EFT Pro Dongle Update V4.6.6 Build 001 is released :
[SPD]
Added GENERIC SPD V1
Fix Bugs
[MTK]
Update GENERIC MTK V5
Update GENERIC MTK 2023
Add Tecno Pop 7 BF6
CPU MT6761
[MTK META]
Added META Read Info All MTK CPU
Added META Factory Reset All MTK CPU
Added META Factory Reset MT62XX
Added META Repair IMEI All MTK CPU
Added in META Mode ( Infinix - Tecno - Itel ) All Model With Auth (First in the world)
Read Info With Auth
Factory Reset With Auth
Repair IMEI With Auth
CPU List:
MT8135/MT8127/MT6595/MT8173/MT6735/MT6535M/MT6753/MT8163/MT8590/MT6580/MT6755/MT6797/MT6737T/MT6737M/MT6750
MT6757/MT6570/MT8167/MT6799/MT6763/MT6758/MT3367/MT6739/MT6771/MT8695/MT6765/MT6761/MT8666/MT6779/MT8518
MT3369/MT6768/MT8168/MT6785/MT6885/MT6873/MT6853/MT6893/MT6833/MT8696/MT6725/MT6877
MT6781/MT6983/MT6879/MT6895/MT6855/MT6789/MT6985/MT6886
INFINIX
and more..Infinix X510 MT6580
Infinix X604 MT6763
Infinix Note 4 X572 MT6753
Infinix Zero 5 X603 MT6757
Infinix Note 5 X604 MT6763
Infinix Note 5 Stylus X605 MT6763
Infinix Smart HD 2021 X612 | X612B MT6761
Infinix Hot 7 X624 | X624B MT6765
Infinix S4 X626 | X626B MT6765
Infinix Smart 3 Plus X627 | X627V | X627W MT6761
Infinix Hot 8 X650B | X650C | X650D MT6765
Infinix S5 X652 MT6765
Infinix S5 lite X652 | X652A | X652B | X652C MT6765
Infinix Hot 9 X655 | X655C | X655D | X655F MT6765
Infinix Hot 9 Pro X655F MT6765
Infinix Smart 5 X657 | X657B | X657C MT6761
Infinix S5 Pro X660 | X660B | X660B MT6765
Infinix Smart 4 Plus X680D MT6765
Infinix Hot 10 X682B MT6768
Infinix Hot 10 X682C MT6768
Infinix Zero 8 X687 MT6785
Infinix Hot 10 Play X688C | X688B MT6765
Infinix Hot 10s X689 | X689B | X689D MT6768
Infinix Hot 10T X689 | X698B | X698C | X698D | X698F MT6768
Infinix Hot 11 X662 | X662B MT6768
Infinix Hot 9 Play X689B MT6768
Infinix Note 7 X690 MT6768
Infinix Note 7 X690B | X690C MT6768
Infinix Note 8 X692 MT6768
Infinix Smart 2 X5515 | X5515F | X5515I MT6739
Infinix Smart 3 X5516 | X5516B | X5516C MT6761
Infinix Note 8i X683 MT6768
Infinix Zero 8i X687B MT6785
Infinix Note 10 Pro X695 | X695C | X695D MT6785
Infinix Note 10 X693 MT6768
Infinix Hot 10i X659B | X659 MT6768
Infinix Hot S X521 MT6753
Infinix Smart 4 X663 | X663B MT6761
Infinix Note 11s 11s MT6781
Infinix Note 11 Pro X697 MT6781
Infinix Hot 11s X6812 MT6768
Infinix Hot 11 Play X688B MT6765
Infinix Note 11i 11i MT6768
