️ CHIMERA ️Software version: 34.41.1114
️ OPPO Qcomm Dynamic FRP Remove ️
Added a new FRP Remove solution for OPPO phones with Qualcomm SoCs. It's available from EDL mode.
We can't provide an exact supported model list, because it's a generic solution which utilises a custom feature of the Qualcomm programmers.
Based on our current programmer database we've collected a list of the supported SoCs below. Please note: this solution might not work on every device that is equipped with the listed SoCs.
Qualcomm Snapdragon 450
Qualcomm Snapdragon 460
Qualcomm Snapdragon 662
Qualcomm Snapdragon 680 4G
Qualcomm Snapdragon 720G
Qualcomm Snapdragon 750G
Qualcomm Snapdragon 765G
Qualcomm Snapdragon 865
Qualcomm Snapdragon 888
The new solution uses Oppo programmers from the official firmware packs, which are named like "prog_firehose_ddr_fwupdate.elf". If Chimera can't provide you a suitable programmer you can look inside a firmware pack and pick one manually. You can use Chimera's own Firmware Extractor (Utility) for this. Be aware that the procedure can take a long time to execute (10-15 minutes) and removing the phone during the process will make the phone unable to boot. This long process usually happens only once on a device.
Order here - www.Gsmservice.center
#chimera , #noneeddongle
