What's New With the iPhone 16 Displays
Apple updated the iPhone 16 Pro and iPhone 16 Pro Max with larger displays this year, increasing the size. The iPhone 16 Pro has a 6.3-inch display, up from 6.1 inches, while the iPhone 16 Pro Max has a 6.9-inch display, up from 6.7 inches.
According to Apple, the iPhone 16 Pro models now have the thinnest borders on any Apple product, thanks to a reduction in bezels. Some of the increase in display size comes from the bezels, but the iPhone 16 Pro models are a little taller and a tiny bit wider than their predecessors.
- iPhone 16 Pro Max - 6.42 inches tall, 3.06 inches wide, 8.25mm thick, 227 grams.
- iPhone 15 Pro Max - 6.29 inches tall, 3.02 inches wide, 8.25mm thick, 221 grams.
- iPhone 16 Pro - 5.89 inches tall, 2.81 inches wide, 8.5mm thick, 199 grams.
- iPhone 16 Pro - 5.77 inches tall, 2.78 inches wide, 8.5mm thick, 187 grams.
- iPhone 16 Pro - 2622x1206 resolution at 460 ppi
- iPhone 15 Pro - 2556x1179 resolution at 460 ppi
- iPhone 16 Pro Max - 2868x1220 resolution at 460 ppi
- iPhone 15 Pro Max - 2796x1290 resolution at 460 ppi
While the iPhone 16 display also supports 1 nit minimum brightness, it does not have an always-on display or support for ProMotion.
Both models also have a new second-generation Ceramic Shield coating that Apple says is 50% tougher than the prior-generation Ceramic Shield coating used in the iPhone 15 models.
https://www.facebook.com/sharer/sha...hone-16-display-improvements/&src=sdkpreparse
How Sleep Apnea Detection Works for Apple Watch Series 10, Series 9, and Apple Watch Ultra
Tuesday September 10, 2024 4:47 pm PDT by Juli CloverApple is adding sleep apnea detection to the Apple Watch Series 10, Apple Watch Ultra 2, and the Apple Watch Series 9. Given that sleep apnea is a breathing disturbance, it's easy to assume that it requires the blood oxygen sensor, but Apple actually uses an entirely different method to detect it.
Breathing Disturbances, the name for the new Apple Watch metric, uses the built-in accelerometer to detect small movements at the wrist that are associated with interruptions to normal respiratory patterns during sleep.
The Apple Watch collects 30 days of data and then analyzes it, alerting users if there are consistent signs of moderate to severe sleep apnea. Users will see Elevated or Not Elevated readings under the Breathing Disturbances section of the Health app, and the data can be used to share with a doctor to get information on the next steps for sleep apnea diagnosis and treatment.
While aggregating data for sleep apnea detection requires 30 days of information, users can see an overall look at their nightly Breathing Disturbances in the Health app to assess the restfulness of sleep. Breathing patterns can be interrupted by alcohol, medications, and sleep position.
With sleep apnea, breathing momentarily stops during sleep, which stops the body from getting adequate oxygen and often has the effect of waking a person up. It can be a difficult condition to diagnose because it occurs during sleep, and Apple says that more than 1 billion people are estimated to be impacted worldwide.
Apple says that its sleep apnea notification algorithm was created using advanced machine learning and an extensive data set of clinical-grade sleep apnea tests, and then it was validated in a clinical study. Every participant identified by the algorithm had at least mild sleep apnea.
Apple expects sleep apnea detection to get marketing authorization from the FDA and other global health authorities in the near future, and it will be available this month in more than 150 countries.
A18 vs. A18 Pro: What's the Difference?
Tuesday September 10, 2024 4:23 pm PDT by Juli CloverApple introduced new second-generation 3-nanometer chips for both the iPhone 16 and the iPhone 16 Pro models, bringing notable improvements in performance. The iPhone 16 and 16 Plus have an A18 chip, while the iPhone 16 Pro and Pro Max have an A18 Pro chip.
The chips are similar, but there are some differences to be aware of, along with differences in the iPhone 16 and 16 Pro thermal design.
A18 and A18 Pro Shared Features
- Built on second-generation 3-nm process with smaller transistors.
- 6-core CPU with four performance cores and two efficiency cores.
- Upgraded 16-core Neural Engine optimized for running large generative models.
- Upgraded memory subsystem with 17 percent more memory bandwidth.
A18/iPhone 16 Features
The A18 has a 5-core GPU rather than the 6-core GPU in the A18 Pro.The iPhone 16 models have a new thermal design. Apple says that it updated the main logic board, centralizing chip placement and optimizing the surrounding architecture. There's a recycled aluminum substructure that dissipates heat for 30 percent higher sustained performance for gaming.
The A18 also adds hardware accelerated ray tracing, a feature that was available in the iPhone 15 Pro models with A17 Pro, but is new to the standard iPhone lineup. Hardware accelerated ray tracing is useful for gaming, and the iPhone 16 models can run all of the console-quality games that Apple touted for the iPhone 15 Pro models last year.
A18 Pro/iPhone 16 Pro Features
The A18 Pro has the same 6-core CPU as the A18, as well as the same Neural Engine, but it has one more GPU core for a 6-core GPU instead of a 5-core GPU.According to Apple, the iPhone 16 Pro maximizes thermal capacity with a machined chassis that uses 100 percent recycled aluminum. It is bonded to the titanium frame using solid state diffusion, and it is combined with a graphite clad aluminum substructure. The new thermal architecture enables a 20 percent improvement in sustained gaming performance compared to the A17 Pro.
A18 Performance
Compared to the A16 Bionic chip, the A18 Pro's CPU is 30 percent faster, and it offers the same performance while using 30 percent less power.The GPU is 40 percent faster than the A16 Bionic GPU, and it is also more efficient. It offers the same performance using 35% less power.
The new Neural Engine is 2x faster for machine learning than the Neural Engine in the A16 Bionic chip.
A18 Pro Performance
The 6-core A18 Pro CPU is 15 percent faster than the A17 Pro CPU, and it delivers the same performance using 20 percent less power. Apple says that it is the fastest CPU in any smartphone, with next-generation ML accelerators that are directly programmable for high-efficiency, high throughput and low latency computations.The 6-core GPU is 20 percent faster than the GPU in the A17 Pro, and hardware accelerated ray tracing is 2x faster.
The upgraded Neural Engine is faster and more efficient than the Neural Engine in the A17 Pro. Apple says that Apple Intelligence features run 15 percent faster on the A18 Pro than the A17 Pro.
There is a new advanced display engine for ProMotion, a new video encoder, and a new image signal processor. Combined, they process twice the amount of data for fast video encoding and improved efficiency.
https://www.facebook.com/sharer/sha...om/2024/09/10/a18-vs-a18-pro/&src=sdkpreparse
