NCK Dongle updates
NewsMaker
NCK Box Premium v2/NCK Pro Unisoc Module v2.2.3 - New Security Added - [17/07/2023]
Supported CPUs for these operations which user can use by selecting CPU if Model Not listed or fail using old method - New Security:
SC7731E
SC9820E
SC9832E
SC9863A
Tiger T310(UMS312)
Tiger T606
Tiger T610(UMS512)
Tiger T612(UMS9230)
Tiger T616
Tiger T700
Supported Features of SPRD Tool so far:
Remove FRP
Backup & Restore NVRam
Backup/Read Fimrware
Write Firmware
Reset Userdata
Write IMEI
Write Serial
Write Bluetooth
Write WIFI
Functions for simlock supported:
1. For now supported by this loaders version of simlock : 2,3,5,6
2. Support for version 4 of simlock by universal loaders will be added in incoming update.
2-1. Some phones can be not supported by this loaders, if phone not supported, please make post in forum with exe log and phone details (Brand, Phone Name, Android version).
- Added detection for UFS filesystem, exe will auto detect EMMC or UFS filesystem.
This allow to handle corectly backups, frp e.t.c.
- Added dumping of uboot and sploader on security(nvram backup)
-- This will allow to enable download mode or fastboot mode in dead phones, like samsung.
--- Backup must be readed and writed for same firmware version.
---- For example Samsung U2 version of uboot, must be used same version for read and write.
- Added possibility to select manually saved backup filename.
Models Added in List & are supported now:
Samsung
Boot info, Factory Reset, Backup & Restore Security (nvram), FRP.
Samsung SM-A032M Galaxy A03 Core (all bits)
Samsung SM-A035G Galaxy A03 (all bits)
Samsung SM-A035M Galaxy A03 (all bits)
Some of The models Listed May need to use TEST POINT if the phone does not allow Port to stay open.
Nokia
Nokia C1
Nokia C1 Plus
Nokia C1 2nd Edition
Nokia C2
Nokia C3
Nokia C10
Nokia C20
Nokia C20 Plus
Nokia C21
Nokia C30
Nokia C31
Nokia C01
Nokia C20
Nokia T10
Nokia T20
Nokia T21
Nokia G11
Nokia G11
Nokia G21
Boot info, Factory Reset, Backup&restore Security (nvram), FRP, Simunlock, Repair/Change IMEI, Write Serial, Write Bluetooth, Write WIFI.
Tecno Pop 5 Go BD1
Tecno Pop 5 LTE BD4
Tecno 10C k15k
Honor
Honor Play 20
Honor Play 5T
Realme
Realme C21Y
Realme C25Y
Realme C30s RMX3690
Realme C31
Realme Narzo 50i Prime
Realme C30
Realme C33
Realme C35
Realme Pad Mini RMP2105
Order here - www.Gsmservice.center
#nckdongle
NewsMaker
NCK Box Premium v2/NCK Pro Unisoc Module v2.2.4 - New Security Added - [19/07/2023]
SC7731E
SC9820E
SC9832E
SC9863A
Tiger T310(UMS312)
Tiger T606
Tiger T610(UMS512)
Tiger T612(UMS9230)
Tiger T616
Tiger T700
Remove FRP
Write Firmware
Reset Userdata
Write IMEI
Write Serial
Write Bluetooth
Write WIFI
Read & Write RPMB
Read & Write RPMB
Repair iIMEI/simunlocklock for SC7731E, SC9832E, SC9863A, Tiger T606 cpu.
-- Simlock type4 for now is supported only for sc9863a, will be added in next updates for other cpu selections.
Fixed bug with frp and wipe
Added imei checksum checkbox for repair imei in flash mode
Smart 7 HD(X6516)
Smart 6(X6511B)
WIKO
Wiko Y82 W-K630
Wiko Y80 W-V720
Wiko View 3 Lite W-V800
Umidigi
Umidigi Bison X10G
Umidigi Bison X1S
Umidigi Bison X1G
Oukitel
Oukitel C25
Doogee
Doogee S35T
Cubot
Cubot Kingkong6
Cubot Pocket
Supported in Flash mode: Boot info, Backup/restore security, Wipe phone, Erase FRP, Backup/write firmware
Diag mode functions - Read info, Repair imei, Repair sn, Factory reset.
