Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > RIFF Box
RIFF Box Раздел поддержки программатора RIFF Box
Старый4 23.09.2018, 21:34   #1
Points: 8,247, Level: 61 Points: 8,247, Level: 61 Points: 8,247, Level: 61
Аватар для farhod4313
Поблагодарили 59 раз(а) в 37 сообщениях
Lightbulb RIFF : Успешные операции
samsung i8552 emmc isp yuli bilan boot tiklandi
Цитата:
[23.09.2018 16:26:08] [START OPERATION_ID = RESURRECT]
[23.09.2018 16:31:54] Open serial port...OK
[23.09.2018 16:31:54] Connecting to the RIFF Box...OK
[23.09.2018 16:31:54] Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.81
[23.09.2018 16:31:54] Selected Resurrector: [Samsung I8552 ISP V1.0.6438.13126, <RJ-45>, 1 Bit Bus Width (DAT0)]
[23.09.2018 16:31:54] Connecting to the SD/eMMC Card...OK
[23.09.2018 16:31:54] Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 393 KHz
[23.09.2018 16:31:54] Detected eMMC Chip, ID: 0x15/0x00 (K7XVMB), User Area Partition = 0x0001D2000000 Bytes (7.28 GB)
[23.09.2018 16:31:54] Selected Resurrection Data for the eMMC Chip with Capacity = 7,28 GB
[23.09.2018 16:31:54] Flashing the dead body...OK
[23.09.2018 16:31:54] Resurrection complete!
farhod4313 вне форума   Ответить с цитированием
gsmservice.uz (23.09.2018), Jasurchik (25.11.2018)
Старый4 22.11.2018, 19:21   #2
По умолчанию SAMSUNG S7562 EMMC _ISP ORQALI BOOT TIKLANDI
Цитата:
[22.11.2018 06:45:47] [START OPERATION_ID = RESURRECT]
[22.11.2018 06:49:46] Open serial port...OK
[22.11.2018 06:49:46] Connecting to the RIFF Box...OK
[22.11.2018 06:49:46] Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.82
[22.11.2018 06:49:46] Selected Resurrector: [Samsung S7562 ISP V1.0.6697.19717, <RJ-45>, 1 Bit Bus Width (DAT0)]
[22.11.2018 06:49:46] Connecting to the SD/eMMC Card...OK
[22.11.2018 06:49:46] Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 960 KHz
[22.11.2018 06:49:46] Detected eMMC Chip, ID: 0x15/0x00 (JJS00A), User Area Partition = 0x0000E9000000 Bytes (3.64 GB)
[22.11.2018 06:49:46] Selected Resurrection Data for the eMMC Chip with Capacity = 3,64 GB
[22.11.2018 06:49:46] Flashing the dead body...OK
[22.11.2018 06:49:46] Resurrection complete!
Тип файла: jpg IMG_20181122_094753.jpg (361.5 Кб, 0 просмотров)
Тип файла: jpg IMG_20181122_094803.jpg (453.3 Кб, 0 просмотров)
Тип файла: jpg IMG_20181122_095725.jpg (388.8 Кб, 0 просмотров)
gsmservice.uz (22.11.2018), Jasurchik (25.11.2018)
Старый4 24.11.2018, 18:26   #3
По умолчанию SAMSUNG N7100 EMMC KMVTU000LM-B503 ALMASHTI
SAMSUNG N7100 EMMC KMVTU000LM-B503 ALMASHTI SAMSUNG I9300 EMMC KMV3W000LM-B310/16GB
QUEILDI VA N7100 RIFF BOX ORQALI BOOT TIKLANDI OK
Цитата:
24.11.2018 06:28:06] [START OPERATION_ID = RESURRECT]
[24.11.2018 06:35:27] Open serial port...OK
[24.11.2018 06:35:27] Connecting to the RIFF Box...OK
[24.11.2018 06:35:27] Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.82
[24.11.2018 06:35:27] Selected Resurrector: [Samsung N7100 ISP V1.0.6474.43852, <RJ-45>, 1 Bit Bus Width (DAT0)]
[24.11.2018 06:35:27] Connecting to the SD/eMMC Card...OK
[24.11.2018 06:35:27] Set I/O Voltage reads as 3.08V, SD_CLK Frequency is 393 KHz
[24.11.2018 06:35:27] Detected eMMC Chip, ID: 0x15/0x00 (V3W00M), User Area Partition = 0x0003AB400000 Bytes (14.68 GB)
[24.11.2018 06:35:27] Selected Resurrection Data for the eMMC Chip with Capacity = 14,68 GB
[24.11.2018 06:35:27] Flashing the dead body...OK
[24.11.2018 06:35:27] Resurrection complete!
