Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Chimera Tool
Chimera Tool Форум поддержки Chimera Tool
Старый4 24.06.2020, 15:04   #61
Points: 136,292, Level: 100 Points: 136,292, Level: 100 Points: 136,292, Level: 100
Поблагодарил(а): 1,462
Поблагодарили 9,652 раз(а) в 3,464 сообщениях
По умолчанию Chimera Samsung: New Read Codes Online Method
Software version: 25.18.1333
Release date: 23 June 2020
Chimera Team keep up the hard work, here is our latest samsung changelog and some other information..
Added New Read Codes Online and Repair IMEI Method for Exynos Models (Root: NO, Knox: 0, BIT: ANY)
Galaxy A10e SM-A102N, SM-A102W, SM-A102U, SM-A102U1
Galaxy A10 SM-A105F, SM-A105FN, SM-A105G, SM-A105M, SM-A105N
Galaxy A20e SM-A202F, SM-A202K
Galaxy A20 SM-A205F, SM-A205FN, SM-A205G, SM-A205GN, SM-A205S, SM-A205U, SM-A205U1, SM-A205YN, SM-A205W
Galaxy A21s SM-A217F, SM-A217M
Galaxy A30 SM-A305F, SM-A305FN, SM-A305G, SM-A305GN, SM-A305GT, SM-A305N, SM-A305YN, SM-A3050, SM-A3058
Galaxy A30s SM-A307FN, SM-A307G, SM-A307GN, SM-A307GT
Galaxy A40 SM-A405F, SM-A405FN, SM-A405M, SM-A405S
Galaxy A50 SM-A505F, SM-A505FN, SM-A505FM, SM-A505G, SM-A505GN, SM-A505GT, SM-A505N, SM-A505U, SM-A505U1, SM-A505YN, SM-A505W
Galaxy A50s SM-A507FN, SM-A5070
Galaxy A51 2019 SM-A515F, SM-A515U, SM-A515U1, SM-A515W
Galaxy A51 5G SM-A516B, SM-A516N, SM-A5160
Galaxy A71 5G SM-A716B, SM-A716S, SM-A7160
Galaxy Xcover 4 SM-G398FN
Galaxy XCover Pro SM-G715FN, SM-G715U, SM-G715U1, SM-G715W
Galaxy Xcover FieldPro SM-G889A, SM-G889F, SM-G889G, SM-G889YB
Galaxy S10e SM-G970F, SM-G970N
Galaxy S10 SM-G973F, SM-G973N
Galaxy S10+ SM-G975F, SM-G975N
Galaxy S10 5G SM-G977B, SM-G977N
Galaxy S20 SM-G980F
Galaxy S20 5G SM-G981B
Galaxy S20+ SM-G985F
Galaxy S20+ 5G SM-G986B
Galaxy S20 Ultra 5G SM-G988B
Galaxy M10 SM-M105F, SM-M105G, SM-M105M, SM-M105Y
Galaxy M10s SM-M107F
Galaxy M20 SM-M205F, SM-M205FN, SM-M205G, SM-M205M, SM-M205N
Galaxy M21 SM-M215F
Galaxy M30 SM-M305F, SM-M305M
Galaxy M30s SM-M307F, SM-M307FN, SM-M3070
Galaxy M31 SM-M315F
Galaxy Note 10 Lite SM-N770F
Galaxy Note 10 SM-N970F
Galaxy Note 10 5G SM-N971N
Galaxy Note 10+ SM-N975F
Galaxy Note 10+ 5G SM-N976B, SM-N976N
Galaxy Tab A 8.0 2019 SM-P205
Galaxy Tab S6 Lite 10.4 SM-P615
Galaxy Tab S6 Lite 10.4 LTE SM-P617
Galaxy Tab A 8.4 2020 SM-T307U
Galaxy Tab A 10.1 2019 SM-T515, SM-T515N
Galaxy Tab A 10.1 2019 LTE SM-T517
Galaxy A20 SC-02M
Galaxy A30 SCV43
Galaxy A20e SCV46
Added New Read Codes Online, Repair IMEI and Read/Write Cert Method for Exynos Models (Root: NO, Knox: 0, BIT: ANY)
Galaxy A2 Core SM-A260F, SM-A260G
Galaxy A8 2018 SM-A530F, SM-A530N, SM-A530W
Galaxy A6 2018 SM-A600A, SM-A600AZ, SM-A600F, SM-A600FN, SM-A600G, SM-A600GN, SM-A600N, SM-A600U
Galaxy A8+ 2018 SM-A730F, SM-A730N
Galaxy A7 2018 SM-A750F, SM-A750FN, SM-A750G, SM-A750GN, SM-A750N
Galaxy Xcover 4 2017 SM-G390F, SM-G390W, SM-G390Y
Galaxy On7 Prime SM-G611F, SM-G611FF, SM-G611M, SM-G611MT, SM-G611K, SM-G611L, SM-G611S
Galaxy S8 SM-G950F, SM-G950N
Galaxy S8+ SM-G955F, SM-G955N
Galaxy S9 SM-G960F, SM-G960N
Galaxy S9+ SM-G965F, SM-G965N
Galaxy J2 Core 2018 SM-J260A, SM-J260AZ, SM-J260F, SM-J260G, SM-J260M, SM-J260Y
Galaxy J3 2017 SM-J330F, SM-J330FN, SM-J330G, SM-J330L, SM-J330N
Galaxy Sol3 SM-J336AZ
Galaxy J3 2018 SM-J337A, SM-J337AZ, SM-J337U, SM-J337VPP, SM-J337W
Galaxy J4 SM-J400F, SM-J400G, SM-J400M
Galaxy J5 2017 SM-J530F, SM-J530FM, SM-J530G, SM-J530GM, SM-J530K, SM-J530L, SM-J530S, SM-J530YM
Galaxy J6 SM-J600F, SM-J600FN, SM-J600G, SM-J600GF, SM-J600GT, SM-J600L, SM-J600N
Galaxy J7 Nxt 2017 SM-J701F, SM-J701M, SM-J701MT
Galaxy J7 2016 SM-J710F, SM-J710FQ, SM-J710GN, SM-J710MN
Galaxy J7 Duo SM-J720F, SM-J720M
Galaxy J7 Sky SM-J727A, SM-J727AZ, SM-J727S, SM-J727U
Galaxy J7 2017 SM-J730F, SM-J730FM, SM-J730G, SM-J730GM, SM-J730M, SM-J730K
Galaxy J7 2018 SM-J737A, SM-J737S, SM-J737U, SM-J737VPP