By NCK 1 year support - here - www.gsmservice.center
#nckdongleupdate
NewsMaker
NCK Box Premium v2/ NCK Pro Android MTK v0.8.6 Released - [22/09/2023]
Added Motorola - Read Simlock unlock codes from MTK Motorola
1. Select flash mode connection.
2. Select Read Simlock Info
- This solution must be universal and supported on many MTK phones.
Can be selected phone from list or simple selected by CPU method with SECURITY BYPASS & SOFTWARE
will Autodetect phone.
Added Remove FRP and format userdata for MTK Motorola phones in FASTBOOT mode.
- To use this solution not need to unlock bootloader.
Solution will temporary unlock bootloader and remove FRP or Format userdata.
This solution must work on many models and must be universal.
It s located in FRP tab.
GENERIC CPU Selection:
Added Simunlock/Read Simlock Info/Repair IMEI in flash mode for Generic CPU Selection
- This solution use default MTK Simlock Algorithm used by many brands what use MTK CPU.
If Algorithm is modified by vendor, this way will not work.
Known brands what use own Algorithm can be OPPO, Xiaomi, Samsung etc...
Updated save security backup and restore security backup function.
Buy NCK 1 year support here - www.gsmservice.center
#nckdongleupdate
NewsMaker
1698649197677-png.2975
NCK Box Premium v2/NCK Pro Unisoc SPRD Module v2.2.5 - [29/10/2023]
SC7731E
SC9820E
SC9832E
SC9863A
Tiger T310(UMS312)
Tiger T606
Tiger T610(UMS512)
Tiger T612(UMS9230)
Tiger T616
Tiger T700
Remove FRP
Write Firmware
Reset Userdata
Write IMEI
Write Serial
Write Bluetooth
Write WIFI
Bootloader Unlock
Read & Write RPMB
Added for this CPUs :
SC7731E
SC9820E
SC9832E
SC9863A
Tiger T310(UMS312)
Tiger T606
Tiger T610(UMS512)
Tiger T612(UMS9230)
Tiger T616
Tiger T700
- Added Unlock phone bootloader for above supported CPU.
- Added possibility to change DM-Verify flag until bootloader unlock.
- Enabled write firmware for firmware readed by exe
- Added "Erase whole CPU" for above supported cpu's.
-- This setting will erase all from phone.
--- Very important-Before use this function need to perform security backup and
have working firmware.
---- On write pac or restore firmware on such erased phones
need to tick "skip backup", write default nvram and repartition to configure phone flash ic.
----- After if need restore from backup nvram, miskdata e.t.c.
- Fixed bug what cause permanently locked after simunlock for some models in flash mode.
- Removed unlock bootloader in fastboot mode as outdated.
- Improved FRP reset for supported models.
- Improved security backup and restore for supported models.
