Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Chimera Tool
Chimera Tool Форум поддержки Chimera Tool
Закрытая тема
Старый4 24.06.2020, 15:04   #61
Points: 169,138, Level: 100 Points: 169,138, Level: 100 Points: 169,138, Level: 100
Поблагодарил(а): 1,482
Поблагодарили 9,860 раз(а) в 3,609 сообщениях
Вес репутации: 68
По умолчанию Chimera Samsung: New Read Codes Online Method
Software version: 25.18.1333
Release date: 23 June 2020
Chimera Team keep up the hard work, here is our latest samsung changelog and some other information..
Added New Read Codes Online and Repair IMEI Method for Exynos Models (Root: NO, Knox: 0, BIT: ANY)
Galaxy A10e SM-A102N, SM-A102W, SM-A102U, SM-A102U1
Galaxy A10 SM-A105F, SM-A105FN, SM-A105G, SM-A105M, SM-A105N
Galaxy A20e SM-A202F, SM-A202K
Galaxy A20 SM-A205F, SM-A205FN, SM-A205G, SM-A205GN, SM-A205S, SM-A205U, SM-A205U1, SM-A205YN, SM-A205W
Galaxy A21s SM-A217F, SM-A217M
Galaxy A30 SM-A305F, SM-A305FN, SM-A305G, SM-A305GN, SM-A305GT, SM-A305N, SM-A305YN, SM-A3050, SM-A3058
Galaxy A30s SM-A307FN, SM-A307G, SM-A307GN, SM-A307GT
Galaxy A40 SM-A405F, SM-A405FN, SM-A405M, SM-A405S
Galaxy A50 SM-A505F, SM-A505FN, SM-A505FM, SM-A505G, SM-A505GN, SM-A505GT, SM-A505N, SM-A505U, SM-A505U1, SM-A505YN, SM-A505W
Galaxy A50s SM-A507FN, SM-A5070
Galaxy A51 2019 SM-A515F, SM-A515U, SM-A515U1, SM-A515W
Galaxy A51 5G SM-A516B, SM-A516N, SM-A5160
Galaxy A71 5G SM-A716B, SM-A716S, SM-A7160
Galaxy Xcover 4 SM-G398FN
Galaxy XCover Pro SM-G715FN, SM-G715U, SM-G715U1, SM-G715W
Galaxy Xcover FieldPro SM-G889A, SM-G889F, SM-G889G, SM-G889YB
Galaxy S10e SM-G970F, SM-G970N
Galaxy S10 SM-G973F, SM-G973N
Galaxy S10+ SM-G975F, SM-G975N
Galaxy S10 5G SM-G977B, SM-G977N
Galaxy S20 SM-G980F
Galaxy S20 5G SM-G981B
Galaxy S20+ SM-G985F
Galaxy S20+ 5G SM-G986B
Galaxy S20 Ultra 5G SM-G988B
Galaxy M10 SM-M105F, SM-M105G, SM-M105M, SM-M105Y
Galaxy M10s SM-M107F
Galaxy M20 SM-M205F, SM-M205FN, SM-M205G, SM-M205M, SM-M205N
Galaxy M21 SM-M215F
Galaxy M30 SM-M305F, SM-M305M
Galaxy M30s SM-M307F, SM-M307FN, SM-M3070
Galaxy M31 SM-M315F
Galaxy Note 10 Lite SM-N770F
Galaxy Note 10 SM-N970F
Galaxy Note 10 5G SM-N971N
Galaxy Note 10+ SM-N975F
Galaxy Note 10+ 5G SM-N976B, SM-N976N
Galaxy Tab A 8.0 2019 SM-P205
Galaxy Tab S6 Lite 10.4 SM-P615
Galaxy Tab S6 Lite 10.4 LTE SM-P617
Galaxy Tab A 8.4 2020 SM-T307U
Galaxy Tab A 10.1 2019 SM-T515, SM-T515N
Galaxy Tab A 10.1 2019 LTE SM-T517
Galaxy A20 SC-02M
Galaxy A30 SCV43
Galaxy A20e SCV46
Added New Read Codes Online, Repair IMEI and Read/Write Cert Method for Exynos Models (Root: NO, Knox: 0, BIT: ANY)
Galaxy A2 Core SM-A260F, SM-A260G
