[26/01/2023] Gsm Shield Box MTK v2.5 Released
Added
- Read Simlock Info for MT6739, MT6761, MT6763, MT6765, MT6768, MT6771, MT6775, MT6779 CPU.
Code:
Code:
-- This solution use default MTK Simlock algorithm used by mostly brands what use MTK CPU.
--- Exe will display locks info and unlock code if phone have stored unlock code.
---- Many Motorola, Nokia, Huawei, Lenovo Models usually store Sim unlock code also.
----- Some brands or models can have modified security and will not support this function.
- Direct UNLOCK for phones with MT6739, MT6761, MT6765, MT6768, MT6771, MT6775, MT6779 CPU.
Code:
Code:
--- For now, is supported for direct unlock only phones with 32 bits Simlock scheme.
---- 64 bits Simlock is supported only for read info.
Please share security backups, this will allow to add Simunlock for unsupported phones also.
Added Change / Repair IMEI for phones with MT67XX CPU in flash mode and SP meta mode.
-- Some models can have meta mode disabled, in this phones SP Meta repair cannot work.
Code:
Code:
Supported CPU with this new update for IMEI Change(repair).
MT6739
MT6761
MT6763
MT6765
MT6768
MT6771
MT6775
MT6779
--- Phones with OTP IMEI and phones with signed IMEI like Alcatel, Samsung, Xiaomi, OPPO, VIVO
possible Motorola is NOT supported.
Added auto bypass security if user will select generic CPU from settings (not need to select manually).
Improved read info in meta mode, and meta mode functions.
Improved IMEI Repair in flash mode or phones MT6739, MT6761, MT6765, MT6768, MT6771, MT6775, MT6779 CPU.
#gsmshield