Infinix Note 11 Note_11 MT6768
Infinix Zero X Pro X6811B | X6811 MT6785
Infinix Hot 10i X658E | X658B MT6768
Infinix Note 7 Lite X656 MT6768
Infinix Smart 4 X653 | X653C MT6761
Infinix Note 6 X610B MT6765
Infinix Smart 2 HD X609 | X609B MT6580
Infinix Hot 6 X606 | X606B | X606C | X606D MT6737M
Infinix Smart 2 Pro X5514 MT6739
Infinix Hot 4 Pro X5511 MT6737M
Infinix Hot 4 X557 MT6580
Infinix Hot 2 X510 MT6580
Infinix Hot 3 X554 MT6580
Infinix Hot 7 Pro X625 MT6757
Infinix Zero 5 Pro X603B MT6757
Infinix Hot 8 Lite X650 MT6580
Infinix Zero 5G Zero_5G MT6877
Infinix Hot 20i X665E MT6765
Infinix Hot 30 X6831 MT6768
Infinix Hot 12 Play X6816 MT6765
Infinix Smart 6 Plus X6823c MT6765
Infinix Hot 20 Play X6825 MT6765
Infinix Note 30 5G X6711 MT6833
TECNO
Tecno AX8 Tecno_AX8 MT6757
Tecno B1P Tecno_B1P MT6580
Tecno CA6 Tecno_CA6 MT6737T
Tecno CA7 Tecno_CA7 MT6737T
Tecno CA8 Tecno_CA8 MT6763
Tecno Camon 11 CF7 | CF7k | CF7S MT6761
Tecno Camon 11 Pro CF8 MT6765
Tecno CX Air Tecno_CX_Air MT6763
Tecno F2 Tecno_F2 MT6580
Tecno F2 LTE Tecno_F2_LTE MT6739
Tecno F3 Tecno_F3 MT6580
Tecno F4 Tecno_F4 MT6739
Tecno Spark Pro Tecno_K8 MT6737M
Tecno DroiPad 8H TECNO_8H MT6582
Tecno Camon C5 C5-H351 MT6735
Tecno Camon C7 C7-H355A MT6735
Tecno Spark TECNO K7 MT6580
Tecno A52 Lite A52Lite-F8018E MT6580
Tecno A52s Lite A52SLite-F8018AJ MT6580
Tecno Pop 2 B1-F8018BC MT6580
Tecno Pop 2 Pro B2-F8017DE MT6580
Tecno A9 Phantom 6 Plus A9-H971A-M MT6797
Tecno Phantom 6 A6-H551C1-M MT6755
Tecno Phantom 9 AB7-H618A MT6765
Tecno 7CS Tecno_7CS MT6582
Tecno IN5 IN5 MT6737T
Tecno Camon 12 CC7 MT6765
Tecno Camon 12 Pro CC9 MT6765
Tecno Camon 15 CD7 MT6765
Tecno Camon 15 Air CD6 | CD6S MT6765
Tecno Camon 15 Premier CD8j MT6765
Tecno Camon 15 Pro CD8 MT6765
Tecno Camon 16 S CD6j MT6765
Tecno Spark 5 Pro KD7H | KD7S MT6765
Tecno Camon 12 Air CC6 MT6761
Tecno Spark 3 KB7 | KB7J MT6761
Tecno Spark 3 Pro KB8 MT6761
Tecno Spark 4 KC2 | KC2J | KC8S MT6761
Tecno Spark 5 Air KD6 | KD6A MT6761
Tecno Camon 16 CE7 | CE9H MT6768
Tecno Camon 16 Pro CE8 MT6768
Tecno Camon 16 SE CE7J MT6768
Tecno Camon 17 CG6 | CG6J
Tecno Camon 17P CG7 | CG7N
Tecno Camon 16 Premier CE9
Tecno Camon 17 Pro CG8 MT6785
Tecno Phantom X AC8 MT6785
Tecno Camon X Camon X MT6763
Tecno Camon X Pro Camon X Pro MT6763
Tecno Spark 7 Pro KF8 MT6768
Tecno Spark 6 Go KE5 | KE5j | KE5S MT6765
Tecno Spark Go KC1 MT6761
