Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > UFI (Universal Flashing Interface )
UFI (Universal Flashing Interface ) Форум поддержки программатора UFI
Старый4 16.10.2018, 00:01   #1
Points: 107,371, Level: 100 Points: 107,371, Level: 100 Points: 107,371, Level: 100
Аватар для Usmonov Rustam
Поблагодарил(а): 490
Поблагодарили 807 раз(а) в 314 сообщениях
Вес репутации: 27
Arrow Обновление UFi Box
UFI Software version 1.2.0.419
Support changes:
ADD: Over 5.4TB compressed files uploaded to the support servers
ADD: Revised support files core system
ADD: Revised built-in download manager with resume and queue support
ADD: Download limitation on each users(10 GiB or 20 files a day)
eMMC ToolBox changes:
ADD: Verify for User Partition
Used to verify data from the specific partition of eMMC againts data from file
ADD: Sector 0 verify for NAND Test function
BUGFIX: PIT file handling bug fixed on Factory image tab
BUGFIX: Workaround for FFU causing eMMC dead to moviNAND with VHX0 controller(KMVTU)
BUGFIX: Minor bugfixes and improvements
Android ToolBox changes:
ADD: Disable MI Cloud Services
This function will patch firmware version 8.0 and below(on the fly) while flashing
Works on both Qualcomm and MediaTek platform
BUGFIX: UFI Box and UFI Dongle can now work simultaneously
[MediaTek tab]
ADD: Meizu SLA Auth support
Meizu Mediatek Devices will work just like other Mediatek Devices in general(requires internet connection)
ADD: Automated [Coolpad] Exit Factory Mode on firehose flashing procedure
[Qualcomm tab]
ADD: Support for Official LGE TOT Firmware extraction
ADD: Automated General CDT handling for Other Qualcomm devices(Lenovo) on firehose flashing procedure
BUGFIX: Oppo Qualcomm OFP extraction bug fixed
BUGFIX: Revised DA handling for MT6750,MT6755(Helio P10),MT6757(Helio P20),MT6795(Helio X10),MT6797(Helio X20)
BUGFIX: Revised [Oppo] Exit Fastboot Mode, now it should works on any known firmware variants
UFI Software Version 1.2.0.447
General changes:
Introducing UFIBox firmware version 1.12 (CHIP prog bugfix)
Introducing [USB] Device Manager toolbox menu
Fixed virtualization bug in Windows 10 Build 16299
Support changes:
Over 6.8TB compressed files uploaded to the support servers
intenal download manager improvements
ADD: Option to resize filesystem when resizing userdata
Use this on "non-empty" userdata, It will resize filesystem on-the-fly according to userdata partition size without losing users data
ADD: Spreadtrum support on factory image tab
Input file is "BMAConfig" file (SCXXXX.xml), can be found on the extracted pac file
BUGFIX: EXT_CSD with repartitioning write bug fixed
ADD: Spreadtrum flashing and imei repair support
Spreadtrum device with eMMC storage is now supported for flashing, partial read, erase and write from the flash tab
Introduced in special task menu:
Factory reset, Backup and Restore NV, Clear FRP Lock
Identify or flashing spreadtrum devices requires "BMAConfig", fdl1 and fdl2 files which is part of the official firmware package(PAC, P5C or CPB file)
ADD: Extract support for CPB file version 2.0, 2.1
ADD: Revised Xiaomi Reset Mi Account Lock task
Mostly support all Xiaomi devices on the market including MiUI 9 with Android 7.2 or later
Reset Mi Account Lock task will disable secure system service so Mi Cloud service will be completely disabled after operation
Restoring firmware via flashing or OTA will re-enable the system service so device will be re-locked when internet connection enabled
ADD: Oppo secure imei repair support
Newer oppo devices come with secure(signed) imei
Currently supported device for now: Oppo A71
Before write imei, you have to patch secure imei from the flash tab, Special Task menu
ADD: Added latest BROM version 7.1817.3.0 for latest MediaTek chipset(MT6783, MT6771) support
For some models, you may have to select correct DA file manually
ADD: Added support for Qualcomm SDM630, SDM636, SDM640, SDM660, SDM670, SDM845 devices
ADD: Support for Nokia devices (Qualcomm and MediaTek) with official nb0 firmware files
ADD: Extract support for Nb0 file
ADD: Cache handling on model loads
WARNING: Do not rename "BRAND" and "MODEL" list to be different as at support site, certain features might not working properly !!!