NCK Box Premium v2 / NCK Pro MTK Preloader Tool v1.0 Released - [26/01/2024]
BROM Exploit:
MT6739
MT6761
MT6763
MT6765
MT6768
MT6771
MT6779
MT6781
MT6785
MT6797
MT6833
MT6853
MT6873
MT6877
MT6885
MT6893
Preloader Exploit:
Infinix V1 (Infinix/Tecno/iTel)
Infinix V2 (Infinix/Tecno/iTel)
Infinix V3 (Infinix/Tecno/iTel)
Motorola XT2025
Motorola XT2029
Motorola XT2053
Motorola XT2055
Motorola XT2095
Motorola XT2097
Motorola XT2331
Motorola XT2333
Oppo V1 (MT6765/68/71/33/53/77/85/93)
Oppo V2 (MT6765/68/71/33/53/77/85/93)
Samsung MT6765 (A03s)
Samsung MT6765 (A04)
Samsung MT6765 (A04e)
Samsung MT6833
Vivo V1 (Old Security)
Vivo V2 (September 2023) (MT6765/68/81/83/53/77/93)
Vivo V3 (December 2023) (MT6765/68/81/83/53/77/93)
Supported Functions:
- Erase Userdata
- Reset FRP
- Reset FRP + Userdata
- Unlock Bootloader
- Relock Bootloader
- Read RPMB
- Write RPMB
- Erase RPMB
Added option to select custom preloader for BROM Exploit
Added Screenshot button to take screenshot and save in PNG format
Buy NCK dongle 1 year support here - www.gsmservice.center
#nckdongleupdate
NCK Dongle updates full history - mobilforum.uz (https://mobilforum.uz/threads/alseery-unlocker-updates.1750/)
NCK Team Qualcomm Module v0.13.6 Update Released - [29/01/2024]
Samsung
  • Galaxy A23 SM-A236E-up to Bit 5
  • Galaxy S20 FE SM-G780G-up to Bit 8
- Reset FRP in EDL Mode
- Factory Reset in EDL Mode
Added Auto support for firehose protocol 3.
Software will auto detect supported protocol and will use it.
Updated Samsung factory reset function to support new firehose protocol
NCK Team Unisoc Module Update Released - [11/03/2024]
SC7731E
SC9820E
SC9832E
SC9863A
Tiger T310(UMS312)
Tiger T606
Tiger T610(UMS512)
Tiger T612(UMS9230)
Tiger T616
Tiger T700
MDM Unlock - NEW!!!
SPLoader repair - NEW!!!
Remove Regional Lock - NEW!!!
SC7731E
SC9820E
SC9832E
SC9863A
Tiger T310(UMS312)
Tiger T606
Tiger T610(UMS512)
Tiger T612(UMS9230)
Tiger T616
Tiger T700
SC9863A_64
T606v2 (Tiger T606 Ver2)
T610v2 (Tiger T610(UMS512) Ver2)
T616v2 (Tiger T616 Ver2)
Remove FRP
Write Firmware
Reset Userdata
Write IMEI
Write Serial
Write Bluetooth
Write WIFI
Bootloader Unlock
Read & Write RPMB
1. Added read phone uid (sc9832e, sc7731e,sc9863a).
- Must be used before using repair IMEI or simunlock for phones with simlock 4 security algo.
Before performing any repair IMEI or simunlock need to read phone uid, after can be performed operation.
2. Added write nvram(protect calibration or skip calibration) on flashing firmware using generic loaders.
- Added as beta test extract odin firmware for supported Samsung phones.
-- This function will create flash able in flash mode firmware.
3. Added possibility to restore sploader on phones with damaged sploader (not boot after connecting to exe).
- Need to perform security backup on phone with same model and bit version and after restore sploader
in damaged phone.
4.Added Realme Remove Regional Lock for supported by exe models.
- Was added 2 types of lock, for old and new firmware versions.
5.Added as beta function remove MDM lock, function is supported only by generic loaders listing.
Models Added:
Itel
S16 Pro-Vision 2 (L6503)
Vision 2s (P651L)
Vision 3 (S661L)
Vision 5 (S663LC)
Vision 2S (P681L)
S15 Pro (L6002P)
Vision 3 (S661LN)
A05s (A663L)
P40 (P662L)
S18 Pro (S662L)
A60s (A662LM)
A70 (A665L)
P36 Pro
Vision 1 Pro(L6502)
A26(A571L)
A49 Play(A631L)
A60(A662L)
A21
A40
A41
A24 Pro(A511LP2)
A23S(A511LQ)
Vision 3(A632W)
A60(A662L)
Supported
Boot info, remove FRP, wipe, format userdata, erase all, repair IMEI, remove simlock,
backup/restore firmware, unlock bootloader, Diag mode functions.
Fixes:
1. Fixed security backup/security restore using generic loaders for supported cpu.
Now must resore nvram ok.
