EMT v4.08.00 Released - Discussion Here [UPD: Jan 26, 2026]
Added OPPO/REALME/ONEPLUS SnapDragon 8GEN1, 870,865-DDR4/DDR5 series models no auth solution, Supported Flash, Read/Erase/Write Partition, Factory Reset, Reset FRP etc functions!
Added OPPO/ONEPLUS "Pack Super.img (MULTI files)" and "Pack Super.img (META files)" functions!
OPPO MODULE:
No Auth / No Credits
Following Models by EDL Mode:
- FIND X5 PRO (PFEM10,CPH2305)
- REALME GT2 PRO (RMX3300,RMX3301)
ONEPLUS MODULE:
- ONEPLUS 10 PRO (NE2210,NE2211,NE2213,NE2215,NE2217)
- Added OPPO/REALME/ONEPLUS SnapDragon 8GEN1, 870,865-DDR4/DDR5 series models no auth solution, Supported Flash, Read/Erase/Write Partition, Factory Reset, Reset FRP etc functions!
- Added OPPO/ONEPLUS "Pack Super.img (MULTI files)" function, Support packing super.img with multiple super.img files!
- Added OPPO/ONEPLUS "Pack Super.img (META files)" functions, Support packing super.img with OPLUS META firmware files!
- Improved Qualcomm protocol
INFOMATION
About "Packing Super.img (MULTI files)" operating process:
1).Unpack the ofp file after downloaded firmware
2).Run EMT, Select the OPPO/ONEPLUS Module, Press "Packing Super.img (MULTI files)" function
3).Select the super files in the ofp unpacking directory (format: super.*.*.img)
4).Waiting for operation complete
TIPS: The packed super.img file is non-sparse format, the rawprogram0.xml file needs to be modified before flashing (find the super line and change the sparse="true" to "false")
About "Packing Super.img (META files)" operating process:
1).Unzip the firmware file after downloaded firmware
2).Run EMT, Select the OPPO/ONEPLUS Module, Press "Packing Super.img (META files)" functions
3).Select the correct json file in the META directory (format: super_def.*.json)
Арзон нархда EMT activation сотиб олиш -www.Gsmservice.uz
#emtupdate, #noneeddongle
Emt updates Full history - here
