Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > NCK Box, NCK Dongle
NCK Box, NCK Dongle Форум поддержки программатора NCK Dongle
Старый4 28.02.2020, 15:14   #261
Points: 122,441, Level: 100 Points: 122,441, Level: 100 Points: 122,441, Level: 100
Поблагодарил(а): 1,457
Поблагодарили 9,580 раз(а) в 3,419 сообщениях
По умолчанию NCK Dongle / Pro Android MTK Module v2.67
NCK Dongle / Pro Android MTK Module v2.67 Update Released - 28/02/2020
KC8 - Read Info/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Repair IMEI/Flashing.
Camon 12 - Read Info/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Repair IMEI/Flashing.
CC7 - Read Info/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Repair IMEI/Flashing.
OT-9027w - SIMUNLOCK old and new method in flash mode.
OT-4034L - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-4034T - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-8077 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-8082 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-8182 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-8068 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-8167 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-8069 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-5026 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
OT-9026 - Read Info//SimLock/FRP/Factory reset (flash & meta mode)/Backup & Restore NVRam (flash & meta mode)/Flashing.
Added Read firmware by custom selection (Button is located in read firmware tab.)
-- User can read flash by address or read flash by partition name(need to load scatter for this)
--- Partitions will be saved at full size and user can select at once multiple partitions to read.
Added additional selection in format custom menu
-- User can now select format by address or format by name partition.
-- Some new phones does not allow format by address but allow by name.
Fixed and remaked reset frp function.
Now by selecting frp + wipe userdata must be fixed "dl image fail" error also.
Fixed booting for Helio phones, now stuck on "switching to Helio API" was fixed.
Software was uploaded to latest 7.1945 version of dll (must support latest cpu, even if not listed in autodetect mode).
Fixed unlock for OT-5059 phones in flash mode (was broken).
Старый4 07.03.2020, 17:22   #262
По умолчанию NCK Dongle / NCK Pro Dongle Android MTK Module v2.6.8
NCK Dongle / NCK Pro Dongle Android MTK Module v2.6.8 Update Released - 07/03/2020
RA6 - Direct unlock By Meta Mode (does not need database anymore).
Other functions is supported
Hisence
F16 - Direct unlock By Meta Mode/Flash Mode (does not need database anymore).
WIKO
Wiko Y60(W-K510) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write Firmware/FRP/Factory Reset/Sim unlock.
Wiko View GO(W_P130) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write Firmware/FRP/Factory Reset/Sim unlock.
Wiko View Max(W_P200) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write Firmware/FRP/Factory Reset/Sim unlock.
LB7 (Pouvoir 3) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write Firmware/FRP/Factory Reset/Sim unlock.
LC6 (Pouvoir 3 Air) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write Firmware/FRP/Factory Reset/Sim unlock.
LB8 (Pouvoir 3 Plus) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write Firmware/FRP/Factory Reset/Sim unlock.
Added Sim Unlock in Meta Mode for supported by exe helio phones.
This function is universal and must support many models from market.
Does Not support models with FUSED NVRAM, Disabled Meta from firmware, custom or modified by vendor simlock.
Ulugbek (11.03.2020)
Старый4 12.05.2020, 13:12   #263
По умолчанию NCK Dongle / NCK Pro Qualcomm Module v0.12.7
NCK Dongle / NCK Pro Qualcomm Module v0.12.7 Update Released - [12/05/2020]
HUAWEI
Huawei Nova (CAN-AL10) - Boot info, factory reset, frp in edl mode.
Huawei Nova (CAN-TL10) - Boot info, factory reset, frp in edl mode.
Huawei Nova (CAN-L01) - Boot info, factory reset, frp in edl mode.
Huawei Nova (CAN-L02) - Boot info, factory reset, frp in edl mode.
Huawei Nova (CAN-L03) - Boot info, factory reset, frp in edl mode.
Honor 6A Pro (DLI-AL10) - Boot info, factory reset, frp in edl mode.
Honor 6A Pro (DLI-L22) - Boot info, factory reset, frp in edl mode.
Honor 6A Pro (DLI-L42) - Boot info, factory reset, frp in edl mode.
Honor 6A Pro (DLI-TL10) - Boot info, factory reset, frp in edl mode.
Honor 6A Pro (DLI-TL20) - Boot info, factory reset, frp in edl mode.
Enjoy 6s 2017 (DIG-AL00) - Boot info, factory reset, frp in edl mode.
Honor 6c (DIG-L01) - Boot info, factory reset, frp in edl mode.
P9 Lite Smart (DIG-L03) - Boot info, factory reset, frp in edl mode.
