️CHIMERA️New Exynos 9810/9820/9825 - 28 models - No Root, Any Bit/Version/Knox
New Exynos 9810/9820/9825 - 28 models - No Root, Any Bit, Any Version, Any Knox
The game-changing update continues!
This time, we're proudly announcing support for Exynos 9810, Exynos 9820 and Exynos 9825. Go ahead and try it! We promise you won’t regret it.
This solution is similar to our previous Exynos update in that it uses the EUB mode* to communicate with the device.
The following devices are supported:
Samsung Galaxy F62 (SM-E625F)
Samsung Galaxy Xcover FieldPro (SM-G889A)
Samsung Galaxy S9 (SM-G960F, SM-G960N)
Samsung Galaxy S9+ (SM-G965F, SM-G965N)
Samsung Galaxy S10e (SM-G970F, SM-G970N)
Samsung Galaxy S10 (SM-G973F, SM-G973N)
Samsung Galaxy S10+ (SM-G975F, SM-G975N)
Samsung Galaxy S10 5G (SM-G977B, SM-G977N)
Samsung Galaxy M62 (SM-M625F)
Samsung Galaxy Note 10 Lite (SM-N770F)
Samsung Galaxy Note 9 (SM-N960F, SM-N960N)
Samsung Galaxy Note 10 (SM-N970F)
Samsung Galaxy Note 10 5G (SM-N971N)
Samsung Galaxy Note 10+ (SM-N975F)
Samsung Galaxy Note 10+ 5G (SM-N976B, SM-N976N)
Samsung Galaxy Tab Active 3 WiFi (SM-T570)
Samsung Galaxy Tab Active 3 (SM-T575, SM-T575N)
Samsung Galaxy Tab Active 3 (SM-T577, SM-T577U)
Available procedures: Restore / Store Backup, Unlock / Relock Bootloader, CSC Change, Change Serial, Factory Reset, Remove FMM, Remove FRP, Knoxguard Remove, Remove Lost Mode, Remove Common Criteria, Remove MDM, Remove Warnings, Restore Security Backup, Read Codes, Network Factory Reset (**)
For more detailed information, please visit our Supported models page.
If you'd like to see this working check out our videos:
Remove FRP
... or our two YouTube channel where you can find various educational content: ChimeraTool and ChimeraToolES.
Mark your calendars! More to come on the 2nd of May...
Credit costs reduced
For Samsung models Read Codes procedure prices went down!
*: In most cases, it's necessary to disassemble the phone and use hardware-testpoints to put the phone into EUB mode. Visit our guides and our Test Point Database to learn more.
**:if Read Codes is not available on your device, please try Network Factory Reset (if the procedure button is visible) to achieve the same functionality. There are devices where none is available.