Galaxy A8 2018 SM-A530F, SM-A530N, SM-A530W
Galaxy A6 2018 SM-A600A, SM-A600AZ, SM-A600F, SM-A600FN, SM-A600G, SM-A600GN, SM-A600N, SM-A600U
Galaxy A8+ 2018 SM-A730F, SM-A730N
Galaxy A7 2018 SM-A750F, SM-A750FN, SM-A750G, SM-A750GN, SM-A750N
Galaxy Xcover 4 2017 SM-G390F, SM-G390W, SM-G390Y
Galaxy On7 Prime SM-G611F, SM-G611FF, SM-G611M, SM-G611MT, SM-G611K, SM-G611L, SM-G611S
Galaxy S8 SM-G950F, SM-G950N
Galaxy S8+ SM-G955F, SM-G955N
Galaxy S9 SM-G960F, SM-G960N
Galaxy S9+ SM-G965F, SM-G965N
Galaxy J2 Core 2018 SM-J260A, SM-J260AZ, SM-J260F, SM-J260G, SM-J260M, SM-J260Y
Galaxy J3 2017 SM-J330F, SM-J330FN, SM-J330G, SM-J330L, SM-J330N
Galaxy Sol3 SM-J336AZ
Galaxy J3 2018 SM-J337A, SM-J337AZ, SM-J337U, SM-J337VPP, SM-J337W
Galaxy J4 SM-J400F, SM-J400G, SM-J400M
Galaxy J5 2017 SM-J530F, SM-J530FM, SM-J530G, SM-J530GM, SM-J530K, SM-J530L, SM-J530S, SM-J530YM
Galaxy J6 SM-J600F, SM-J600FN, SM-J600G, SM-J600GF, SM-J600GT, SM-J600L, SM-J600N
Galaxy J7 Nxt 2017 SM-J701F, SM-J701M, SM-J701MT
Galaxy J7 2016 SM-J710F, SM-J710FQ, SM-J710GN, SM-J710MN
Galaxy J7 Duo SM-J720F, SM-J720M
Galaxy J7 Sky SM-J727A, SM-J727AZ, SM-J727S, SM-J727U
Galaxy J7 2017 SM-J730F, SM-J730FM, SM-J730G, SM-J730GM, SM-J730M, SM-J730K
Galaxy J7 2018 SM-J737A, SM-J737S, SM-J737U, SM-J737VPP
Galaxy Note 8 SM-N950F, SM-N950N
Galaxy Note 9 SM-N960F, SM-N960N
Galaxy Tab Active 2 SM-T395, SM-T395C, SM-T395N
Galaxy View 2 SM-T927A
Galaxy Feel 2 SC-02L
Galaxy Feel SC-04J
gsmservice.uz вне форума
Nurziyod (25.06.2020)
Старый4 10.07.2020, 10:14   #62
Вес репутации: 68
По умолчанию CHIMERA Huawei: Factory Fastboot & Model/Vendor/Country without disassembling
HUAWEI
Software Brick: Load Factory Fastboot procedure now tries to put the device into factory mode without Test Point (without disassemble!)
Compatibility list: Kirin 980/710/970/960/etc..
Repair Boot*: as a result of software brick, after restart (hard reset) the phone remains bricked. Repair Boot can fix this but it needs factory fastboot loaded on the phone.
Model and Vendor/Country Change*: No need to Test Point, works on all phones, any CPU. Compatibility is not certain with latest firmware versions (without disassemble!).
Compatibility list: Kirin 990/810/980/710/970/960/etc.. (Kirin 990/810 devices, where older sw version available)
Please do not forget: both process able to use without Test Point & disassemble.
Huawei bugfixes:
USB Firmware Update bugfix when using version info override
* After Repair Boot and Model and Vendor/Country Change you MUST run USB Software Update or Repair Recovery (if available) on the device.
