Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > Infinity Box
Infinity Box Форум поддержки программатора Infinity Box
Закрытая тема
Старый4 13.08.2020, 15:18   #21
Points: 186,630, Level: 100 Points: 186,630, Level: 100 Points: 186,630, Level: 100
Поблагодарил(а): 1,503
Поблагодарили 9,916 раз(а) в 3,649 сообщениях
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.06
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.06 - Android 10, FastRead, FastFlash
As ordinary, unique functions and methods released
Core
Changed : FlashCore Protocol updated
Changed : DiagCore Protocol updated
Changed : NAND protocol adaptation
Changed : Operations speed increased
Flasher
Changed : Flash Engine updated
Changed : Handling for 64bit files optimized
Changed : Activated FastFlash V1 protocol *
Changed : Activated FastFlash V2 protocol *
!* FastFlash protocol allow increase flashing speed for big unsparsed images
!* FastFlash protocol reduce flashing time up to 4-6 times, depend on device configuration - 3-4 minutes against 20-25
!* FastFlash activated automatically, if can be performed
!* GOOD USB cable and GOOD USB port must be used - do not use USB HUBs !
Changed : Support for new PAC formats activated: v2.x.x line
Service
Changed : Identify scheme : Read more accurate and complete info *
!* Include modern Android 9 and Android 10 devices
Changed : Precise FileSystem settings detection ( Type and Encryption algo )
Changed : Better security detection
Changed : Format FS / Reset settings updated
Firmware Reader
Changed : Reading speed up to 30% faster ! *
!* Test feature, support modern UniSoc devices: SC7731E, SC9832E, SC9863
!* Test feature, only RS-featured loaders supported !
Changed : Android 10 support activated! *
!* Support latest Android 9 and modern Android 10 devices from now!
!* Allow read complete firmware image from Android 10 devices without loss any ota/vendor abilities
Changed : X64 devices/loaders native support activated for complete reading
Changed : SW now create Android-version depend images for better compatibility
Changed : SW now create correct FileSystems bundle according device settings *
!* Almost reducing "hang" case after flashing
Changed : Improved structure identification
Changed : Support more different types
Changed : Structure identification and NAND reader more stable now (complete E-series NAND adaptation is on the way)
Model DB
Changed : New loaders included for various set of devices
Changed : New Generic loaders included and updated existing ones
Other
Changed : Removed outdated options from platform tab, many options changed to atomatic mode
BugFix : Minor changes and fixes
Info
Android 10 enabled devices : SC7731E, SC9832E, SC9863
FastFlash enabled devices : SC9832E, SC9863
gsmservice.uz вне форума
Старый4 07.09.2020, 15:31   #22
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.07
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.07 released - UltraReading & New Features activated
Core
BugFix : SC9832E line support updated
BugFix : SC9820E line support updated
BugFix : SC9863x line support updated
NewFeature : eMMC ReadOnly check for DLv4 and later ( automatic during boot )
Changed : All service features speed under FlashMode increased
Flasher
Changed : FastFlash protocol updated
Service
BugFix [Identify] : FS state detection may fail for legacy SPD line, fixed
Changed [Identify] : SelfLearn / Automatic DB update during "Identify" rebuild
Changed [Identify] : Support detection of AES and RSA-enabled auth in devices/loaders
Changed [Identify] : Support correct BASE <-> DEVICE verification for optimal loader selection
BugFix [Read Privacy] : Privacy Lock reading on some devices may fail , fixed
NewFeature [Read Privacy] : Mobile AntiTheft password reading ( another version of "privacy lock" )
BugFix [Format FS] : Fixed Format FS in DiagMode for Android 10 and modern Android 9 devices
Firmware Reader
Changed : Complete FWReader rebuild to cover most count of different devices, existing on market *
!* Almost all Flashing issues has been fixed, FWRead repeat required for problematic cases/models!
Changed : UltraReading option activated ! *
!* Now reading of UniSoc devices 3-5 times faster, than before
- approx 20 mins instead of 70 for SC9853i (2.2 GiB) comparing to older releases
- approx 12 mins instead of 40 for SC9832E (2.5 GiB) comparing to older releases
- approx 20 mins instead of 60 for SC9863 (4.4 GiB) comparing to older releases
- approx 15 mins instead of 50 for SC7731 (1.5 GiB) comparing to older releases
!* Most generic loaders now support FastReading ( RS,SS,0S,1S,2S )
- Use USB-2 port !
