Вернуться   MOBILFORUM.UZ GSM FORUM UZBEKISTAN > Форумы поддержки оборудования > EME Mobile Tool ( EMT ) (ex BST)
EME Mobile Tool ( EMT ) (ex BST) Раздел поддержки программных продуктов EME Mobile Tool ( BST )
Старый4 21.04.2021, 12:14   #21
Points: 171,683, Level: 100 Points: 171,683, Level: 100 Points: 171,683, Level: 100
Поблагодарил(а): 1,482
Поблагодарили 9,869 раз(а) в 3,616 сообщениях
Вес репутации: 68
По умолчанию EMT v3.08.00
EMT v3.08.00 Released
World First! Added Blackshark 3S/3PRO/3, MI NOTE3/MAX2/MIX2, Redmi NOTE5A/5Plus etc models Reset MI Lock No VPN / No Unlock Bootloader / No Flash Roms New Solution, Supported MIUI 8,9,10,11,12 versions, can be able to factory reset & reboot device after reset mi lock!
World First! Added Reset Screenlock without data loss for Redmi 6, Redmi 6A, Mi Play, Supported to MIUI11!
World First! Added Y30G, Y20G, Y7S, V17 NEO, S1, Y5S, Y19 etc models Flash, Factory Reset, Reset ID Lock etc functions!
Added MTK Module Auth Service (no need install Python and Libusb), Supported MT6735, MT6737, MT6739, MT6750, MT6755, MT6757, MT6761, MT6763, MT6765, MT6768, MT6771, MT6785, MT6799, MT6873, MT8127, MT8163, MT8173, MT8695 Flash/Unlock etc functions!
ADDED
XIAOMI MODULE:
World First! No VPN / No Unlock BL / No Flash ROMs
Following Models by EDL Mode:
Reset ID Lock (Supported MIUI 8,9,10,11,12)
-BLACKSHARK 3S (KLEIN)
-BLACKSHARK 3 PRO (KLEIN)
-BLACKSHARK 3 (KLEIN)
-BLACKSHARK 3_8+128 (KLEIN)
-REDMI GO (TIARE)
-MI NOTE 3 (JASON)
-MI MAX 2 (OXYGEN)
-MI MIX 2 (CHIRON)
-MI 6 (SAGIT)
-MI MIX (LITHIUM)
-MI MAX PRIME (HELIUM)
-MI MAX (HYDROGEN)
-MI 5SPLUS (NATRIUM)
-MI 5S (CAPRICORN)
-MI 5 (GEMINI)
-MI NOTE2 (SCORPIO)
-MI A1 (TISSOT)
-MI 5X (TIFFANY)
-REDMI NOTE 5A PRIME (UGG)
-REDMI Y1 (UGG)
-REDMI NOTE 5A (UGGLITE)
-REDMI Y1 LITE (UGGLITE)
-REDMI 5A (RIVA)
-REDMI 4S (AQUA)
-REDMI 4C (LIBRA)
-REDMI 5 PLUS (VINCE)
-REDMI 5 (ROSY)
TIPS: After Reset MI lock, you can factory reset and reboot device, but phone will be relock by mi lock after flash roms or online updates, recommended to close system online updates.
World First! Following Models by Flash Mode:
Disable/Enable Screenlocks (Supported to MIUI11)
-REDMI 6 (CEREUS)
-REDMI 6A (CACTUS)
-MI PLAY (LOTUS)
Read Info, Flash, Read/Erase/Write Partition, Factory Reset, Reset ID, Partition File Manager
-REDMI 10X_4G (MERLIN)
TIPS: If phone relock after network connect, need to install VPN and disable the xiaomi etc apk network first!
VIVO MODULE:
-Y30G (PD2066B)
-Y20G (PD2066F,PD2066CF)
-Y7S (PD1913,PD1913B)
-V17 NEO (PD1913F)
-S1 (PD1913F)
-Y5S (PD1934)
-Y19 (PD1934F)
MTK MODULE:
No Need install Python and Libusb
Following Models by Bootrom Mode:
Authentication Service
-MT6261
-MT6572
-MT6580
-MT6582
-MT6735
-MT6737
-MT6739
-MT6750
-MT6755
-MT6757
-MT6761
-MT6763
-MT6765
-MT6768
-MT6771
-MT6785
-MT6799
-MT6873
-MT8127
-MT8163
-MT8173
-MT8695
FIXED
-Improved MTK protocol
-Improved MTK "Skip Security" option
-Improved Xiaomi "Lookup Model (Sideload)" function
-Fixed Known bugs
INFORMATION
About MTK module "Authentication Service" function:
1).Method: Press "Authentication Service", Power off, Press Vol Up + Vol Dn, Connect USB Cable.
2).Function: Select Loader and Scatter files manually after Authentication Service, supported Unlock/Flash etc functions.
2.1).Loader: Select "DA_v3_3001_01.bin" or other loader files
2.2).Scatter: get "*_scatter.txt" and "preloader_*.bin" files from firmware and then select scatter file.
bst, emt, standart, обновления, скачать
Текущее время: 04:40. Часовой пояс GMT +5.