CHIP Prog changes:
BUGFIX: Fixed write bug on small SPI NAND and eeprom devices(UFIBox firmware upgrade required)
UFI Software Version 1.2.0.454
General changes:
Added "report an issue" in the window popup menu
Fixed UFI Dongle detection bug in Windows 8.1 Build 9600
Improved support for Windows 10 Redstone
ADD: Bug fixed for Mediatek BROM version 7.1817.3.0(was problematic for device with eMMC storage)
ADD: Mediatek META init support for latest MediaTek chipset(MT6783, MT6771)FLASHING
ADD: Flashing Support for Spreadtrum Devices directly with pac file(without extract)
ADD: Revised Qualcomm EDL flashing(handling sparse file on-the-fly)
ADD: Internal firehose loader for some "new" Vivo devices to bypass custom auth
ADD: Identification of Qualcomm firehose loader with VIP and custom auth
ADD: Flashing Support for Qualcomm firehose loader with VIP enabled (Latest Oppo devices, R11s, R15, A71 2018 and so on)
Partial Read, Write and Erase is blocked with firehose with VIP enabled
ADD: Extract support for latest ofp files (F7, R11s, R15 and so on)
ADD: "Clear App Cache" on Settings
ADD: Option to exclude spesific ports on Settings
BUGFIX: Meizu SLA auth for latest MediaTek models
UFI Software version 1.3.0.1155
General changes:
Software version numbering changed
ADD: Extract support for RAR5 file format
ADD: System information for Android A/B system is now readed correctly
ADD: Improved reading system information for Android Oreo and Project Treble system
ADD: Auto list PIT file inside tar.md5 archive on factory image tab
ADD: Meizu Qualcomm EDL with authorization flashing support
Currently supported models:
Meizu 15
Meizu 15 LITE
Meizu 16th
Meizu 16X
Internet connection required for remote authentication
ADD: Xiaomi Anti-Rollback repair via EDL
Note that newer Xiaomi devices require more authentication(Qualcomm and MediaTek model)
Some models has a bug which allow us to use "older" firehose without custom auth and some others had a bug to bypass custom auth.
Redmi Note 5, Mi 6X (SDM660)
Redmi S2/Y2, Mi MAX3 (MSM8953)
ADD: Revised Xiaomi Reset Mi Account Lock routine to support Oreo based MIUI
ADD: Qualcomm EDL Special tasks
Patch boot image(disable dm-verity, encryption) - oem sig
Patch boot image(disable dm-verity, encryption) - sig overflow
Switch to Global for Oreo based MIUI
ADD: Xiaomi sideload(MIUI Recovery) support, use the toggle button to switch between normal and MIUI sideload
ADD: Xiaomi Wipe data via MIUI recovery
ADD: Removed fastboot quick task, changed to fastboot special task
ADD: Motorola fastboot flashing support(correct parsing for xml file)
ADD: Motorola Bypass FRP Lock in the fastboot special task menu
ADD: USB connection status which will be usefull to identify problem caused by usb communication while flashing
ADD: Bypass FRP Lock(Bypass setup wizard) in the adb special task menu
ADD: Disable MIUI Service for non rooted devices in the adb special task menu
ADD: Extract support for newest OFP files
BUGFIX: QCN write bug fixed
BUGFIX: EDL flashing issue on old chipset
BUGFIX: EDL flashing issue with some Oppo devices with VIP enabled bug fixed
BUGFIX: Mediatek BROM version auto selection on older chipset
BUGFIX: Spreadtrum fdl load handler when working with PAC files directly(without extract)
BUGFIX: Bug while listing provisioning file resulting duplicate files
BUGFIX: Bug while listing multi(lun) rawprogram for devices with ufs storage
Тип файла: rar UFI_v1.3.0.1155_setup.part1.rar (60.00 Мб, 29 просмотров)
Тип файла: rar UFI_v1.3.0.1155_setup.part2.rar (60.00 Мб, 25 просмотров)
Тип файла: rar UFI_v1.3.0.1155_setup.part3.rar (48.77 Мб, 23 просмотров)
Последний раз редактировалось gsmservice.uz; 12.11.2018 в 10:11.
Usmonov Rustam вне форума   Ответить с цитированием
Akbar_as (16.10.2018), ELYOR.PHONE (19.06.2019), gsmservice.uz (16.10.2018)
Старый4 21.08.2019, 17:45   #2
Points: 129,727, Level: 100 Points: 129,727, Level: 100 Points: 129,727, Level: 100
Поблагодарил(а): 1,461
Поблагодарили 9,619 раз(а) в 3,446 сообщениях
По умолчанию UFI Software version 1.4.0.1464
!!! WARNING: Do not rename "BRAND" and "MODEL" list to be different as at support site, certain features might not working properly !!!