- DO NOT use USB-3 port !
- DO NOT use USB-HUB !
Changed : Android 10 devices support improved
Model DB
Changed : SC9820E(eMMC), SC9832E, SC9863x loaders updated
Other
Changed : Power Reset/Switch off scenario operation-depend now
Option : GUI ( File -> GUI ) : Allow select other interface mode*
!* Default interface - standard V2 line GUI
!* Wide interface - best for big screen / big distance to monitor
!* Wide log - extend log window to screen size - optimal for most cases
Старый4 03.11.2020, 19:52   #23
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.08 - NAND, Forensic and more features !
Core
Changed : FlashCore protocol updated
Changed : NAND support rebuild
Changed : X64 SS/RS loader line handling optimized
New SOC : SC9820E with NAND support
New SOC : SC7731E with NAND support
Flasher
Changed : Big files handling optimized
Changed : NVM manager updated
Firmware reader
New Feature : UniSoc NAND SC9820E/SC7731E support activated !
- Allow backup FW from range of phones, based on SC9820E/SC7731E SoC with NAND flash memory
- Firmware is complete, not damage any security, ota or any other compatibility
Changed : Forced reading ( disable deep verify ) option enabled - Use WITH CAUTION!
Changed : Android 4.x / Mocor 5 specific changes
Changed : UBI defragmentation for NAND devices activated by default
Service
New Feature : Security Repair allow change BT/WiFi MAC
- Useful only in DiagMode for UniSoc(E-line), Flash/Diag for SPRD line
Changed : Security Repair options - Generate MAC's - double click at MAC field to generate and activated
Changed : Security Repair options - AutoIncremental set SEC2/SEC3 fields, when SEC1 set. Just double click in next field
Changed : Security Repair : NVM Manager updated according latest devices changes
Changed : Identify : Support identify for UniSoc NAND line
Changed : Identify : NAND identify speed increased
UserData
Changed : Privacy reading types increased to 4 ( +2 new types )
New Feature : UserData DeepVerify and DUMP activated!
- Available for users with active Infinity Data Explorer module!
- Ignore ALL sprd protocol limitations, which require MEMORY DESOLDER and EXTERNAL MEMORY PROGRAMMER using!
- Allow verify and dump COMPLETE USER image for wide range of types and filesystems
1. eMMC with EXT3/EXT4 filesystem. FDE check may differs from Identify!
2. eMMC with F2FS filesystem. FDE check may differs from Identify!
3. NAND with UBIFS. Result image defragmented and prepared for further forensic analyze
- Internal checks during dumping make differ, than Identify option, analysis. Even if Identify say FDE - device can be not encrypted.
- Ability to resume dumping in case of read fails, can be used much times, as need
- After dumping device must be flashed!
1. Get FW or make FW backup from WORKING/GOOD device with complete options if SW asks
2. Complete Flash device
or
2. If need revert device to initial state
2.1 : Select FW, uncheck all items ( Rmouse - > Uncheck all )
2.2 : Select UBOOT/SPL
2.3 : All other settings must be default, not touch anything
2.4 : Flash device
Model DB
Changed : New generic loaders included, changes some existing once for better compatibility
Changed : Generic SC9820E NAND loaders included
Changed : Generic SC7731E NAND loaders included
QIN QF9 ( QIN1 SC9820E ) - full support : Read/Write FW,Reset Settings,Security,Service
- Firmware can be found on support area
- Boot key : Call button
- Change Lang sequence : Ok, Left, down, ok, 15 times - down, ok, ok, select need language ( English )
Password for files: 12345678
Ulugbek (04.11.2020)
Старый4 17.11.2020, 19:29   #24
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.09 - SPUnlock for most SPD/UniSoc
Core
Flasher
Changed : NVM manager updated. Recovery mode rebuild
Firmware reader
Changed : SPRD Android 4.x line minor changes
Changed : New types supported (Android 9/10)
Service
New Feature: SP (Network) Unlock activated !
