Chimera : Samsung KnoxGuard MDM-like locks can be removed
New features and improvements
MDM Remove procedure has arrived for Samsung Exynos devices! KnoxConfigure, KnoxMobileEnrollment/BulkEnrollment and KnoxFirmwareManagement locks can be removed. The procedure works in EUB mode and the changes are permanent, the lock does not come back, even after factory reset, updates or firmware flash. It works on all Samsung security updates, up to the latest. The supported devices are:
Samsung Galaxy A04s (SM-A047F, SM-A047M)
Samsung Galaxy A12 (SM-A127F, SM-A127M)
Samsung Galaxy M12 (SM-M127F, SM-M127G, SM-M127N)
Samsung Galaxy F12 (SM-F127G)
Samsung Galaxy A13 (SM-A135F, SM-A135M, SM-A135N, SM-A135U, SM-A135U1)
Samsung Galaxy M13 (SM-M135F, SM-M135FU, SM-M135M)
Samsung Galaxy F13 (SM-E135F)
Samsung Galaxy A14 (SM-A145F, SM-A145FB, SM-A145M, SM-A145MB)
Samsung Galaxy A21s (SM-A217F, SM-A217M, SM-A217N)
Samsung Galaxy XCover 5 (SM-G525F, SM-G525N)
Samsung Galaxy A25 5G (SM-A256B, SM-A256E)
Samsung Galaxy A33 5G (SM-A336B, SM-A336E, SM-A336M, SM-A336N, SM-A3360)
Samsung Galaxy A53 5G (SM-A536B, SM-A536E, SM-A536N, SM-A536V, SM-A536W, SM-A536U, SM-A536U1, SM-A5360, SM-S536DL, SC-53C, SCG15)
Samsung Galaxy M33 5G (SM-M336B, SM-M336BU, SM-M336K)
Samsung Galaxy M34 5G (SM-M346B, SM-M346B1, SM-M346B2)
Samsung Galaxy F34 5G (SM-E346B)
Samsung Galaxy A14 5G (SM-A146B, SM-A146M)
Samsung Galaxy F14 5G (SM-E146B)
Samsung Galaxy M14 5G (SM-M146B)
Samsung Galaxy A54 5G (SM-A546B, SM-A546E, SM-A546S, SM-A546U, SM-A546U1, SM-A546V, SM-A546W, SM-A5460, SM-S546VL)
Samsung Galaxy M54 5G (SM-M546B)
Samsung Galaxy F54 5G (SM-E546B)
Samsung Galaxy Tab S9 FE 5G (SM-X516B, SM-X516C, SM-X518U)
Samsung Galaxy Tab S9 FE Plus 5G (SM-X616B, SM-X616C)
Samsung Galaxy A51 5G (SM-A516B, SM-A516N, SM-A516U, SM-A516U1, SM-A5160)
Samsung Galaxy A71 5G (SM-A716B, SM-A716S, SM-A7160)
Samsung Galaxy S20 (SM-G980F)
Samsung Galaxy S20 Plus (SM-G985F)
Samsung Galaxy S20 5G (SM-G981B)
Samsung Galaxy S20 Plus 5G (SM-G986B)
Samsung Galaxy S20 Ultra 5G (SM-G988B)
Samsung Galaxy Note 20 (SM-N980F)
Samsung Galaxy Note 20 Ultra (SM-N985F)
Samsung Galaxy Note 20 5G (SM-N981B)
Samsung Galaxy Note 20 Ultra 5G (SM-N986B)
Samsung Galaxy S20 FE (SM-G780F)
Samsung Galaxy S21 FE 5G (SM-G990E)
Samsung Galaxy S21 5G (SM-G991B, SM-G991N)
Samsung Galaxy S21 Plus 5G (SM-G996B, SM-G996N)
Samsung Galaxy S21 Ultra 5G (SM-G998B, SM-G998N)
Important note: If you still find the device locked after MDM Remove, please run a Factory reset manually for the changes to take effect. If you get an "MDM not detected" error, it is likely that you have a different lock on the device, such as Find My Mobile, SmartThings Find, Lost mode or any other. In this case, try other procedures. Knoxguard itself cannot be removed with this procedure.
Buy Chimera activation here - www.gsmservice.center
Chimera Full update history - www.mobilforum.uz