Старый4 21.07.2020, 22:30   #63
Вес репутации: 68
По умолчанию Samsung Update(21.July 2020)- Exynos Read Codes for the Latest Firmwares (TFx, TGx)
Software version: 25.46.0928
Release date: 21. July 2020
>> Added Read Codes for the latest firmwares of Exynos models (TFx, TGx) with the 01/06/2020 or newer Android security patch. First in the World! <<
The list of affected models:
Galaxy S20 SM-G980F
Galaxy M21 SM-M215F
Galaxy M31 SM-M315F
Galaxy A20 SC-02M
Galaxy A30 SCV43
Galaxy A20e SCV46
Galaxy Feel SC-04J
Старый4 23.07.2020, 18:06   #64
Вес репутации: 68
По умолчанию Chimera BiWeekly Update Summary - Fixes and Improvements
Software version: 25.48.1328
Release date: 23 July 2020
New features and improvements:
Samsung: improved Read Codes Online support for MTK models (A315x, A415F)
Bugfixes:
Huawei: phone detection fix in fastboot mode
Huawei: Model and Vendor/Country Change UI bugfix
Furious Box: Win10 issue bugfix
Chimera: certificate/SSL bugfix
Старый4 31.07.2020, 12:26   #65
Вес репутации: 68
По умолчанию Huawei update – Full Support for the Latest Huawei Kirin CPUs, All SW, No Test Point
Software version: 25.55.1946
Release date: 30 July 2020
Yes, our big Huawei update has finally arrived!
Compared to other’s Fastboot methods, we developed a “Deep Method” that allows us to support the latest, and all future Kirin CPUs, all software versions and without test point – so you don’t have to disassemble phones!
It means that now we fully support HiSilicon Kirin 710/810/820/980/985/990/990 5G, all software versions including EMUI 10.1 and Magic UI 3.1 for the following functions:
Network Factory Reset
FRP Remove
Huawei ID Reset
IMEI Repair
Cert Read/Write
Modify OEMINFO
Demo Remove
Set Battery Serial
We were focusing on supporting the latest phones but of course, we will keep adding support for previous-generation devices too.
Старый4 10.08.2020, 20:46   #66
Вес репутации: 68
10/08/2020 #32 BiWeekly Update Summary - Fixes and Improvements
LG: added new Repair MEID procedure for MTK models
LG: improved lock check (if not only simlock is available)
Huawei: improved backend processes
Huawei: smart function display/hide based on phone mode and security state
Bugfixes:
Oppo: now different XML formats handled in firmware files
LG: fixed Sprint device recognition for MTK models
Huawei: fixed flash management for Kirin 710 with EMMC
Huawei: improvements in Remove FRP and Huawei ID Reset functions
Chimera: no more date localisations in logs
Старый4 19.08.2020, 19:26   #67
Вес репутации: 68
По умолчанию #34 Chimera BiWeekly Update
Software version: 25.74.1754
Release date: 19 August 2020
Huawei: added PATCH partition restore to Exit Factory Mode procedure (Fastboot Mode)
Huawei: improved demo device recognition
Huawei: improved the process of entering Factory Mode
Huawei: better model name hints for Modify OEMINFO, Demo Remove and Model and Vendor Country Change procedures
Core: improved SSL error handling
Core: procedure dialog UI improvements
Core: new file formats supported in EF Extractor
Bugfixes:
Huawei: Write Cert procedure can be started from normal mode (via HDB protocol)
Huawei: phone detection bugfixes when entering USB Update Mode
Huawei: now the bootloader lock status is checked for procedure run validation
Старый4 04.09.2020, 16:54   #68
Вес репутации: 68
По умолчанию CHIMERA – #36 BiWeekly Update
CHIMERA – #36 BiWeekly Update Summary - Fixes and Improvements
Software version: 25.89.2237
Release date: 03 September 2020
Huawei: added new Enter Factory Mode procedure
Huawei: improved Exit Factory Mode functionality for phones with Factory Fastboot
Huawei: improved learning process for Load Factory Fastboot procedure; now we can suggest a better match for your phone
Huawei: the improved Enter Factory Mode is now implemented to all related procedures
Huawei: disabling 'Model and Vendor/Country Change' button when the FW version is not supported
Huawei: more accurate help in 'Switch to USB update mode' dialog
Huawei: Huawei ID Reset and FRP Remove together was moved to a new tab
Core: improved phone detection
Bugfixes:
Core: fixed a bug that could cause crash during model selection
Nurziyod (07.09.2020), Ulugbek (04.09.2020)
Старый4 17.09.2020, 10:30   #69
Вес репутации: 68
По умолчанию #38 BiWeekly Update Summary
#38 BiWeekly Update Summary - Fixes and Improvements
Software version: 26.03.1259
Release date: 16 September 2020
Qualcomm: now you can select specific partitions from firmware packs, to flash (same as Xiaomi fastboot mode flash)
LG: support new simlock type for LG MTK phones (k41s, k51s, k61s, etc.)