General changes:
Introducing UFIBox firmware version 1.13
Latest firmware for supported models (Nokia, Meizu, Xiaomi, Oppo, Vivo and others) was uploaded to support servers
Remapped [USB] Device Manager toolbox menu
Revised upgrade firmware routine for boxed with new hardware version
ADD: Improved reading system information for Android with Project Treble and Android A/B system
BUGFIX: Handing extracted OFP files
WARNING: Extracted OFP firmwares is still encrypted and can only be used from within the UFI Software(including eMMC ToolBox)
Always use self extracted firmware image from OFP file, never use firmware extracts downloaded from internet that are known to have been extracted using UFI software
Using this fimware with other tools may result in bricked devices !!!
ADD: Introducing UFI CREDIT for flash authentication, unlock bootloader and repair signed imei for new security phones
Currently implemented:
Nokia (by HMD Global) supports for flashing(QC, MTK), repair imei, unlock bootloader
Meizu supports for flashing(QC, MTK, EXYNOS), unlock bootloader(EXYNOS)
Xiaomi supports for flashing(QC, MTK), unlock bootloader for some devices
Oppo supports for flashing(QC) and repair imei(QC, MTK)
ADD: Full support for Nokia phones (by HMD Global)
- Support for phones with old security and new security version: 4 and security version: 8
- Normal flashing via Fastboot mode (both for old and newer phones, requires authentication)
- Unlock Bootloader via "FASTBOOT->Special Task" (requires credits)
- Repair IMEI via "SERVICE->IMEI & PROD ID", need to run in FTM MODE before IMEI tasks(requires authentication)
ADD: Support for Meizu with Exynos platform
- Normal flashing via Fastboot mode(requires authentication)
ADD: Support for Latest Oppo phones(Qualcomm platform)
- Normal flashing via Qualcomm EDL mode (requires authentication)
ADD: Full support for Latest Xiaomi phones(Qualcomm and MediaTek platform)
- Normal flashing via Qualcomm EDL mode and MTK BootRom mode(requires authentication)
- Unlock Bootloader for some phones via "FASTBOOT->Special Task"
ADD: IMEI repair support for Newer Oppo phones
- IMEI repair for Oppo requires to have a pair of PCBA Number and Both IMEI number(requires credits)
ADD: Erase FRP and Erase Userdata option while flashing
For effective flashing task, you can now automated Erase FRP and/or Userdata on flashing
ADD: On MediaTek devices, After Identify phones will stay in DA mode so next time you need to do -
some tasks(Write, Erase, Special Task, etc) the software will resume the DA session and continue the task
Note that: DA session will lost if USB disconnected, changing BROM version or you close the UFI software
ADD: Erase FRP and Userdata support with Newer Vivo phones with new security
ADD: Merged IMEI and Product ID functions to "SERVICE->IMEI & PROD ID" tab
ADD: "SERVICE->TOOLS" tab
[Oppo] Secrecy Unlock used to Decrypt Factory Engineering Mode, after unlock you can Unlock Region Lock, Enable DIAG or META mode
[META] Master Clear used to Erase Internal Storage (may work for some old models)
ADD: "SERVICE->REMOTE SERVICE" tab
All Remote Services will be available here(some services can be free or requires credits)
Currently available:
Xiaomi Unbind Mi Account(CLEAN Device Only) by SN
Oppo Calculate AuthTokenDecrypt Code, Similliar to Secrecy Unlock but it done remotely without access to the phone physically
ADD: Added Latest MediaTek BROM version 7.1917.3.0 for latest MediaTek chipset with new PL signature type
BUGFIX: Improved rawprogram.xml parsing to handle misconfigured items for unsplited/sparsed images(vivo)
BUGFIX: Improved ADB Logcat features
BUGFIX: Improved Debug Uart Terminal features (Note that Debug Uart for MediaTek platform requires 921600 baudrate)
NOTE:
All features which requires authentication will require credit
Some remote services are free but are required to have atleast 1 credits in your account
See "[ACCOUNT]" menu to see latest available services, status and the service cost
The credits top up system can be accessed directly there
Payment can be made with Paypal(for International) and GO-PAY(For Indonesia)
Credits can also be purchased from available resellers
Ulugbek (21.08.2019)
Старый4 17.09.2019, 11:05   #3
По умолчанию UFI Software Version 1.4.0.1491
