EFT Dongle Pro V 5.1.0
EFT Pro Dongle Update V5.0.8 Build 003 is released :
What’s New in This Update?
[Apple]
* jailbreak Idevice A7/A8/A9/A10/A11
* Ipwnder Idevice A7/A8/A9/A10/A11 (Checkm8) Mth2
[Apple]
* Remove Icloud Open Menu with Backup (FMI OFF with PET Token) (new Patch Apple) Beta
* jailbreak Idevice A7/A8/A9/A10/A11 (Updated)
[Allwinner]
Flash Operations: (Updated)
• Read Dump
• Write Dump Flash
New Features – Security & Locks:
• Reset FRP Lock
• Factory Reset
[Apple]
Requirements For { Remove Icloud Open Menu with BACKUP (FMI OFF with PET Token) BETA }:
📌 Steps to configure Fiddler proxy and install the certificate on iPhone:
Code:
1. On your iPhone, go to: Settings > Wi-Fi.
2. Tap the (i) icon next to your connected Wi-Fi network.
3. Scroll down to 'HTTP Proxy' and select 'Manual'.
4. In the 'Server' field, enter your computer's IP address (103.82.38.125).
5. In the 'Port' field, enter: 8888
6. Leave 'Authentication' turned OFF (unless required).
7. Open Safari on your iPhone.
8. Go to: http://103.82.38.125:8888
9. The Fiddler page will appear.
10. Tap on 'Download FiddlerRoot certificate'.
11. Tap 'Allow' to start the download.
12. Go to: Settings > General > VPN & Device Management (or Profile Downloaded).
13. Tap on 'FiddlerRoot', then tap 'Install'.
Enter your passcode if prompted, then confirm.
14. To trust the certificate, go to: Settings > General > About > Certificate Trust Settings.
15. Enable 'Full Trust' for the Fiddler certificate.
16. Sign out of the Apple Store, then sign in again.
17. Go to PHOTOS → Turn On, then Turn Off Shared Albums.
18. Turn off Wi-Fi.
19. Back up your device again.
Buy EFT PRO 1, 3, 6 or 12 months activation 👉 www.gsmservice.center
EFT Pro updates full history - here