LG: Android 10 support
Huawei: added support for all Huawei HiSilicon 960/970 models for Network Factory Reset, Modify Oeminfo and Demo Remove (Factory Fastboot method)
Nurziyod (19.09.2020), Shoxruzbek (18.09.2020)
Старый4 28.09.2020, 18:53   #70
Вес репутации: 68
По умолчанию CHIMERA – FIW – Samsung Read Codes Online for the latest firmwares
Software version: 26.15.1040
Release date: 28 September 2020
Another FIRST IN THE WORLD Samsung Update!
The network repair (patch cert) is coming soon!
Added new Read Codes Online and Repair IMEI Method for Exynos Models (Root: REQUIRED, Knox: ANY, BIT: ANY)
Galaxy A21s SM-A217F, SM-A217M, SM-A217N
Galaxy A30 SM-A305F, SM-A305G, SM-A305GT, SM-A305N, SM-A305YN
Galaxy A40 SM-A405FN, SM-A405S
Galaxy A50 SM-A505F, SM-A505G, SM-A505N, SM-A505W, SM-A505YN
Galaxy A51 SM-A515F, SM-A515W
Galaxy Xcover 4s SM-G398FN
Galaxy Xcover Pro SM-G715FN, SM-G715W
Galaxy Xcover Field Pro SM-G889A, SM-G889F, SM-G889G, SM-G889YB
Galaxy S20 SM-G980F
Galaxy S20+ SM-G986B
Galaxy M31s SM-M317F
Galaxy Note10 Lite SM-N770F
Galaxy Note10 SM-N970F
Galaxy Note10 5G SM-N971N
Galaxy Note10+ SM-N975F
Galaxy Note10+ 5G SM-N976B, SM-N976N
Galaxy Galaxy Tab S6 Lite SM-P615, SM-P615C, SM-P615N, SM-P617
Galaxy Galaxy Tab A 10.1 SM-T515, SM-T515N, SM-T517
Galaxy Galaxy Tab Active3 SM-T575
Galaxy A20 Docomo SC-02M
Galaxy A30 SCV43
Galaxy A30 SCV46
Added new Read Codes Online, Repair IMEI and Read/Write Cert Method for Exynos Models (Root: REQUIRED, Knox: ANY, BIT: ANY)
Galaxy A5 SM-A520F
Galaxy A8 SM-A530F
Galaxy A6 SM-A600A, SM-A600AZ, SM-A600F, SM-A600FN, SM-A600G, SM-A600GN, SM-A600N, SM-A600T, SM-A600T1, SM-A600U
Galaxy A7 SM-A720F
Galaxy A7 SM-A750FN, SM-A750GN, SM-A750N
Galaxy S7 SM-G930F, SM-G930K, SM-G930L, SM-G930S, SM-G930W8
Galaxy S7 edge SM-G935F, SM-G935K, SM-G935L, SM-G935S, SM-G935W8
Galaxy J2 Core SM-J260A, SM-J260AZ, SM-J260F, SM-J260G, SM-J260M, SM-J260T1, SM-J260Y
Galaxy J3 SM-J336AZ, SM-J337A, SM-J337AZ, SM-J337T, SM-J337U, SM-J337VPP, SM-J337W
Galaxy J6 SM-J600F, SM-J600G, SM-J600GF, SM-J600GT, SM-J600L, SM-J600N
Galaxy J7 Pro SM-J730FM, SM-J730G, SM-J730GM, J730K
Galaxy J7 2018 SM-J737A, SM-J737S, SM-J737T, SM-J737T1, SM-J737U, SM-J737VPP
Galaxy Note7 SM-N930F, SM-N930K, SM-N930L, SM-N930S
Galaxy Note FE SM-N935F, SM-N935K, SM-N935L, SM-N935S
Galaxy Note8 SM-N950F, SM-N950N
Galaxy Note9 SM-N960F, SM-N960N
Galaxy View2 SM-T927A
Galaxy Galaxy Feel2 SC-02L
Старый4 15.10.2020, 17:15   #71
Вес репутации: 68
По умолчанию Chimera #42 BiWeekly Update Summary - Samsung FIW, Fixes and Improvements
Software version: 26.32.0936
Release date: 15 October 2020
First in the World Samsung
Added Read Codes Online for Exynos N20 models (sm-n980f, sm-n981b, sm-n985f, sm-n986b) (Root: Yes)
