[22-04-23] UMTv2 / UMTPro UltimateMTK2 v0.5 - Xiaomi New Patch Cert and more...
What's New:
Vivo
- Y53s (PD2103F)
- Y53s (PD2104F)
[COLOR=yellow)]Added Xiaomi New Patch Cert Function[/COLOR]
- You muse select correct model from list
- It will work even if NVRAM/DATA is fully erased
- If boot loop issue, then Wipe from Recovery and repeat operation
- Poco C3 (angelicain)
- Poco C31 (angelicain)
- Poco C55 (earth)
- Poco M4 Pro (fleur)
- Redmi 10 (selene)
- Redmi 10 Prime (selene)
- Redmi 10A (dandelion_c3l2)
- Redmi 10X 4G (merlin)
- Redmi 12C (earth)
- Redmi 6A (cactus)
- Redmi 9A (dandelion)
- Redmi 9A Sport (dandelion)
- Redmi 9AT (dandelion)
- Redmi 9C (angelica)
- Redmi 9i (dandelion)
- Redmi 9i Sport (dandelion)
- Redmi A1+ (ice)
- Redmi A1+ (snow)
- Redmi Note 10S (rosemary)
- Redmi Note 10S (secret)
- Redmi Note 11 Pro (vida)
- Redmi Note 11 Pro 4G (viva)
- Redmi Note 11S (fleur)
- Redmi Note 8 (biloba)
- Redmi Note 8 Pro (begonia)
- Redmi Note 9 (merlin)Fixed Mi Account Relock Function
- It was broken in 0.4, now should work fine
Updated Patch DM-Verity to Support Xiaomi Devices
Added Remove DM-Verity Patch Option
- In case you need to revert back to original condition
Fixed Desktop Icon being moved inside folder
Please uninstall old version and then install this one
- If you need to connect device in Preloader mode,
you must select PRELOADER in connection settings, otherwise software will try to
Crash Preloader (may not work on new security devices)
WARNING:
ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI.
ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS.
WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE.
#umtpro