2. Fixed repair IMEI in flash mode for supported cpu.
Phones with otp IMEI, signed imei e.t.c will not work.
3. Fixed repair IMEI for phones with simlock 4 using generic loaders(sc9832e, sc7731e,sc9863a).
4. Fixed simlock for phones with simlock 4 using generic loaders(sc9832e, sc7731e,sc9863a).
5. Fixed Nokia T10 loader(reported by users)
Improvements:
1. Improved flashing process(speedup), now must backup write flash more fast.
2. Improved security backup on phones with android 11, 12.
3. Improved booting using generic loaders(some phones respond slow and give error on sending boot).
4. Improved "Erase All" function, this function will erase whole flash including partition table and sploader.
- Use with precaution.
-- After this operation restoring firmware using pac file can not work.
--- Need to use saved firmware from other phone using generic loaders.
#nckdongleupdate
NCK Box Premium v2 / Pro Qualcomm Module v0.13.7 Update Released - [13/03/2024]
Samsung
Galaxy A71 5G SM-A716W BIT9 - Read info, Factory reset, FRP Reset.
Galaxy Z Flip 4 SM-F721B BIT5 - Read info, Factory reset, FRP Reset.
Galaxy Z Flip 4 SM-F721U BIT4 - Read info, Factory reset, FRP Reset.
Galaxy Z Flip 4 SM-F721W BIT4 - Read info, Factory reset, FRP Reset.
Galaxy S10 Plus SM-G975W BIT9 - Read info, Factory reset, FRP Reset.
Galaxy S20 5G SM-G981U BIT8 - Read info, Factory reset, FRP Reset.
Galaxy S20 5G SM-G981W BIT8 - Read info, Factory reset, FRP Reset.
Galaxy S20+ 5G SM-G986U BIT8 - Read info, Factory reset, FRP Reset.
Galaxy S20+ 5G SM-G986W BIT8 - Read info, Factory reset, FRP Reset.
Galaxy S20 Ultra 5G SM-G988U BIT8 - Read info, Factory reset, FRP Reset.
Galaxy S20 Ultra 5G SM-G988W BIT8 - Read info, Factory reset, FRP Reset.
Galaxy S21 Ultra 5G SM-G998W BIT-A - Read info, Factory reset, FRP Reset.
Galaxy M14 SM-M145F BIT1 - Read info, Factory reset, FRP Reset.
Galaxy Note10 SM-N970U BIT8 - Read info, Factory reset, FRP Reset.
Galaxy Note10+ SM-N975U BIT8 - Read info, Factory reset, FRP Reset.
Galaxy Note 20 Ultra 5G SM-N986U BIT6 - Read info, Factory reset, FRP Reset.
Galaxy Note 20 Ultra 5G SM-N986W BIT6 - Read info, Factory reset, FRP Reset.
Galaxy S23 Plus 5G SM-S916W BIT2 - Read info, Factory reset, FRP Reset.
Galaxy S23 Ultra 5G SM-S918N BIT2 - Read info, Factory reset, FRP Reset.
Galaxy S23 Ultra SM-S918U BIT2 - Read info, Factory reset, FRP Reset.
Galaxy S23 Ultra 5G SM-S918W BIT2 - Read info, Factory reset, FRP Reset.
Galaxy S24 SM-S921U BIT1 - Read info, Factory reset, FRP Reset.
Galaxy S24 SM-S921W BIT1 - Read info, Factory reset, FRP Reset.
Galaxy S24 Plus SM-S926U BIT1 - Read info, Factory reset, FRP Reset.
Galaxy S24 Plus SM-S926W BIT1 - Read info, Factory reset, FRP Reset.
Galaxy S24 Ultra SM-S928B BIT1 - Read info, Factory reset, FRP Reset.
Galaxy S24 Ultra SM-S928U BIT1 - Read info, Factory reset, FRP Reset.
Galaxy S24 Ultra SM-S928W BIT1 - Read info, Factory reset, FRP Reset.