Nova Smart DS (DIG-L21) - Boot info, factory reset, frp in edl mode.
Honor 6c (DIG-L21HN) - Boot info, factory reset, frp in edl mode.
P9 Lite Smart (DIG-L23) - Boot info, factory reset, frp in edl mode.
Enjoy 6s 2017 (DIG-TL10) - Boot info, factory reset, frp in edl mode.
Nova Plus (MLA-AL10) - Boot info, factory reset, frp in edl mode.
Nova Plus (MLA-L01) - Boot info, factory reset, frp in edl mode.
Nova Plus (MLA-L02) - Boot info, factory reset, frp in edl mode.
Nova Plus (MLA-L03) - Boot info, factory reset, frp in edl mode.
Nova Plus (MLA-L11) - Boot info, factory reset, frp in edl mode.
Nova Plus (MLA-L12) - Boot info, factory reset, frp in edl mode.
Nova Plus (MLA-L13) - Boot info, factory reset, frp in edl mode.
G9 Plus (MLA-TL10) - Boot info, factory reset, frp in edl mode.
G9 Plus (MLA-TL00) - Boot info, factory reset, frp in edl mode.
G9 Plus (MLA-UL00) - Boot info, factory reset, frp in edl mode.
Honor T3 (AGS-W09) - Boot info, factory reset, frp in edl mode.
MediaPad T3 10 (AGS-L03) - Boot info, factory reset, frp in edl mode.
MediaPad T3 10 (AGS-L09) - Boot info, factory reset, frp in edl mode.
Enjoy 8e (ATU-AL10) - Boot info, factory reset, frp in edl mode.
Y6 2018 (ATU-AL20B) - Boot info, factory reset, frp in edl mode.
Honor 7A 2018 (AUM-AL20) - Boot info, factory reset, frp in edl mode.
Honor 7C (AUM-L41) - Boot info, factory reset, frp in edl mode.
Y6 2018 (ATU-L11) - Boot info, factory reset, frp in edl mode.
Y6 2018 (ATU-L21) - Boot info, factory reset, frp in edl mode.
Y6 2018 (ATU-L22) - Boot info, factory reset, frp in edl mode.
Y6 2018 (ATU-LX3) - Boot info, factory reset, frp in edl mode.
Y6 Prime 2018 (ATU-L31) - Boot info, factory reset, frp in edl mode.
Y6 Prime 2018 (ATU-L42) - Boot info, factory reset, frp in edl mode.
For some phones will need TESTPOINT to force EDL mode.
You do not need to select model from list, Software must Auto Detect model.
Ulugbek (12.05.2020)
Старый4 27.05.2020, 15:31   #264
По умолчанию NCK Dongle / Pro Android MTK v2.6.9
NCK Dongle / Pro Android MTK v2.6.9 Update Released - [27/05/2020]
B1F (Pop 2F) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write firmware/FRP/Factory Reset/Write Firmware/Sim Unlock.
BB2 (Pop 3) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write firmware/FRP/Factory Reset/Write Firmware/Sim Unlock.
AB7 (Phantom 9) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write firmware/FRP/Factory Reset/Write Firmware/Sim Unlock.
ID5A (Camon I2) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write firmware/FRP/Factory Reset/Write Firmware/Sim Unlock.
ID5B (Camon I 2X) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write firmware/FRP/Factory Reset/Write Firmware/Sim Unlock.
CC6 (Camon 12 Air) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write firmware/FRP/Factory Reset/Write Firmware/Sim Unlock.
CC9 (Camon 12 Pro) - Read info/Repair IMEI/Backup & Restore NVRAM/Read & Write security backup/Read & Write firmware/FRP/Factory Reset/Write Firmware/Sim Unlock.
NOKIA
Nokia 2.2
Nokia 2.3
Improved FRP reset, backup restore security.
Sim unlock is not supported yet, if somebody have locked phone, please contact us.
Fixed MT6761 security and firmware reading bug.
Fixed OT-9009G booting(added missing flash id to database)
Improved old cpu flashing, on flashing firmware without preloader, exe will try to perform flash initialization from database.
Improved meta mode IMEI repair function for Helio phones(now exists 3 ways to repair IMEI).
In installation directory (usb_driver) is included new MTK drivers.
If exists problem with booting or flashing phones under windows 10, please replace MTK drivers.
alcatel, dongle, download, frp, huawei, info, mtk, nck, quallcomm, samsung, spd, unlock, update, бесплатно, коды
Текущее время: 06:11. Часовой пояс GMT +5.
