DTPro Mediatek Module v4.0.0.00065DRAM Big update... VIVO New Security Support and More... [UPD: Feb 09, 2022]
Today we added VIVO MTK phones New Security (Beta).
- supported all function (without credits) such as reset FRP, IMEI repair, Factory reset
Added Support for Devices with New Security and Sensitivity when connecting the Testpoint!
BROM Info
Read IMEI's
Write IMEI's
Frp Erase/Factory Reset
You DO NOT Need a Server, Nor Downgrade (All Operations Are Directly/via Testpoint)
Security patches Tested... All the processes were carried out successfully.
October 2022
September 2022
November 2022
December 2022
January 2023
Tested Devices (Without Credist)
Tested Devices (Without Downgrade)
VIVO Y33 (V2057)
VIVO Y53s (V2058)
VIVO Y21s (V2110)
VIVO Y33s (V2109)
These Devices in other tools need Downgrade or Credits or simply NOT supported with the error (Brom disabled by Efuse[0x146])
More Models Are Supported... You need to Test and report us! (Models like: Y20 2021, S1. and More is Supported)
Added a Large database with more than 2000 compatible IDs (work like preloaders) on Devices that for X reason could NOT be read.. (These preloaders DO NOT try to write them or your Device will Die)
-reading of preloaders in patches from November 2022 to January 2023 It is Supported.. (Please Perform the Testpoint correctly.)
Note:
when performing the Test Point, try to be free of static and only place the end that goes to the Test Point in the Correct part! -Use a good quality cable.
We have remodeled all the Software. Thank you for your Opinion, all the opinions that were given in the Telegram Group were taken. (Improved UI)
Added 3 types of payload with Decryption Methods
Improved Partiticon Manager (Now connection is Stable)
Improved protocol with UFS Devices
Improved Unlock Bootloader
Improved Frp Erase and Factory Reset
Improved IMEI repair (Method4)
#dtpro, #dtprotool , #noneeddongle