Tecno Spark 7 KF6 | KF6h | KF6i | KF6j | KF6k MT6765
Tecno Spark Go 2021 Spark_Go_2021 MT6761
Tecno Spark 7T KF6p MT6765
Tecno Pova LD7 | LD7j MT6768
Tecno Spark Power 2 Air Spark_Power_2_Air MT6761
Tecno Spark Go 2020 KE5 MT6761
Tecno Spark Go Plus Spark_Go_Plus MT6761
Tecno Spark Power Tecno_Spark_Power MT6761
Tecno Camon i4 Tecno_Camon_i4 MT6761
Tecno Camon IClick2 Camon_IClick2 MT6765
Tecno Camon iAce 2X Camon_iAce_2X MT6761
Tecno Camon iAce Camon_iAce MT6739W
Tecno Camon iClick Camon_iClick MT6763
Tecno i7 Tecno_i7 MT6750T
Tecno Camon i Sky Camon_i_Sky MT6739W
Tecno Spark 7P KF7j MT6771
Tecno Camon CX MT6750
Tecno WX4Pro WX4Pro MT6737M
Tecno Pouvoir 4 LC7 | LC7S MT6761
Tecno Spark 8 KG6 MT6765
Tecno Spark 4 Air KC6 | KC6S | KC1j MT6761
Tecno Camon 18 CH6-OP MT6768
Tecno Spark 8P 8P MT6768
Tecno Camon 18 Premier CH9 | CH9n MT6781
Tecno Camon 18P CH7 | CH7n MT6781
Tecno Pova 2 LE7 | LE7n MT6768
Tecno Phantom 8 AX8 MT6757
Tecno IN2 H391 MT6739
Tecno Camon 18T CH6T MT6768
Tecno Pova Neo LE6 MT6762
Tecno Pouvoir 1 LA6 MT6580
Tecno Pouvoir 2 LA7 MT6739
Tecno Pouvoir 2 Air LB6 MT6580
Tecno Pouvoir 2 Pro LA7 Pro MT6739
Tecno Pouvoir 3 LB7 MT6739W
Tecno Pouvoir 3 Air LC6 | LC6a MT6761
Tecno Pouvoir 3 Plus LB8 | LB8a MT6765
Tecno SA6S SA6S MT6580
Tecno Spark 4 Lite BB4k MT6761
Tecno Spark 6 KE7 MT6768
Tecno Spark 6 Air KE6 | KE6j MT6761
Tecno Spark 7 Go KF6m MT6765
Tecno Pop 4 Air BC1 MT6580
Tecno Pova 5G Pova_5G MT6877
Tecno Pop 5 Pro BD4j | BD4H MT6761
Tecno Camon 19 CI6 MT6769
Tecno Spark 10 KI5Q | KI5N MT6765
and more..
ITEL
Itel A32F F8007 MT6580
Itel 11 Plus Itel_11_Plus MT6580
Itel S12 Itel_S12 MT6580
Itel A11 Itel_A11 MT6572
Itel A13 Plus Itel_A13_Plus MT6580
Itel A15 Itel_A15 MT6580
Itel S31 Itel_S31 MT6580
Itel A52 Itel_A52 MT6580
Itel A62 Itel_A62 MT6739
Itel Alpha W5503 MT6580
Itel it1405 Itel_it1405 MT6572
Itel P13 Plus Itel_P13_Plus MT6580
Itel P32 Itel_P32 MT6580
Itel P51 Itel_P51 MT6580
Itel S13 Pro Itel_S13_Pro MT6580
Itel S32 Itel_S32 MT6580
Itel S32 Lite Itel_S32_Lite MT6737M
Itel S33 Itel_S33 MT6580
Itel A43 Itel_A43 MT6735
Itel S21 I_S21 MT6737M
Itel A44 Pro F3706 MT6737M
Itel A52SLite F8018AJ MT6580
Itel S32 Mini W5003 MT6580
Itel S11 Plus S11 Plus MT6580
Itel S41 S41 MT6737M
and more..
Buy EFT PRO 1, 3, 6 or 12 months activation here - www.gsmservice.center
EFT Pro updates full history - here