Samsung: improved Carrier Relock for the lasest firmwares (affected carrier IDs: T-Mobile (TMB, TMK), Verizon (VZW))
Samsung: improved CSC change for the latest firmwares
Samsung: improved Read Codes Online for new security Qualcomm models
Huawei: improved server communication stability
Qualcomm: improved CPU type detection and automatic loader recommendation
Bugfixes:
Huawei: procedure bugfixes for older phones (FRP Remove, Network Factory Reset)
Core: crash fix during application startup related to older VGA drivers
Core: fixed a licensing error
Старый4 20.10.2020, 11:13   #72
Вес репутации: 68
Chimera Samsung Patch Cert for latest Exynos models and firmwares
Software version: 26.36.1122
Release date: 19 October 2020
Added Network Repair/Patch Cert for Samsung Exynos Models (Root: YES, Knox: ANY, BIT: ANY)
Galaxy M10 SM-A105F, SM-A105FN, SM-A105G, SM-A105M, SM-A105N
Galaxy A5 SM-A520F
Galaxy A8 SM-A530F
Galaxy A71 SM-A716B, SM-A716S, SM-A7160
Galaxy A7 SM-A720F
Galaxy A7 2018 SM-A750FN, SM-A750GN, SM-A750N
Galaxy S7 Edge SM-G935F, SM-G935K, SM-G935L, SM-G935S, SM-G935W8
Galaxy S20 SM-G980F
Galaxy J2 SM-J260A, SM-J260AZ, SM-J260F, SM-J260G, SM-J260M, SM-J260T1, SM-J260Y
Galaxy Sol 3 SM-J336AZ, SM-J337A, SM-J337AZ, SM-J337T, SM-J337U, SM-J337VPP, SM-J337W
Galaxy J7 2017 SM-J730FM, SM-J730G, SM-J730GM, J730K
Galaxy Note 7 SM-N930F, SM-N930K, SM-N930L, SM-N930S
Galaxy Note 20 SM-N980F
Galaxy Note 20 5G SM-N981B
Galaxy Note 20 Ultra SM-N985F
Galaxy Note 20 Ultra 5G SM-N986B
Galaxy Tab Active 3 SM-T575
Galaxy A20 SC-02M
Galaxy A30 SCV43
Galaxy A20 SCV46
ilhom-uz (20.10.2020), Ulugbek (20.10.2020)
Старый4 30.10.2020, 12:18   #73
Вес репутации: 68
По умолчанию CHIMERA – #44 BiWeekly Update
CHIMERA – #44 BiWeekly Update Summary - Fixes and Improvements
Software version: 26.46.1149
Release date: 29 October 2020
Free Network Factory Reset for Huawei
Huawei: the Network Factory Reset procedure is now free, it doesn't cost any credits!
Samsung: First in the World: Added Read Codes Online, Repair IMEI, Patch Cert/Network Repair for Samsung Galaxy S20 Fan Edition (SM-G780F)
Core: updated ChimeraSU (root via Magisk) used in Samsung Firmware Update with Autoroot option, LG's Root and Generic MTK's Root procedures
Core: credit prices are shown for each paid procedures before you start them (there are some exceptions in LG module)
Huawei: added support for newer EasyFirmware (*.EF_*) file type for Enter Factory Mode (in the panel where it asks for a firmware file)
Huawei: more informative error messages in Model and Vendor/Country change procedure
Generic Qualcomm: more informative error reporting
LG: improved Network Factory Reset function for MTK devices
Bugfixes:
Huawei: fixed Network Factory Reset procedure for older SoC types (659, 658, etc.)
