Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > NCK BOX, NCK Dongle
NCK BOX, NCK Dongle Форум поддержки программатора NCK Dongle
Старый4 29.12.2018, 17:56   #241
Поблагодарил(а): 7
Поблагодарили 3 раз(а) в 3 сообщениях
NCK Dongle v8.7 Discussion
NCK Dongle v8.7 Released
Huawei U Series
Netphone 501 Direct Unlock/Network Fix
Orange Phone
Orange Sydney Unlock Code Calculation
ZTE Android - Direct Unlock
Acqua Direct Unlock
R22 Direct Unlock
T22 Direct Unlock
V889D Direct Unlock
Orange Dublin Direct Unlock
P752V Direct Unlock
P735T Direct Unlock
Alcatel MTK
Added all New PIDs for:
OT-213
OT-214
OT-217
OT-720
BlackBerry PRDs Updated (100 NEW PRDS).
Download support area access software here:
Тип файла: zip support.zip (1.59 Мб, 6 просмотров)
Последний раз редактировалось casper2233; 29.12.2018 в 18:13.
casper2233 вне форума   Ответить с цитированием
akbar (31.12.2018)
Старый4 02.01.2019, 17:13   #242
Points: 72,564, Level: 100 Points: 72,564, Level: 100 Points: 72,564, Level: 100
Поблагодарил(а): 1,272
Поблагодарили 8,656 раз(а) в 2,905 сообщениях
Вес репутации: 51
По умолчанию NCK Dongle / NCK Pro Android MTK Module v2.5.9.7
NCK Dongle / NCK Pro Android MTK Module v2.5.9.7 Update Released - [01/01/2019]
- Enabled - USE DATABASE feature on sim unlock for all phones.
Now user can use Modem database (usually it come with factory firmwares) to sim unlock phone.
- Enabled - USE DATABASE feature to repair IMEI for all phones.
Now user can use Modem database (usually it come with factory firmwares) to repair imei.
This feature must work on all CPU, including MT6739 and other new CPU.
-- Read Only IMEI is not supported.
Added Phones:
Wiko Lenny 2 Plus - Backup & Restore NVRam in Meta Mode.Factory Reset in Meta Mode/Simunlock [Beta]/FRP/Write Firmware/Userdata Reset/Read Info/Backup & Restore Security.
Infinix_x606C - Backup & Restore NVRam in Meta Mode.Factory Reset in Meta Mode/Simunlock [Beta]/FRP/Write Firmware/Userdata Reset/Read Info/Backup & Restore Security.
Vestel Venus E3 - Backup & Restore NVRam in Meta Mode.Factory Reset in Meta Mode/Simunlock [Beta]/FRP/Write Firmware/Userdata Reset/Read Info/Backup & Restore Security.
Azumi IRO A55 QL - Backup & Restore NVRam in Meta Mode.Factory Reset in Meta Mode/Simunlock [Beta]/FRP/Write Firmware/Userdata Reset/Read Info/Backup & Restore Security.
Vivo Y83 - Backup & Restore NVRam in Meta Mode.Factory Reset in Meta Mode/Simunlock [Beta]/FRP/Write Firmware/Userdata Reset/Read Info/Backup & Restore Security.
Старый4 02.02.2019, 10:28   #243
Points: 236,383, Level: 100 Points: 236,383, Level: 100 Points: 236,383, Level: 100
Activity: 50.0% Activity: 50.0% Activity: 50.0%
Аватар для Shoxruzbek
Поблагодарил(а): 4,730
Поблагодарили 2,276 раз(а) в 829 сообщениях
Вес репутации: 25
Профессионализм За Активность Архивариус За 100 сообщений
По умолчанию NCK Dongle / NCK PRO Spreadtrum Module v0.7 Update Released - [01/02/2019]
1. Added Basic support for SC6531EFM
- Supported Repair IMEI
-- Factory Reset
--- Read & Write NVRam
---- Write PAC File.
2. Added 2 Methods to service Phones in DIAG Mode.
- Old Method allow only to:
-- Read info (SimLock)/Reset phone/Repair IMEI/BT/Wifi
- New Method allow also to:
-- Perform Direct unlock in diag mode.
--- Usually new method work on phones with android 5.1 and more new.
---- It work also on SC6531EFM, possible on other generic phones too.
3. Added support for Simlock types 2,3,5 and 6 in DIAG Mode.
- For this types will be displayed sim unlock code on read info, and new phones will allow direct unlock.
-- For other types will need Simlock backup and link to phone firmware.
3. Remade PAC files Writer.
-- Now it become more universal and stable.
--- Supported EMMC and NOR phones
---- NAND phones support will be added in incoming updates.
4. Added possibility to select custom backup directory.
5. Added custom loader for wiko sunny 3 in custom folder.
This loader can be used to remove phone FRP.
To perform sim unlock is recommended to use DIAG Mode.
Official Website:
Shoxruzbek вне форума   Ответить с цитированием
Старый4 19.02.2019, 14:21   #244
Вес репутации: 51
По умолчанию NCK Dongle / Pro Android MTK Module v2.5.9.8
NCK Dongle / Pro Android MTK Module v2.5.9.8 Update Released - [19/02/2019]
A3A PLUS - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5058A - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5058J - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5058I - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
A3A XL 4G - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5099Y - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5099U - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5099I - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5099D - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
OT-5099A - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
Tesla
Tesla 3.3 - Read Info/Remove FRP/Factory Reset/Read & Restore NVRAM/Flash Firmware.
Enabled full flash, Full Erase + Flash for phones with Helio CPU.
Improved format function on phones with Helio CPU
Added Flash only Preloader function (so called init Preloader).
Added backup modem database in Meta mode.
Please note, this function not work for all CPUs.
We tested on MT6750 and MT6755, possible will be others also supported.
Removed direct unlock without database for MT6739 Alcatel phones, now software will give error on direct unlock without loaded database.
XURSAND (19.02.2019), Хасан (19.02.2019)
Старый4 19.02.2019, 18:00   #245
Points: 571, Level: 11 Points: 571, Level: 11 Points: 571, Level: 11
Activity: 72.2% Activity: 72.2% Activity: 72.2%
Аватар для nevajno
Поблагодарили 16 раз(а) в 8 сообщениях
Файл для скачки
Тип файла: rar NckDongle_AndroidMTK_v2.5.9.8_Setup.part1.rar (70.00 Мб, 0 просмотров)
Тип файла: rar NckDongle_AndroidMTK_v2.5.9.8_Setup.part2.rar (55.56 Мб, 0 просмотров)
nevajno вне форума   Ответить с цитированием
ELYOR.PHONE (20.02.2019), Хасан (19.02.2019)
alcatel, dongle, download, frp, huawei, info, mtk, nck, quallcomm, samsung, spd, unlock, update, бесплатно, коды
Текущее время: 18:08. Часовой пояс GMT +5.