- Support Legacy SPRD phones on SC7715/SC7731/SC9820/SC9832/SC9850
- Support modern UniSoc phones on SC9820e/SC7731e/SC9832e/SC9850/SC9853i/SC9863
- Support unlock in FlashMode ( ! recommended way, permanent )
- Support unlock in DiagMode ( ! may relock in some certain cases )
- Support unlock for signed and unsigned devices
-- Unsigned/Legacy devices supported standalone without server
-- Modern devices require server support
Changed : NVM manager updated ( Read/Write process revised )
Other
- Setting tab activated
1. Allow setup user details to use remote/server functions
2. Allow select Firmware path
- Changed default paths for different operations
- Minor changes and fixes
ilhom-uz (18.11.2020), Nurziyod (17.11.2020), Ulugbek (17.11.2020)
Старый4 03.01.2021, 13:57   #25
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.10
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.10 - Released Happy New Year​
Core
NewSOC: UniSOC Tiger T61x series support
NewSOC: UniSOC UIS7862 (Car HeadUnits SoC) series support
NewSOC: SC7731E Android 10 / FastProto supported
NewSOC: SC9832E Android 10 / FastProto supported
Flasher
Changed : Protocol updated
Changed : FastFlash protocol updated ( SC7731E, SC9832E supported )
Firmware reader
Changed : Android 10 specific changes
Changed : Initial Tiger and NaT devices support
Changed : UltraRead protocol updated ( SC7731E, SC9832E supported under 0S loaders now )
Service
NewFeature: Security Repair allow change PSN1/PSN2
- In newer devices PSN1/2 damage may lead to bootlop, ota and other issues
- In newer devices PSN1/2 used as bootloader token
Changed : Identify : Correct MEMORY and RAM size reading for Android 10 devices
Changed : Identify : Read PSN1 and PSN1
Changed : Identify : SC9832E and SC7731E can be used to verify eMMC ReadOnly state (0S loader mode)
Changed : Repair : Identify signed devices during repair
Changed : NVM : Read and Write operations revised
UserData
Changed : UserData dump feature updated ( Legacy line fixes )
SPUnlock
Changed : SC9863 support updated
Changed : SC9832 support updated
Changed : PermLock fix ( processed in automatic mode, fix issue with possible PermLock after first unlock try )
NewFeature: Error codes explanation and hints
NewFeature: Damaged devices ( security destroyed ) detection
NewFeature: Damaged devices ( permLock ) detection
Model DB
Changed : New generic loaders included for SC7731E with Android 10 ( 0S type )
Changed : New generic loaders included for SC7792E with Android 10 ( 0S type )
Changed : New generic loaders included for Tiger T61x
Changed : New generic loaders included for UIS7862
Changed : ZTE, Itel and others line loaders updated to support faster operatons amd more HW variants
Other
Changed : GUI settings now stored and load select style, settings and other at next run
Changed : Lot of different changes and fixes
Старый4 10.02.2021, 18:22   #26
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.11
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.11 - Unlock, Repair, New CPU
Core
Changed: FlashCore protocol updated
NewSOC: UMS9117 support ( service mode )
Flasher
Changed: Protocol updated
Changed: NVM manager updated
Firmware reader
Changed: Android 10 specific changes
Changed: UltraRead protocol updated
Changed: New types supported
Service
Changed: Repair : Security Repair allow now repair signed devices
- Permanent lock and other issues can be also fixed with that feature
- Repair can be done in Flash and Diag mode
- Repair support new security devices as well ( Android 10 + )
Changed: Repair : UMS9117 repair security support activated ( Nokia line supported included )
Changed: Identify : Enabled Read All Info by default under FlashMode
Changed: FormatFS : UMS9117 Reset/Format FS support activated
SPUnlock
Changed: UMS9117 support activated ( Nokia line supported included )
Changed: SC9863, SC9832 support improved
Other
Changed: Many internal changes and fixes
Drivers: UMS9117 drivers are at support area
* with password 12345678
Старый4 07.06.2021, 12:04   #27
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.12
Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.12 - New repair level activated
Core
Changed: FlashCore protocol updated (R25)
Changed: New DL-core support (v10 at Infinity notation)
NewSOC: SC9820e [RS/0S] with NAND supported