ADD: [Oppo] MasterClear in USER AREA PART tab, Special Task
ADD: New eMMC5x FFU files for eMMC5x Field Firmware Update
MICRON-S0J9K9(16).ffu
SAMSUNG-3H6CAB(210).ffu
SAMSUNG-DH6DAB(210).ffu
SAMSUNG-GD6BMB(5).ffu
BUGFIX: UFI Lite connection issue
ADD: Oppo EngineeringMode Task in ADB tab, Special Task
ADD: [Oppo] MasterClear for Qualcomm and MediaTek, Special Task
Wipe Data & App Data - Remove user lock, FRP and third party app
Wipe Data Only - Remove user lock
Wipe App Data Only - Remove FRP and third party app
Format Data - Format all user data
ADD: External Loader selection list for Qualcomm firehose and MediaTek DA and auth (Click on the label)
BUGFIX: MediaTek keep in DA mode issue fixed
BUGFIX: Auth specific routine improved
BUGFIX: Nokia Fastboot flashing issue for (Qualcomm platform)
BUGFIX: Oppo MediaTek flashing issue with error S_PRELOADER_INVALID
BUGFIX: MediaTek flashing issue with error S_FTHND_FILE_IS_NOT_LOADED_YET
BUGFIX: Oppo EDL flashing with VIP issue
NOTE:
Bootloader Authorization service is limited as "Bootloader Authorization" which is required for Identify, Flashing, Read, Write, Erase and Special Task menu
If Bootloader Authorization request fails, you may retry 2 more times at no cost
For any issue and refund claim because of software bugs, you may write an email to support[at]ufibox.com, please include your detailed logs
There are 4 scenarios in [Oppo] Master Clear operation
For easy understanding, will explain by using two popular user lock issue in Android,
There is a User Lock (Pin/Passcode) and FRP (Google Account).
And we have also User Data Files: User Apps(include contact and SMS), and Media Files(music, pictures, videos)
1. Wipe Data & App:
This will clear User Lock (Pin/Passcode), and FRP (Google Account), User Apps but will not remove media files.
2. Wipe Data Only:
This will clear User Lock (Pin/Passcode), but not remove FRP (Google Account), and Media Files.
3. Wipe App Data:
This will not Clear User Lock (Pin/Passcode), but will bypass FRP (Google Account). All User Apps and Media Files will stay intact.
4. Format Data:
This will clear User Lock (Pin/Passcode), User Apps and Media Files, but not remove FRP (Google Account).
From the description above, you can adjust according to your customer's needs, and negotiate the highest costs possible.
Старый4 28.09.2019, 12:36   #4
По умолчанию UFI Software version 1.4.0.1502
ADD: Added 16MB & 32MB preset for Boot and RPMB size change
ADD: [Vivo] MasterClear in USERAREA PART tab, Special Task
ADD: [Oppo] MasterClear in USERAREA PART tab, Special Task
AUTO UPDATE
Nurziyod (28.09.2019), Ulugbek (28.09.2019)
Старый4 07.03.2020, 10:51   #5
По умолчанию UFI Box Software Version 1.4.0.1663
UFI Box Software Version 1.4.0.1663 Auto Update Released
ADD: Added Latest MediaTek BROM version 7.1945.3.0
ADD: Revised Xiaomi flashing authorization routine
Added support for MT6785
Note that flashing authorization is only for devices with the "Find My Device" status OFF
ADD: Revised Nokia flashing authorization routine
Option to preserve service bootloader on flashing
NOTE:
For any issue and refund claim because of software bugs, you may write an email to support[at]ufibox.com, please include your detailed logs.
ADD: Samsung Lz4 firmware support on factory image tab
BUGFIX: Mediatek repartitioning issue fixed on factory image tab
BUGFIX: Minor bugfixes and improvements.
How To Update:
Go To UFI Box Setting & Start Synchronize File.
Ulugbek (11.03.2020)
Старый4 01.07.2020, 18:55   #6
По умолчанию UFI Software Update v.1.4.0.1779
General changes:
Support for Windows 10 version 2004(20H1) and 2009(20H2)
ADD: Introduced console mode by executing UFI.exe with command line /c
Syntax : ufi.exe /c [device][config][command]options][file]
BUGFIX: Mediatek scatter(factory image0 addressing issue introduced by previous release is now fixed
ADD: Added flashing support for latest Xiaomi models
ADD: Oppo Disable OTA update in ADB tab, Special Task
ADD: Improved flashing support with latest Mediatek BROM version 7.1945.3.0 for both UFS and eMMC storage
ADD: Updated Mediatek SoC list: MT6768, MT6873
ADD: Updated Qualcomm SoC list: SM4250, SM6115, SM6125, SM6150, SM8150, SM8250
BUGFIX: Parsing rawprogram_unparse with UFS Storage
NOTE:
Ulugbek (02.07.2020)
Текущее время: 23:44. Часовой пояс GMT +5.
