DTPro Mediatek Module v7.0.0.02(Nobody)DRAM •Huawei and Xiaomi Cert patch|IMEI repair|Fix Null| and More [UPD: October 31, 2023]
HUAWEI|HONOR
- supported all function (without credits) such as reset FRP, IMEI repair, Factory reset
# Added Support for Devices with New Security (ANDROID 12)
Brom Info
Read IMEI's
Write IMEI's
Frp Erase/Factory Reset
Full IMEI Dump [Backup]
# You DO NOT Need a Server, Nor Downgrade (All Operations Are Directly/via Testpoint)
Latest Added Models!
Huawei/Honor 2023
IMEI repair for phone with New patch Security (2023) HIGH
Honor X7A | RKY-LX01 | RKY-L21 | RKY-LX02 | RKY-LX03 | RKY-L23 | RKY-L000 | RKY-BD00
HONOR X6 - X6s | VNE-L02 | VNE-LX2 | VNE-LX3 | VNE-L03
Honor X8A | CRT-LX1 | CRT-LX2 | CRT-LX3 | CRT-L03 | CRT-L23 | CRT-L22 | CRT-BD00
Honor X5 | VNA-LX1 | VNA-LX2 | VNA-LX3 | VNA-L03 | VNA-L23 | VNA-L22 | VNA-AL00
Frp Erase|Factory Reset
IMEI Full Dump|Backup
•You can now fix security on Devices with Null IMEI [Honor X8a tested]
You do NOT need to pay Extra Activation!.. USB Dog Authorization is NOT required!...
Since the security patch: May 28, 2023, Operators have closed the Service port!
Device will enter Factory/Meta Mode - but Port Connection will be Null!
for Huawei/Honor Series 2023 Devices with security patch; June 1, 2023 You can Downgrade via OTG and after this repair the IMEI...
Added direct Factory port option! (Via Testpoint)
XIAOMI
Support all MIUI versions [include MIUI14]
Brom Info
Read IMEI's
Write IMEI's
Cert patch [Fix NVData Corrupted]
IMEI Dump
Write partitions
Erase partitions
You DO NOT Need a Server, Nor Downgrade (All Operations Are Directly/via Brom)
# Add Repair IMEI Dual SIM Flash Mode and Patch Cert For following model list
Xiaomi Redmi Note 9 [Merlin]
Xiaomi Redmi 10X 4G [Merlin]
Xiaomi Redmi Note 9 [MerlinNFC]
Xiaomi Redmi 9 [Lancelot]
Xiaomi Redmi 9 prime [Lancelot]
Xiaomi Redmi Note 8 2021 [Biloba]
Pocophone POCO F2 [Shiva]
No need original NVDATA | phones with Erased Original NV setting can be repaired
For Null state write IMEI Dump partitions... and repair IMEI after this...
Buy DT Pro 1 Year activation here - www.gsmservice.center
#dtpro, #dtprotool , #noneeddongle
HUAWEI|HONOR
Brom Info
Read IMEI's
Write IMEI's
Huawei/Honor 2023
XIAOMI
Brom Info
Read IMEI's
Write IMEI's
IMEI Dump
Write partitions
Erase partitions
