Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Новости программаторов
Старый4 01.08.2020, 12:34   #21
Points: 134,973, Level: 100 Points: 134,973, Level: 100 Points: 134,973, Level: 100
Поблагодарил(а): 1,462
Поблагодарили 9,652 раз(а) в 3,464 сообщениях
По умолчанию GSMShield Qualcomm v1.8
- 5056I
LYF
- Water F1 (LS-5505)
YooMee
- L451E
Wiko
- Pulp 4G
- Rainbow Lite 4G
- View Prime
- View 2 Pro
- Wim
YU
- Yuphoria (YU5010A)
ZTE
- Blade A320
Added Vivo Format/FRP Method
- This method should ONLY be used on Vivo Secured Phones
- If normal method does not work, you can use this method
- You can select this method from Format Dropdown List
Added Diagnostic Mode Security Repair
- Simply tick Only DIAG Mode to skip EDL mode operations
- If it does not work, you must use normal method (EDL+DIAG)
Added Xiaomi RSA Protected IMEI Repair
- Should work on all RSA Protected Xiaomi Devices
- You must have working QCN, or Read from Device first
Fixed Issues with Open/Save File Dialogs
Internal Loaders Updated
Старый4 02.08.2020, 16:51   #22
По умолчанию GSM SHIELD BOX SPRD v1.3
GSM SHIELD BOX SPRD v1.3 Setup is out...
Itel
A55 (L6003P) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
A33 (W5001) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
P36 (W6501) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
P12 - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
A33 (W5001P) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
A46 (L5503L) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
P33 (W5504) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
S15 Pro(L6002P) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
S15 (W6002) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
A14 Max (W4003) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
P15 (W5005P) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
WIKO
Y80 (W-V720-EEA) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
View 3 (W-V800-EEA) - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
Micromax
N4120 - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
Q402+ - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
SA2S - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
SA7S - Write PAC Firmware/Reset FRP/Backup & Restore NVRam/Diag Mode Reset/Repair IMEI/Read Info etc...
Added in exe support for Read & Write 4 IMEIs
Changed custom loaders structure, new created loaders now will store and display info about supported phone.
Added security nv backup in diag mode, restore will be activated in next exe version.
Changed exe GUI
Added separate tabls for: Simlock, Repair IMEI, Generic Diag Operations.
Flashing PAC improvment for supported phones.
box, gsm, gsm shield box, shield, update
Текущее время: 13:56. Часовой пояс GMT +5.
