⭐️CHIMERA⭐️ Samsung, Huawei and other generic Qualcomm improvements, IMEI input fixed
Samsung MTK
New models are supported for FRP Remove procedure - available from ODIN mode, no need to disassemble the device:
Samsung Galaxy A15(SM-A155F)
Samsung Galaxy A24 (SM-A245F, SM-A245M, SM-A245N)
Additionally, IMEI Repair and Patch Cert procedures are now available for the following device:
Samsung Galaxy A14 (SM-A145P)
Samsung Exynos
New models arrived:
Samsung Galaxy A25 (SM-A256E, SM-A256B)
Samsung Galaxy Tab S9 FE 5G (SM-X516B, SM-X516C, SM-X518U)
Samsung Galaxy Tab S9 FE Plus 5G (SM-X616B, SM-X616C)
Samsung Galaxy M34 5G (SM-M346B1, SM-M346B2)
Improvements: Qualcomm Generic
Major improvements in automatic programmer handling - newer types of programmers and therefore additional Qualcomm devices are now supported
Supported procedures in Normal Mode are: Read Codes Online, IMEI Repair, Patch Cert and Demo Remove (Root required)
Available procedures in EUB mode: Backup, Bootloader Unlock, Change Csc, Change Serial, Read Codes, Factory Reset, Fmm Remove, Frp Remove, Knoxguard Remove, Lost Mode Remove, Common Criteria Remove, Mdm Remove, Remove Warnings, Security Backup/Restore, Network Factory Reset
Improvements and fixes
Core
Fixed a bug of IMEI input fields during IMEI Repair, now you can paste from clipboard easily
Samsung firmware server API changed, Chimera is adjusted so now Samsung firmware downloads work correctly
Generic Qualcomm
Fixed a bug in programmer handout (in case of a specific type of programmers), more Qualcomm devices are expected to be supported
Fixed a bug in Qualcomm procedures provided for Motorola devices
Factory Reset procedure improved (Samsung and some other phones affected)
Manual programmer selection dialog improved: More device details added to the dialog, which is shown when we're unable to provide a working programmer for the device
Huawei Qualcomm
Made improvements in Huawei ID Remove procedure: Factory Reset is now performed automatically after ID removal
Buy Chimera activation here - www.gsmservice.center