[24.11.2018 06:35:27] [FINISH OPERATION_ID = RESURRECT]
Тип файла: jpg photo_2018-11-24_12-06-42 (2).jpg (178.1 Кб, 0 просмотров)
Тип файла: jpg IMG_20181123_152440.jpg (364.3 Кб, 0 просмотров)
Тип файла: jpg photo_2018-11-24_12-06-40.jpg (158.6 Кб, 0 просмотров)
gsmservice.uz (24.11.2018), Jasurchik (25.11.2018), st_max (24.11.2018)
Старый4 20.01.2019, 17:33   #4
По умолчанию SAMSUNG I9192 EMMC BOOT TIKLANDI
SAMSUNG I9192 EMMC ALMASHTI VA RIFF BOX ORQALI BOOT TIKLANDI
Цитата:
[01.11.2019 12:48:08] [START OPERATION_ID = RESURRECT]
[01.11.2019 12:49:09] Open serial port...OK
[01.11.2019 12:49:09] Connecting to the RIFF Box...OK
[01.11.2019 12:49:09] Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.86
[01.11.2019 12:49:09] Selected Resurrector: [Samsung I9192 ISP V1.0.6437.62332, <RJ-45>, 1 Bit Bus Width (DAT0)]
[01.11.2019 12:49:09] Connecting to the SD/eMMC Card...OK
[01.11.2019 12:49:09] Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 960 KHz
[01.11.2019 12:49:09] Detected eMMC Chip, ID: 0x45/0x00 (SEM08G), User Area Partition = 0x0001D2000000 Bytes (7.28 GB)
[01.11.2019 12:49:09] Selected Resurrection Data for the eMMC Chip with Capacity = 7,28 GB
[01.11.2019 12:49:09] Flashing the dead body...OK
[01.11.2019 12:49:09] Resurrection complete!
Jasurchik (29.08.2019)
Старый4 29.08.2019, 06:15   #5
По умолчанию SAMSUNG G531H EMMC _ISP ORQALI BOOT TIKLANDI
SAMSUNG G531H RIFF BOX EMMC _ISP ORQALI BOOT TIKLANDI
Тип файла: jpg photo_2019-08-28_00-13-32.jpg (154.1 Кб, 0 просмотров)
Тип файла: jpg photo_2019-08-28_00-13-37.jpg (153.7 Кб, 0 просмотров)
Тип файла: jpg photo_2019-08-28_00-13-44.jpg (162.8 Кб, 0 просмотров)
Тип файла: jpg photo_2019-08-28_00-13-52.jpg (110.3 Кб, 0 просмотров)
Тип файла: jpg photo_2019-08-28_10-55-54.jpg (111.8 Кб, 0 просмотров)
BOTIR (29.08.2019), gsmservice.uz (29.08.2019), Jasurchik (29.08.2019)
Старый4 10.01.2020, 18:22   #6
По умолчанию Huawei Y5 II CUN-U29
Huawei Y5 II CUN-U29 emmc almashdi FN12MB va RIFF BOX olqali isp boot tiklandi
Firmware Version: 1.53 (RIFFBOX1), JTAG Manager Version: 1.87
Selected Resurrector: [Huawei Y5 II (CUN-U29) ISP V1.0.6736.44149, <RJ-45>, 1 Bit Bus Width (DAT0)]
Set I/O Voltage reads as 1.81V, SD_CLK Frequency is 960 KHz
Detected eMMC Chip, ID: 0x15/0x00 (FN12MB), User Area Partition = 0x0001D2000000 Bytes (7.28 GB)
Тип файла: jpg 1.jpg (205.9 Кб, 0 просмотров)
Тип файла: jpg 2.jpg (150.3 Кб, 0 просмотров)
Тип файла: jpg 3.jpg (128.6 Кб, 0 просмотров)
5 пользователя(ей) сказали cпасибо:
gsmservice.uz (10.01.2020), Nurziyod (10.01.2020), sherzodbek-123 (10.01.2020), Ulugbek (11.01.2020), Хасан (10.01.2020)
Старый4 30.01.2020, 18:27   #7
По умолчанию SAMSUNG G532F RIFF BOX EMMC ISP BOOT DONE
SAMSUNG G532F RIFF BOX EMMC ISP ORQALI BOOT TIKLANDI
Selected Package: [Samsung G532F XXU1ARB1 V1.02 by <legija>, <RJ-45>, 1 Bit Bus Width (DAT0)]
WARNING: Embedded I/O Voltage is overriden to 1.80V
Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 649 KHz
Detected eMMC Chip, ID: 0x90/0x4A (H8G4u ), User Area Partition = 0x0001D2000000 Bytes (7.28 GB)
Writting to the SD/MMC Card...OK
Package execution complete!
Тип файла: jpg photo_2020-01-30_15-27-10.jpg (138.9 Кб, 0 просмотров)
Тип файла: jpg photo_2020-01-30_15-27-20.jpg (162.1 Кб, 0 просмотров)
Тип файла: jpg photo_2020-01-30_15-27-28.jpg (150.3 Кб, 0 просмотров)
Тип файла: jpg photo_2020-01-30_15-27-36.jpg (139.0 Кб, 0 просмотров)
Тип файла: jpg photo_2020-01-30_15-27-48.jpg (111.0 Кб, 0 просмотров)
Тип файла: jpg photo_2020-01-30_15-27-54.jpg (82.3 Кб, 0 просмотров)
Старый4 07.02.2020, 18:09   #8
По умолчанию LG D686 MTK CPU
LG D686 MTK CPU RIFF BOX ORQALI BOOT TIKLANDI
Тип файла: jpg 1.jpg (151.6 Кб, 0 просмотров)
Тип файла: jpg 2.jpg (136.0 Кб, 0 просмотров)
Тип файла: jpg 4.jpg (141.5 Кб, 0 просмотров)
Тип файла: jpg 3.jpg (112.8 Кб, 0 просмотров)
Nurziyod (08.02.2020)
Текущее время: 08:30. Часовой пояс GMT +5.
