 4G (CPH2035) Xiaomi - Mi Play - Redmi 6 Added Support for UFS Storage Devices Added Automatic Disable Auth - Software will Automatically do it for listed phones - If you use manual method, use "Use Disable Auth" checkbox on top to control behavior Added Connection Mode Help - Now log will show you, in which mode to connect device. Fixed Disable Auth for Xiaomi Note 8 Pro and some others Auto Install Driver Package / Filter Driver with Setup Installer |
Пользователь сказал cпасибо: | Ulugbek (06.03.2021) |
#108 | ||||||||
UMTv2/UMTPro QcFire v6.6 - LG G8, V50, Xiaomi Fix WIFI/Network and more...
Added Alcatel - Pop Up (OT-6044D) Huawei - Y6 Prime (ATU-L21) - Y6 Prime (ATU-L22) - Y6 Prime (ATU-LX3) - Y7 Pro 2018 (LDX-LX2) LG - G8 ThinQ - G8x - V50 ThinQ Oppo - R1x Vivo - Y12s (PD2060F) - Y71i (PD1731BF) Added One Click Fix WIFI / Network for Xiaomi phones: - Mi 5 (gemini) - Mi 9SE (grus) - Mi A3 (laurel (sprout) - Mi CC9 (pyxis) - Mi Mix3 (perseus) - Poco F1 (beryllium) - Redmi 7 (onclite) - Redmi 8A Dual (olivewood) - Redmi 8A (olivelite) - Redmi Note5Pro (whyred) - Redmi Note7Pro (violet) - Redmi Note8 (ginkgo) - Redmi Note9S (curtana) - Redmi Y2 (ysl) - Redmi Y3 (onc) Added Reset FRP confirmation on Reset Mi Account / Fix Wifi / Network function. Added QCN Patch Option on Restore QCN Added Diag Only Option for IMEI Repair - Ticking this will allow you to skip EDL mode operation Updated Format FS / Reset Locks (Vivo) Functions - If write is not allowed, it will try to use Alt. Write method instead - Please note that Reset Locks (Vivo) function may not work on latest firmware Enabled Manual Selction of Internal Loader - You can now choose loader from internal database if needed. - This option is restored due to demand of many users. Updated Internal Loader Database with many new Loaders. |
#109 | ||||||||
UMTv2 / UMTPro UltimateMTK v4.0 - Xiaomi IMEI Repair, NVRAM Format and more....
- Xiaomi IMEI Repair - New!!! - NVRAM/NVDATA Format - New!!! - META Reboot for SLA Enabled Devices - New!!! Added Infinix - Hot 9 (X655D) Micromax - Canvas 2 Plus Nokia - 2.3 (IRM) - 3.1 Plus Tecno - Spark 5 Pro (KD7h) - Spark 6 Air Vivo - Y1s - Y12s Xiaomi - Poco C3 - Poco M2 - Redmi 9 - Redmi 9C - Redmi 10X - Redmi 10X 4G - Redmi 10X Pro Added SLA Disable on META Functions - SLA will be disabled if "Use Disable Auth" is checked - Usefull for SLA Enabled devices like Xiaomi - You can change this behaviour by toggling "Use Disable Auth" checkbox Added Xiaomi IMEI Repair Method - You can repair IMEI if lost after flashing - This method is only to restore original IMEI from phone back label - Only IMEI2 can be repaired Added NVRAM/NVDATA Format - You can format NVRAM/NVDATA to repair baseband unkown issue on some phones - Make sure to backup NVRAM first before using this function Updated NVRAM Backup Function - Now it will create both NVRAM and NVDATA backup (nvr/nvd file) Updated NVRAM Restore Function - Now you can select NVRAM backup of any size, previously on 5MB size was supported - NVDATA restore is not added yet, as device will recreate it after restoring NVRAM Fixed Payload Not Found error for MT6779 CPU |
#110 | ||||||||
Ultimate NCK Huawei Module Update Released in Auto update - [02/04/2021]
Added: For NCK Products / UMT Products / Avengers Box Kirin980 Models: Huawei Honor Magic 2 - Vendor/Country/Model Repair - Demo Remove. Huawei Honor 20/Pro - Vendor/Country/Model Repair - Demo Remove. Huawei Honor V20 - Vendor/Country/Model Repair - Demo Remove. Huawei Mate 20/Pro/Premium - Vendor/Country/Model Repair - Demo Remove. Huawei Mate 20 RS Porsche Design - Vendor/Country/Model Repair - Demo Remove. Huawei Mate 20 X - Vendor/Country/Model Repair - Demo Remove. Huawei MediaPad M6 10.8 - Vendor/Country/Model Repair - Demo Remove. Huawei MediaPad M6 8.4 - Vendor/Country/Model Repair - Demo Remove. Huawei Nova 5 Pro - Vendor/Country/Model Repair - Demo Remove. Huawei Nova 5T/Premium - Vendor/Country/Model Repair - Demo Remove. Huawei P30/Pro/Premium - Vendor/Country/Model Repair - Demo Remove. Can Be serviced in software or hardware TP only. Fixed Bug in Qualcomm detection in manufacture mode. Kirin 659 bootloader code reading in TP fixed. This version does not need to be downloaded as it is already added in auto update from software. |
#111 | ||||||||
UMTv2_UMTPro_UltimateMTK_4.1
Added: Alcatel - 9022X ASUS - ZenFone Max Pro M1 Ellipsis - 8 HD Hisense - F20 - F31 Infinix - Hot S3x Lenovo - K5 Note (L38012) - K5 Play (L38011) - Yoga Tab 3 8.0 (YT3-850M) QMobile - Z8 Plus Vestel - Venus Z20 Vivo - Y91 - Y95 - V11 Pro - Z1 ZTE (Sideload Mode) - Z986DL - Z353VL - Z610DL - Z716BL - Z717VL - Z818L - Z819L - Z836BL - Z837VL - Z861BL - Z862VL ZUK - Edge (Z2151) |
Метки |
asus, download, edl, firmware, motorolla, nck, qualcomm, umt, zte, бесплатно, бокс, дастурлаш, донгл, код, программа, прошивка, скачать, текин, узбекистан |
Здесь присутствуют: 1 (пользователей: 0 , гостей: 1) | |
Опции темы | |
