⭐️13/Chimera New Exynos Models (9945/8845) - No Root, Any Bit, Any Version, Any Knox
⭐️13/06/2024⭐️Chimera New Exynos Models (9945/8845) - No Root, Any Bit, Any Version, Any Knox
🎉 Yet another Exynos update you didn't expect! 🎉
This time we're thrilled to introduce support for
• Exynos 9945
• Exynos 8845
This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device.
🔸The following devices are supported🔸
• Samsung Galaxy S24 (SM-S921B, SM-S921N)
• Samsung Galaxy S24 Plus (SM-S926B)
• Samsung Galaxy A55 (SM-A556B, SM-A556E, SM-A5560)
Available procedures: Restore / Store Backup, Unlock / Relock Bootloader, CSC Change (**), Repair Serial, Factory Reset, Remove FMM, Remove FRP, Set KnoxGuard State, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset (***), Patch KnoxGuard, Get Info, Reset Battery Status
For more detailed information, please visit our Supported models (https://chimeratool.com/en/models) page.
🎬📹If you'd like to see this working check out our videos:
• Read Codes (
• ... or our two YouTube channel where you can find various educational content: ChimeraTool (https://www.youtube.com/@chimera-tool) and ChimeraToolES (https://www.youtube.com/@ChimeraToolES).
🔸Further Exynos improvements🔸
Network Factory Reset is available on the following Japanese models:
• Samsung Galaxy A54 5G (SCG21)
• Samsung Galaxy A53 5G (SCG15)
• Samsung Galaxy A21 2020 (SCV49)
• Samsung Galaxy A20e (SCV46)
• Samsung Galaxy A30 (SCV43)
• Samsung Galaxy Tab S9 FE Plus 5G (SCT22)
*: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides here (https://chimeratool.com/en/docs) and our Test Point Database (https://chimeratool.com/test-points) to learn more.
**: CSC Change procedure is not available on Samsung Galaxy A55 models
***: if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available.
Buy Chimera Pro or Samsung activation - www.gsmservice.center
CHIMERA UPDATES:
⭐️Chimera Happy 2024! Unisoc new feature, Qualcomm new programmers, calculate NCK and more⭐
