[04/03/2023] UMT v2/UMT Pro Unisoc V0.3 update Released.
Unisoc v0.3
The Ultimate Unisoc Tool
Supported Functions
- Read / Write Firmware
- Backup / Restore QCN
- IMEI Repair in FTM/Diag + Flash Mode
- Backup / Reset / Restore Security (EFS)
- Reset FRP (Google Factory Reset Protection)
- Format UserData
- Read Pattern Lock (Android < 6.0, Un-Encrypted Devices Only)
- Reset Locks (PIN, Password, Pattern w/o Data Loss, Un-Encrypted Devices Only)
- Enable Diag (Need OEM Unlock, May not work on BL Locked Devices)
- Reboot to EDL from Fastboot
- Reset Mi Account for Xiaomi Devices
- Disable Mi Account for Xiaomi Devices
- Factory Reset (sideload Mode) for Xiaomi Devices
- Disable / Restore Locks for Encrypted Userdata
- Motorola Boot Repair
- Xiaomi EDL Locked Device Service
- Bootloader Unlock in EDL Mode for some Xiaomi Devices
- One Click Root in EDL Mode for Generic Qualcomm Devices
- Forensic Functions (Read Contacts / Messages in EDL Mode)
- One Click Lock Reset for Vivo Phones (Encrypted Userdata)
- Factory Method for Format FS
- EDL Authentication using Xiaomi Auth App (Service Account Required)
- Xiaomi Wipe EFS in Sideload Mode
- Xiaomi IMEI Repair for RSA Protected Phones
- Xiaomi Boot Loader Unlock
- Unique Method for Vivo Reset Locks for Protected Devices
- Xiaomi EDL Auth Using UMT Server
- Xiaomi Flashing in Fastboot Mode
- Nokia Factory Firmware (nb0) Direct Flashing in EDL mode
- Oppo OFP Firmware Exctration Added
- Xiaomi Free Auth Service (bypass).
- Mi Account Reset without Relock
- Mi Account Patch on Flashing (EDL/Fastboot)
- Samsung MDM Unlock in EDL Mode
- Huawei ID Reset
- Vivo Functions in Fastboot Mode
- Universal Huawei ID Reset
- Xiaomi Sideload Reset FRP/Mi Account
- Xiaomi Sideload Firmware Update
- Xiaomi Temporary BL Unlock
- Xiaomi Enable Diag (NO ROOT)
Added:
Realme
C11 2021 - SimUnlock [beta], other functions already supported.
C25Y - SimUnlock [beta], other functions already supported.
C21Y - SimUnlock [beta], other functions already supported.
SM-A035F - Read Info, Factory Reset, Backup & Restore NVRam, FRP Reset, Write Firmware
-- Added in exe Testpoint images and updated connection logs.
-- Testpoint images links located in Utils tab
ZTE
ZTE Blade P600 - Support for Android 11 Simunlockr.
ZTE Blade P651 2021- Support for Android 11 Simunlock.
ZTE Blade A7S 2020 - Support for Android 11 Simunlock.
ZTE Blade V2020 - Support for Android 11 Simunlock.
ZTE Blade A31 - Support for Android 11 Simunlock.
- Fixed "wrong response" error on unlocking such phones with android 11
ZTE A31 lite - Support for Android 11 Simunlock.
ZTE A3 (2020). - Support for Android 11 Simunlock.
- To service this phones need to select model from list.
- Selecting generic model will not work.
- On selecting Simunlock or IMEI Repair for these phones need to read exe hints.
Itel
A25 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
A51 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
A56 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
AC60 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
Alpha - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
P36 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
P41 - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset, Write Firmware, Diag Functions.
Micromax
IN 2b - Read info, Factory Reset, Backup/Restore NVRam, FRP Reset Write Firmware, Diag Functions.
Gsmservice.center News Channel !, [04.03.2023 18:22]
- Added Possibility to use Custom UID to perform Simunlock.
- Improved Reset FRP on phones with Android 11.
- Improved Restore nvram, Backup firmware, Backup nvram on phones with Android 11.
- Added generic ZTE SC9832E loader what support Read firmware.
- Added generic ZTE SC9832E loader what Support simlock.
- Fixed bug with remove FRP, what give error on some cpu.
- Improved backup firmware function, if loader support this function, exe will allow read firmware and display partitions.
- Read firmware will remain in same format and can be wrote back with old exe function like before.
- Improved nvram backup to support new phones with Android 11
- Reading SN on Boot Info.
- Reading firmware on Phones which uses certificate to sign firmware.
Order here- www.Gsmservice.center
#umtpro
