️26/09/2024️Chimera Samsung (Qualcomm, Exynos) and Unisoc improvements
Samsung Exynos Improvements
Fixed a bug when reading exceptionally large PITs from EUB mode.
New models were added to be supported from EUB mode:
Samsung Galaxy Tab S6 Lite (SM-P625)
Samsung Galaxy A35 5G (SM-S356V)
Samsung Galaxy A35 5G (SM-A356N)
Samsung Galaxy Tab S9 FE Plus 5G (SM-X616N)
Available procedures (may vary device to device): Restore / Store Backup, Unlock / Relock Bootloader, CSC Change, Repair Serial, Factory Reset, Remove FMM, Remove FRP, Set KnoxGuard State, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset, Patch KnoxGuard, Get Info, Reset Battery Status.
Samsung Improvements
We've added the Network Factory Reset (Online) procedure for the following new Japanese au KDDI models via ADB mode:
Samsung Galaxy S23 FE 5G (SCG24)
Samsung Galaxy S24 Ultra (SCG26)
Samsung Qualcomm Improvements
More new programmers have arrived for Samsung Qualcomm.
The following models and BIT versions are supported:
Samsung Galaxy Z Fold3 5G (SM-F926B) BIT8
Samsung Galaxy A52s 5G (SM-A528B) BIT9
Samsung Galaxy A71 (SM-A715F) BITB
Samsung Galaxy S9 (SM-G960U) BIT9
Samsung Galaxy S22 5G (SM-S901E) BITA
Samsung Galaxy A70s (SM-A707F) BIT3
Samsung Galaxy M40 (SM-M405F) BIT2
Samsung Galaxy S20 FE (SM-G780G) BITC
Samsung Galaxy S10 (SM-G973U) BIT9
Samsung Galaxy Note10+ 5G (SM-N976U) BIT6
Samsung Galaxy S23+ 5G (SM-S916N) BIT4
On the devices above, the following procedures are now available: Factory Reset, Remove FRP, Get Info, Remove FMM, Remove MDM, Repair Boot, Root, Repair Serial, CSC Change, Remove Knoxguard (*), Reset Battery Status.
*: The solution works until the February 2024 security update.
Unisoc Improvements
We made the Repair IMEI procedure safer by identifying further device details that would make the procedure unable to run properly. In these cases, the Repair IMEI procedure is disabled.
Арзон нархда Chimera Pro or Samsung activation сотиб олиш - www.gsmservice.uz