Galaxy Note 8 SM-N950F, SM-N950N
Galaxy Note 9 SM-N960F, SM-N960N
Galaxy Tab Active 2 SM-T395, SM-T395C, SM-T395N
Galaxy View 2 SM-T927A
Galaxy Feel 2 SC-02L
Galaxy Feel SC-04J
Nurziyod (25.06.2020)
Старый4 10.07.2020, 10:14   #62
По умолчанию CHIMERA Huawei: Factory Fastboot & Model/Vendor/Country without disassembling
HUAWEI
Software Brick: Load Factory Fastboot procedure now tries to put the device into factory mode without Test Point (without disassemble!)
Compatibility list: Kirin 980/710/970/960/etc..
Repair Boot*: as a result of software brick, after restart (hard reset) the phone remains bricked. Repair Boot can fix this but it needs factory fastboot loaded on the phone.
Model and Vendor/Country Change*: No need to Test Point, works on all phones, any CPU. Compatibility is not certain with latest firmware versions (without disassemble!).
Compatibility list: Kirin 990/810/980/710/970/960/etc.. (Kirin 990/810 devices, where older sw version available)
Please do not forget: both process able to use without Test Point & disassemble.
Huawei bugfixes:
USB Firmware Update bugfix when using version info override
* After Repair Boot and Model and Vendor/Country Change you MUST run USB Software Update or Repair Recovery (if available) on the device.
Старый4 21.07.2020, 22:30   #63
По умолчанию Samsung Update(21.July 2020)- Exynos Read Codes for the Latest Firmwares (TFx, TGx)
Software version: 25.46.0928
Release date: 21. July 2020
>> Added Read Codes for the latest firmwares of Exynos models (TFx, TGx) with the 01/06/2020 or newer Android security patch. First in the World! <<
The list of affected models:
Galaxy S20 SM-G980F
Galaxy M21 SM-M215F
Galaxy M31 SM-M315F
Galaxy A20 SC-02M
Galaxy A30 SCV43
Galaxy A20e SCV46
Galaxy Feel SC-04J
Старый4 23.07.2020, 18:06   #64
По умолчанию Chimera BiWeekly Update Summary - Fixes and Improvements
Software version: 25.48.1328
Release date: 23 July 2020
New features and improvements:
Samsung: improved Read Codes Online support for MTK models (A315x, A415F)
Bugfixes:
Huawei: phone detection fix in fastboot mode
Huawei: Model and Vendor/Country Change UI bugfix
Furious Box: Win10 issue bugfix
Chimera: certificate/SSL bugfix
Старый4 31.07.2020, 12:26   #65
По умолчанию Huawei update – Full Support for the Latest Huawei Kirin CPUs, All SW, No Test Point
Software version: 25.55.1946
Release date: 30 July 2020
Yes, our big Huawei update has finally arrived!
Compared to other’s Fastboot methods, we developed a “Deep Method” that allows us to support the latest, and all future Kirin CPUs, all software versions and without test point – so you don’t have to disassemble phones!
It means that now we fully support HiSilicon Kirin 710/810/820/980/985/990/990 5G, all software versions including EMUI 10.1 and Magic UI 3.1 for the following functions:
Network Factory Reset
FRP Remove
Huawei ID Reset
IMEI Repair
Cert Read/Write
Modify OEMINFO
Demo Remove
Set Battery Serial
We were focusing on supporting the latest phones but of course, we will keep adding support for previous-generation devices too.
Старый4 10.08.2020, 20:46   #66
10/08/2020 #32 BiWeekly Update Summary - Fixes and Improvements
LG: added new Repair MEID procedure for MTK models
LG: improved lock check (if not only simlock is available)
Huawei: improved backend processes
Huawei: smart function display/hide based on phone mode and security state
Bugfixes:
Oppo: now different XML formats handled in firmware files
LG: fixed Sprint device recognition for MTK models
Huawei: fixed flash management for Kirin 710 with EMMC
Huawei: improvements in Remove FRP and Huawei ID Reset functions
Chimera: no more date localisations in logs
chimera, download, forum, free, frp, huawei, module, network, samsung, unlock, update, бесплатно, обновления, скачать, узбекистан
Текущее время: 22:16. Часовой пояс GMT +5.