Changed: Diag protocol updated
Flasher
Changed: FlashCore rebuild
- Reworked FlashErase
- Reworked support of fully erased or semi-damaged modern devices Android 8/9/10/11 (SC9820e, SC7731e, SC9832e, SC9863, SC9850), it is possible to repair these devices from any state (in case of working HW)
- Reworked NVRecovery procedure
- Android version change ( Downgrade/Upgrade ) now work more correct
Firmware reader
Changed: KaiOs specific changes
Changed: Initial Android 11 support
Changed: Fixed "Encryption Unsucessfull" errors on some devices after flash
SPUnlock
Changed: Android 11 SPunlock and Repair confirmed and working
Changed: UniSoc Tiger T310 initial SPUnlock/Repair support
Changed: Changed unlock procedure for some devices
Changed: Allow check status/continue unlock on zero balance
Almost all existing on market devices for SP-Unlock and Repair are supported, Android 10 / 11 "security" as well
Model DB
Changed: New generic loaders included for 9820E with NAND
Other
Changed: Many other different changes and fixes
Старый4 29.06.2021, 19:28   #28
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.13 - Boot RSA Auth activated
Core
Changed: Automatic detection and use loaders with PMTInfo
Changed: FlashLoader authentification [RSA and AES] activated ( brand-specific )
- Allow service over FlashMode models, which require remote authentification
- Supproted Brand lines: Itel - all RSA-auth enabled models
- Supported default prod auth - Generic models, RSA and AES
- After sucessfull auth you have full access to any service operations - flash read, write, frp, repair
- Feature require Internet access and valid IOS username and password
- Feature is free and unlimited for all currently supported models
Flasher
Firmware reader
Changed: New range of generic and brand-specific models support for safe and complete Firmware Read
Changed: NAND support revised
Model DB
Changed: Moto G20 (XT-2821-X line) included in list (support under test)
Other
Changed: Some changes and fixes
Старый4 25.09.2021, 13:24   #29
Вес репутации: 70
По умолчанию Infinity Chinese Miracle-2 SP2/SPD-UniSoc v2.14 - A/B support and more!
Core
Changed: FlashCore protocol updated (R25.x)
Changed: New DL-core support (v20 at Infinity notation)
Changed: 1S base loaders for SC7731e (AB devices, Android 10/11)
Changed: 1S loaders line included for SC9832e (AB devices, Android 10/11)
Changed: 1S loaders line included for SC9863 (AB devices, Android 10/11)
Info : 1S loaders reccommend to use for Identify operation on older UniSoc lines (SC7731e, SC9832e, SC9863 with Android 9 - 10)
Changed: FlashLoader authentification [RSA and AES] (brand-specific)
- New model lines activated (server-side): Tecno, Infinix
- Supproted Brand lines: Itel, Infinix, Tecno, Generic
Flasher
Changed: FlashCore update
Changed: A/B flashing activated (Infinity Packages, factory PAC)
Changed: PAC r2.x line support updated
Changed: Infinity Packages flashing revised
Service
Changed: FormatFS updated
Changed: NVMManager updated (NV Read, Write, Update)
Changed: RepairSecurity updated: SN repair
Changed: RepairSecurity updated: ServerSupport models list increased, more Android 10/11 supported
Firmware reader
Changed: Android 10, 11 specific changes
Changed: Loader compatibility selection optimized
Changed: A/B devices support activated!
- Allow read complete, working, safe and factory-like firmware images for most modern Android 10/11 devices!
- No any FOTA, security and other issues with read FW, no any unique data damaging
- Automatic active slot identification and selection, with no chances to read useless firmware (and save 2x hdd space for old AB)
Model DB
Changed: New generic loaders included for SC7731e (1S line, v20)
Changed: New generic loaders included for SC9832e (1S line, v20)
Changed: New generic loaders included for SC9863 (1S line, v20)
Changed: New generic loaders included for T618 (1S line, v20)
Changed: New loaders included for Realme
Changed: New loaders included for Itel
Changed: New loaders included for Tecno
Changed: New loaders included for ZTE
Other
Changed: LoaderDB updater now supports modern PACs (A/B, modern R2.x)
Закрытая тема
chinese, download, forum, free, infinity, miracle, spd, spreadtrum, tashkent, update, uzbekistan, бепул, обновления, форум, юклаш, янгилаш
Текущее время: 21:29. Часовой пояс GMT +5.