Galaxy S22 5G SM-S9010 BIT4 - Read info, Factory reset, FRP Reset.
#nckdongleupdate
UltimateMTK2 v1.2 The Ultimate MediaTek Tool
Added Vivo Demo Reset (New)
- Tested on Vivo T2x 5G and Y28 5G
Added Vivo Demo Reset (Old)
- For devices not supported by New Method
Added Samsung Unbrick and TAR Flashing
- Simple and Easy way to Unbrick Samsung Devices
- NO NEED OF UNBRICK FIRMWARE ANYMORE
- Supports Completely Formatted Flash Chips
- Creation GPT on the fly if it is Erased
- No need to use Odin to flash after Unbrick if used BL/AP/CP/CSC
- Flashing any Single TAR is supported if GPT is intact
- Incase of fully formatted flash chip, you must use BL/AP/CP/CSC
- Use of same or higher BIT Firmware is recommended to fully recover device
- Software will automatically use preloader from BL if device is connected in BROM mode
Added Read Dump
- Simple and Easy Tool to make Full Dump
- Backup BOOT1/BOOT2 and USERAREA
- USERAREA dump is completely customizable
- You can choose either FULL or set own Start/Length for USERAREA
- Auto detect if save location has enough free space to save dump
Added Write Dump
- You can write back dump created by Read Dump function
- Just select CFG file and tick parts of dump you want to write
- Writing DUMP from one device to another is not recommended
- Make sure to backup security partitions before writing DUMP from another device
Fixed "Lost in background" issue on Confirmation Dialog at Startup
Improved Format Functions
Improved Write Flash Function
Minor UI Changes
Important Notes:
- You can flash device with both BROM and Preloader mode
- If default DA does not work, use own DA in custom DA
- Force BROM may not work on new security, use Test Point instead
- When using Test Point, you must select Preloader in PL (not needed when flashing)
- If you need to connect device in Preloader mode, you must select PRELOADER in connection settings, otherwise software will try to Crash Preloader (may not work on new security devices)
Note : Some features are device/OS specific and may not work on all devices.
NCK Box Premium v2 /Pro Qualcomm Module v0.13.9 Released - [27/03/2024]
Still Don t have NCK?
Good News, Now you can activate NCK on you Normal UMT Card.
  • Also! You Can Activate UMT on your Normal Avengers or UMT Card.
  • For More Details Please Contact Your reseller now.
- Alcatel OT-5002
ZTEWorld's First? Possible
- ZTE Nubia Red Magic 9 (NX769j)
- ZTE Nubia Red Magic 9 Pro (NX769j)
- ZTE Nubia Red Magic 9 Pro+ (NX769j)
Supported operations
- Fixed test points images
NCK Box Premium v2 / NCK Pro SPD Module v2.3.0 Released - [07/04/2024]
ZTE
ZTE V30(9030) - T618 CPU
- Supported read info, factory format, frp, backup/restore security, backup/restore firmware, diag mode functions.
-- Simunlock and repair IMEI is not supported yet for this phone.
Also Added:
1. Added to use custom loader on flashing firmware.
User can load custom loader on flashing firmware(pac or readed firmware) and exe will ask to confirm this.
Can be useful for phones what can't be booted with default loader from pac file.
2. Added ITEL/TECNO/INFINIX RSA boot authorization for year 2022 Phones.
Exe will detect auto such phones and will try to perform authorization.
Is supported for flashing pac file, selecting custom loader so on.
Phones with new version(2024) is not supported yet.
Authorization is offline and not need internet for this.
3. Improved Motorola RSA boot authorization for supported phones.
Added possibility to flash Pac file using original loader what request authorization.
4. Improved flash PAC firmware for supported phones(using new protocol must perform flashing more fast).
5.Bug Fixes.
