EMT v3.29.00 Released - Discussion Here [UPD: Nov 17, 2022]
First in China! No Mi Assistant Tool / Just One-Click
Flash Recovery Firmware - 2 Credits
- You can flash recovery firmware directly via sideload mode
- Any Xiaomi, Redmi, POCO devices with sideload mode is supported
- Supported auto display the recommend firmware link in the logs
- Suggested to flash recommend firmware, same or high version
- If you try to flash a lower version, the operation may fail
- It depends on Xiaomi allow you to flash current firmware or not
TIPS: This function can be solve the problems of mi assistant tool not recognizing, 2015/2011 error code and other tool stuck in 33% bugs!
OPPO MODULE:
First in World! No Auth / No Credits / Just One-Click
Following Models by EDL Mode:
Remove Demo Mode
- A11S (PDVM00)
- A32 (PDVM00)
- A33_2020 (CPH2137)
- A36 (PESM10)
- A53_2020 (CPH2127,CPH2131)
- A53S_EMMC (CPH2135,CPH2139)
- A53S_UFS (CPH2135,CPH2139)
- A73 (CPH2099)
- A74 (CPH2219)
- A76 (CPH2375)
- A95_4G (CPH2365)
- A96 (CPH2333)
- ACE2 (PDHM00,PDHT00)
- F17 (CPH2095)
- F19 (CPH2219)
- F19S (CPH2223)
- F21 PRO (CPH2363)
- RENO 10X ZOOM (PCCM00,PCCT00,CPH1919)
- RENO 3 PRO_5G (PCRM00,PCRT00)
- RENO3 YOUNG (PCLM50,PCLT50,PCRT01)
- RENO 4 PRO_4G (CPH2109)
- RENO 4 PRO_5G (PDNM00,PDNT00,CPH2089)
- RENO 4_4G (CPH2113)
- RENO 4_5G (PDPM00,PDPT00,CPH2091)
- RENO 5 PRO_5G (CPH2207)
- RENO 5 PRO+_5G (PDRM00,PDRT00)
- RENO 5_4G (CPH2159)
- RENO 5_5G (PEGM00,PEGT00,CPH2145)
- RENO 5A (CPH2199,A1030P)
- RENO 5K (PEGM10,PEGT10)
- RENO 6 LITE (CPH2365)
- RENO 6 PRO_5G (CPH2247)
- RENO 6 PRO+_5G (PENM00)
- RENO 6_4G (CPH2235)
- RENO 7_4G (CPH2363)
- RENO 7_5G (PFJM10)
- RENO ACE (PCLM10,PCLT10)
- RENO_5G (CPH1921)
- FIND N (PEUM00)
- FIND X2 (PDEM10,PDET10,CPH2023)
- FIND X2 LITE (CPH2005)
- FIND X2 NEO (CPH2009)
- FIND X2 PRO (PDEM30,PDET30,CPH2025)
- FIND X3 (PEDM00)
- FIND X3 LITE_5G (CPH2145)
- FIND X3 NEO_5G (CPH2207)
- FIND X3 PRO (CPH2173,PEEM00,PEET00)
- FIND X5 (PFFM10,CPH2307)
- K10 (CPH2373)
- K10 PRO (PGIM10)
- K10 ENERGY EDITION (PERM10)
- K7_5G (PCLM50)
- K9_5G (PEXM00)
- K9S (PERM10)
- PAD AIR (OPD2102,X21N2)
- PAD (OPD2101)
- REALME 6 PRO (RMX2061,RMX2063) - BETA
- REALME 7 PRO (RMX2170) - BETA
- REALME 7I (RMX2103,RMX2104)
- REALME 8 PRO (RMX3081) - BETA
- REALME 9 (RMX3521)
- REALME 9 5G SPEED EDITION (RMX3461)
- REALME 9I (RMX3491)
- REALME C15 QUALCOMM EDITION (RMX2195,RMX2192,RMX2194)
- REALME C17 (RMX2101)
- REALME GT 2 (RMX3310,RMX3311,RMX3312)
- REALME GT NEO 2 (RMX3370)
- REALME GT NEO 3T (RMX3372)
- REALME GT_5G (RMX2202)
- REALME GT MASTER EDITION (RMX3363,RMX3360,RMX3361)
- REALME GT MASTER EXPLORER EDITION (RMX3366,RMX3360)
- REALME Q3 PRO CARNIVAL (RMX3142)
- REALME Q3_5G (RMX3161)
- REALME Q3S (RMX3461,RMX3463)
- REALME Q3T (RMX3462)
- REALME Q5 PRO (RMX3372)
- REALME X2 PRO (RMX1931)
- REALME X3 (RMX2081,RMX2083)
- REALME X3 SUPERZOOM (RMX2085,RMX2086)
- REALME X50 PRO_5G (RMX2071,RMX2075,RMX2076)
- REALME X50 PRO PLAYER EDITION (RMX2072)
- REALME X50_5G (RMX2144)
- REALME X50M_5G (RMX2141,RMX2142)
- REALME X50T_5G (RMX2052)
- REALME X50 CHINA_5G (RMX2051,RMX2025)
- Added Xiaomi Module "Flash Recovery Firmware" function, supported flash recovery firmware via sideload mode
- Added OPPO Module "Remove Demo Mode" function, supported oppo qualcomm series models
- Fixed Oppo Module Qualcomm SnapDragon 865 solution
gsmservice.uz - Янгиликлар ! Акция ва Супер чегирмалар!, [17.11.2022 18:15]
About Xiaomi "Flash Recovery Firmware" function description:
1.This function working for any Xiaomi/Redmi/POCO devices with sideload mode, supported flash recovery firmware via sideload mode!
2.This function can be solve the problems of mi assistant tool not recognizing, 2015/2011 error and other tool stuck in 33% bugs!
3."Flash Recovery Firmware" Operation Process:
1).Confirm model and select correct model
2).Put phone into SIDELOAD mode (Recovery mode, Select "Connect MiAssistant"), Connect USB Cable
3).Press "Flash Recovery Firmware" and then select recovery firmware.
4).Waiting the process finish.
TIPS: If you facing "Reading Validate ... Failed" during the operation, suggested to downloading the recommend firmware and then select recommend firmware try it again!
#emt, #noneeddongle
