EMT v3.30.00 Released - Discussion Here [UPD: Jan 16, 2023]
Added Redmi NOTE 11/11T_5G/11 PRO/11 PRO+, POCO M4 PRO_5G, MI 11I_5G etc models, Supported Unlock Bootloader, Relock Bootloader etc functions!
Updated the "Flash Recovery Firmware" Solution of Xiaomi Module, Support some models that failed to reading the recommend firmware, support some firmware that failed to reading the validate!
No Auth / No Credits
Following Models by BROM Mode:
- REDMI NOTE 11/11T_5G (EVERGO)
- POCO M4 PRO_5G (EVERGREEN)
- REDMI NOTE 11 PRO/PRO+ (PISSARRO)
- MI 11I_5G (PISSARRO)
- Support some models that failed to reading the recommend firmware
- Support some firmware that failed to reading the validate
- Compatible with special pc environment without file selection window
- Improved the "Flash Recovery Firmware" operation judgment
- Added Redmi NOTE 11/11T_5G/11 PRO/11 PRO+, POCO M4 PRO_5G, MI 11I_5G etc models, Supported Unlock Bootloader, Relock Bootloader etc functions!
- Updated the "Flash Recovery Firmware" Solution of Xiaomi Module
About Xiaomi "Flash Recovery Firmware" function description:
1.This function working for any Xiaomi/Redmi/POCO devices with sideload mode, supported flash recovery firmware via sideload mode!
2.This function can be solve the problems of mi assistant tool not recognizing, 2015/2011 error and other tool stuck in 33% bugs!
3."Flash Recovery Firmware" Operation Process:
1).Confirm model and select correct model
2).Put phone into SIDELOAD mode (Recovery mode, Select "Connect MiAssistant"), Connect USB Cable
3).Press "Flash Recovery Firmware" and then select recovery firmware.
4).Waiting the process finish.
TIPS: If you facing "Reading Validate ... Failed" during the operation, suggested to downloading the recommend firmware and then select recommend firmware try it again!
#emt, #noneeddongle
#emt, #noneeddongle