NCK Team Qualcomm Module v0.14.0 Released - [18/04/2024]
Samsung
Galaxy M14 SM-M145F BIT2
Galaxy M55 5G SM-M556B BIT1
Galaxy Note20 Ultra 5G SM-N986U BIT2
Galaxy Note20 Ultra 5G SM-N986U BIT5
Galaxy S21 FE SM-G990 U2
Galaxy S21 FE SM-G990 U7
Read Info, Factory reset, FRP
TCL
TCL 20 SE T671
TCL 20 5G T768O
TCL 20A 5G T768S
TCL 10L T770
TCL 20L T774H
TCL 20L+ T775H
TCL Plex T780H
TCL 20 Pro 5G T781
TCL 30V 5G T781S
TCL 10 Plus T782
TCL 10 5G T790
TCL 10 Pro T799
TCL 20 Pro 5G T810
LEGION Y700 (TB-9707F)
LEGION Y700 2023 TB-320FC
TAB M10 5G (TB-360ZU)
TAB P11 (TB-J606L)
TAB P11 5G (TB-J607Z)
TAB P11 5GWIFI (TB-J607F)
TAB P11 PRO (TB-J706L)
TAB P11 PRO 2021 (TB-J716F,ZA910001CN)
TAB P11 PROWIFI (TB-J706F)
TAB P11WIFI (TB-J606F)
TAB V7 (PB-6505M,PB-6505MC,PB-6505Y)
YOGA SMART TAB (YT-X705L,YT-X705X,YT-X705F)
YOGA TAB 3 8.0 WIFI (YT3-850F)
YOGA TAB 3 PLUS (YT-X703L)
YOGA TAB 3 PLUS WIFI (YT-X703F)
YOGA TAB_13 YT-K606F
TAB P12 PRO 2023 TB-371FC
#nckdongleupdate
NCK Box Premium v2 / NCK Pro Qualcomm Module v0.14.1 Released - [21/04/2024]
Samsung
  • Samsung Galaxy Z Flip3 5G - SM-F711B Bit 7
  • Samsung Galaxy A23 5G - SM-A236U - Bit 5
  • Samsung Galaxy F55 - SM-E556B - Bit 1
  • Samsung Galaxy Z Fold4 - SM-F936B - Bit 5
  • Samsung Galaxy S20 FE 5G - SM-G781V - Bit c
  • Samsung Galaxy S20 FE 5G - SM-G781B - Bit 9
  • Samsung Galaxy A52 5G - SM-A526U - Bit C
  • Samsung Galaxy S20 5G UW - SM_G981V - Bit 8
Fixed
Samsung Galaxy Tab A 10.5
NCK Team SPD Modules Released - [30/04/2024]
Realme
Note 50 RMX3834
Supported read info, factory format, FRP, backup/restore security, Remove Regional Lock, backup/restore firmware, Diag mode functions.
Hisense
U963(HLTE100E)
E30 Lite(HLTE102E)
E31 Lite(HLTE105E)
U964(HLTE106E)
Infinity E30(HLTE107E)
E32 Lite(HLTE107E)
U60(HLTE108E)
U70(Pro HLTE109E)
Infinity E MAX(HLTE221E)
U50(HLTE222E)
Infinity H30 Lite(HLTE223E)
E50 Lite(HLTE228E)
E40(HLTE229E)
Infinity H40 Lite(HLTE230E)
E50 128G(HLTE232E)
Infinity H50 Lite(HLTE233E)
E60 Lite(HLTE235E)
E60(HLTE236E)
E50s 128G(HLTE239E)
H60 Smart(HLTE240E)
E32 Pro(HLTE242E)
E33(HLTE243E)
E70(HLTE262E)
U964(HWCD100E)
U605(HWCD101E)
U605(HWCD103E)
Supported read info, factory format, repair IMEI, FRP, backup/restore security, backup/restore firmware, Diag mode functions.
Added possibility to perform erase Userdata and remove MDM in same function.
Improved
Remove Regional Lock for supported Realme phones.
Repair IMEI in flash mode for supported phones, added possibility to enable or disable backup.
Bug Fixes.
#nckdongleupdate
