️CHIMERA️Exynos 7884/7884B/7885/7904 - 54 models - No Root, Any Bit/Version/Knox
We haven't finished yet! This time we're thrilled to introduce support for
Exynos 7884
Exynos 7884B
Exynos 7885
Exynos 7904
This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device.
The following devices are supported:
Samsung Galaxy A10e (SM-A102N, SM-A102U, SM-A102U1, SM-A102W, SM-S102DL)
Samsung Galaxy A10 (SM-A105F, SM-A105FN, SM-A105G, SM-A105M, SM-A105N)
Samsung Galaxy A20e (SM-A202F, SCV46)
Samsung Galaxy A20 (SM-A205F, SM-A205FN, SM-A205G, SM-A205GN, SM-A205S, SM-A205W, SM-A205YN, SM-S205DL)
Samsung Galaxy A30 (SM-A3050, SM-A3058, SM-A305F, SM-A305FN, SM-A305GT, SM-A305N, SM-A305YN, SCV43)
Samsung Galaxy A30s (SM-A307FN, SM-A307G, SM-A307GN, SM-A307GT)
Samsung Galaxy A40 (SM-A405FM SM-A405FN, SM-A405S)
Samsung Galaxy A8 2018 (SM-A530F, SM-A530W)
Samsung Galaxy A7 2018 (SM-A750C, SM-A750F, SM-A750FN, SM-A750N)
Samsung Galaxy Xcover 4 (SM-G398FN)
Samsung Galaxy J7 Duo (SM-J720F, SM-J720M)
Samsung Galaxy M10s (SM-M107F)
Samsung Galaxy M20 (SM-M205G, SM-M205M)
Samsung Galaxy M30 (SM-M305F, SM-M305M)
Samsung Galaxy Tab A 8.0 2019 (SM-P205)
Samsung Galaxy Tab A 10.1 2019 (SM-T515, SM-T515N)
Samsung Galaxy Tab A 10.1 2019 LTE (SM-T517, SM-T517P)
Available procedures:Restore / Store Backup, CSC Change, Repair Serial, Factory Reset, Remove FMM, Remove FRP, Knoxguard Remove, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset (**), Unlock / Relock Bootloader (***)
For more detailed information, please visit our Supported models page.
If you'd like to see this working check out our videos:
Repair Serial
... or our two YouTube channel where you can find various educational content ChimeraTool and ChimeraToolES.
*: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides and our Test Point Database to learn more.
**:if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available.
***: This is a beta feature, and it doesn't work on 100% of the devices, but our team is working on fully supporting the procedure.
Buy Chimera Pro or Samsung activation here - www.gsmservice.uz
Chimera Full Updates history - here