Samsung: various bugfixes for the new Patch Cert procedure
LG: fixed character-coding issue during flashing
Core: various bugfixes for popup dialogs during procedure execution
Ulugbek (31.10.2020)
Старый4 12.11.2020, 22:42   #74
Вес репутации: 68
По умолчанию CHIMERA – #46 BiWeekly
CHIMERA – #46 BiWeekly Update Summary - Fixes and Improvements
Software version: 26.59.1533
Release date: 12 November 2020
Qualcomm: generic root solution for EDL mode (only for OEM/bootloader unlocked phones)
Samsung: EF file format support for Firmware Update and Firmware Compatibility
Samsung: automatic reboot of SAR (system-as-root) models for Patch Cert, when root is not available
Vivo: better error handling for the IMEI write procedure
Core: better error reporting for force terminated threads
Bugfixes:
BlackBerry: fixed a bug in Network Factory Reset and Repair Modem procedures for OS10 phones
Nurziyod (13.11.2020)
Старый4 14.01.2021, 19:21   #75
Вес репутации: 68
По умолчанию CHIMERA – #2 BiWeekly Update Summary - Fixes and Improvements
Software version: 27.22.1223
Release date: 13 January 2021
Fixes and Improvements:
Huawei: improved connection stability for procedures which require server side authentication
Huawei: factory fastboots are ordered by their success rate, and the most likely working ones are flagged
Qualcomm: more straightforward instructions for changing to EDL mode
Qualcomm: improved information reporting from Qualcomm procedures, for better loader suggestions
Qualcomm: brand selector dialog opens up only if we cannot determine the phone's manufacturer (during procedure execution on Qualcomm phones)
Motorola: new Info procedure for fastboot mode
Motorola: new Brick Repair procedure (available in EDL mode) to fix boot loops or other critical issues
Motorola: added detailed logging during Update Firmware procedure
Motorola: fixed a bug that could occur during Update Firmware procedure
Core: refactored database handling for local database --> less error prone and faster
Core: additional information can be shown to the user in case of application crash
Core: links in notifications can be opened
Ulugbek (15.01.2021)
Старый4 28.01.2021, 17:28   #76
Вес репутации: 68
По умолчанию #CHIMERA – #4 BiWeekly Update Summary - Fixes and Improvements
Software version: 27.37.0813
Release date: 28 January 2021
Samsung: Added new Read Codes Online and Read Cert method for the following models (ROOT: NO, KNOX: 0)
• Galaxy Xcover 4 (G390F, G390W, G390Y)
• Galaxy J2 (J260A, J260AZ, J260F, J260G, J260M, J260Y)
• Galaxy J3 (J330F, J330FN, J330G, J330L, J330N)
• Galaxy J3 Sol (J326AZ, J327A, J327AZ)
• Galaxy J4 (J400F, J400G, J400M)
• Huawei: improved connection stability for procedures which require server side authentication
• Motorola: added additional software information on Update Firmware panel
• Motorola: recognised Motorola models automatically added to our Supported Models
• Motorola: improved error messages in case of firmware incompatibility
• Motorola: increased USB timeout values for Fastboot communication that improves the stability of Update Firmware (fastboto mode) procedures
• Motorola: added support for blankflash files in Boot Repair procedure
• Core: improved logging for application crashes
Bugfixes:
• Huawei: fixed a bug on Write Cert panel, so the procedure cannot be started without providing at least one certificate file
• Core: fixed race-condition error during application restart, after software updates
• Core: local database access bugfixes
Старый4 11.02.2021, 18:19   #77
Вес репутации: 68
По умолчанию CHIMERA #6 BiWeekly
Chimera is your all-in-one service tool that supports thousands of phone models, for all service functions, without any hardware or box.
Happy Chinese New Year 2021 – 新年快乐
Celebrating Chinese New Year, we have a gift to all our users:
Now all Huawei Procedures are FREE on all supported CPUs (Kirin 710/810/820/980/985/990/990 5G), no credit needed!
