⭐️ #34 Chimera BiWeekly - Samsung update and various bugfixes ⭐️
➡️ Samsung Exynos, new models arrived
🔸 Samsung Galaxy F34 5G (SM-E346B)
🔸 Samsung Galaxy M34 5G (SM-M346B)
were added for Remove CC, Remove Warning Logos, FMM Remove, Read Codes, CSC Change, Knox Guard Remove, Factory Reset, FRP Remove procedures (EUB -> Exynos mode)
🔸 Various improvements for Exynos EUB procedures
➡️ Huawei
🔸 Re-enabled Soft Brick option for Huawei's Kirin SoCs
(Please note that the soft brick method will only work on older firmware versions. For newer versions the most likely working solution is to disassemble the phone and use test points!)
➡️ Utility
🔸 Added .PAC (Spreadtrum/UNISoC firmware) file support for Firmware Extractor
➡️ Bugfixes
🔸 Various UI-related bugs were fixed
🔸 Generating procedure logs was also patched
By Chimera activation from Authorized reseller - www.gsmservice.center