Demo Remove: FREE
Remove FRP Lock: FREE
Read/Write Cert: FREE
Model and Vendor/Country Change: FREE
Modify Oeminfo: FREE
Network Factory Reset: FREE
Huawei: added support for OTA firmware packages in USB Firmware Update porcedure
Core: improved overall application stability
Core: more informative error messages
Bugfixes:
Huawei: fixed a bug for Hisi 658 SOC type phones that could occur during Factory Fastboot type procedures
Xiaomi: fixed an EDL mode communication bug for phones with EMMC flash chip
By from official reseller - gsmservice.uz
Старый4 26.02.2021, 11:30   #78
Вес репутации: 68
По умолчанию CHIMERA ⭐️ #8 BiWeekly Update
CHIMERA ⭐️ #8 BiWeekly Update - Fixes and Improvements ⭐️
Chimera is your all-in-one service software that supports thousands of phone models, for all service functions, without any hardware or box.
Samsung: added new Read Codes Online and Read Cert procedures for some Exynos models (only shows for supported models with supported modems, ROOT: NO, KNOX: YES)
Huawei: removed a couple security restrictions for Factory Mode procedures
Huawei: more informative messages on dialogs during procedure execution
Core: more precise remaining time calculation in download manager
Bugfixes:
Huawei: fixed a bug that could occur when using user provided firmware files for soft bricking
Core: various fixes to improve application stability
Старый4 12.03.2021, 11:09   #79
Вес репутации: 68
По умолчанию CHIMERA #10 BiWeekly
⭐️ CHIMERA ⭐️ #10 BiWeekly - BiWeekly Update Summary - Fixes and Improvements ⭐️
Improvements and bugfixes:
Core: improved user analytics
Core: smaller executable size due to refactoring of resource usage
Generic Qualcomm and Motorola: improved overall stability
Motorola: various bugfixes and improvements in Motorola's Repair Boot procedure
Huawei changes:
Demo Remove procedure is merged with Modify Oeminfo from now
Modify Oeminfo is also available in Fastboot mode
Modify Oeminfo is extended with Convert to Dual SIM and Disable FW compatibility* features
The phone automatically reboots into USB update mode after a successful Modify Oeminfo procedure (to ease the usage of USB Firmware Update procedure)
Restore SIM State** procedure is added
Samsung changes:
improved functionality of CSC Change procedure for the latest firmwares
* By using this checkbox the phone should accept all firmware versions during USB Firmware Update procedure. It doesn't generally mean that it allows version downgrade, because the phone can have different checks against that. It is usually used to let the phone accept a different model's firmware after a model name change.
** The Modify Oeminfo's Convert to Dual SIM feature creates a backup of the phone's original SIM state value, before it does the modification. The backup can be restored with this procedure.
Старый4 01.04.2021, 11:48   #80
Вес репутации: 68
По умолчанию Mega MTK Update
31/03/2021 Mega MTK Update
We are happy to announce the update of our MTK module!
With our latest update, we added support for the following SoC types:
MT6739
MT6757 (Helio P20)
MT6761 (Helio A22)
MT6763 (Helio P23)
MT6765 (Helio P35)
MT6768 (Helio P65)
MT6771 (Helio P60)
MT6779 (Helio P90)
MT6785 (Helio G90)
MT6873 (Dimensity 800)
MT6885 (Dimensity 1000L)
It covers over 300 models, many Samsung, Huawei, Xiaomi, Oppo, VIVO, LG, Motorola, Nokia, ZTE, Realme, Infinix, Ulefone, etc. devices. You can check the full list on our website. Please note, our update adds support for MediaTek chipsets in general and we will keep adding brand specific solutions continuously!
Depending on each device’s custom configuration, the following Chimera features are fully (or partially) supported on these models:
Write IMEI
Erase FRP
Bootloader Unlock/Relock
Backup/Restore Phone
Root
Screen Lock Remove
Закрытая тема
chimera, download, forum, free, frp, huawei, module, network, samsung, unlock, update, бесплатно, обновления, скачать, узбекистан
Текущее время: 07:32. Часовой пояс GMT +5.
