F64 Multi-Programming Edition V1.01.31.2026 Update!
*** Box Firmware Update is Recommended before using this updated software ***
1. Added support for upto 32 F64 boxes connected together in 1 computer.
* Each F64 box should have it's own FOLDER and Special Multi-Programming Edition EXE
* An external 5V (1000 mA) USB C External power source should be used for each F64 box
* Your computer should have enough resources to handle the bandwidth and power demands
* You must use the Multi-Programming Edition EXE for this feature
2. RPMB Key Read for NON-SECURE DL6DAB : KMDL6001DA-B425
* This feature only works after eMMC FFU + Full Factory Reset
* Do not use this feature on SM-A055F BIT 10 and BIT 11
* Do not use this on a phone that does not provision the RPMB of a blank eMMC
* Do not use this if you do not understand the 3 statements above
3. Added support for Oppo, Realme and Oneplus 2026 Official Firmware Files
4. Added support for loading single partition file automatically from the same folder
5. Added support for Unisoc PAC and XML files for UFS Provision.
6. Added support for MTK Scatter XML files for UFS Provision.
7. Automatically skips Unisoc RF/IMEI partitions loaded from Factory Firmware Files.
8. Improved Android Factory Reset for Oppo, Realme, Vivo and iQOO
9. Vivo, iQOO, Jovi Read Device Info Added (Thanks to hello-firmware.com)
10. Fixed Security Patch Version Reading for A16 Vivo, iQOO, Jovi phones.
11. Added TXN option "AUTO" which automatically switches between TXN values
12. Added New Samsung eMMC FFU:
RP64AB : KMRP60014A-B614 (Contributed by 0x9k (Circuit Knight X))
13. Behind the scene bug fixes (Thanks, Mr.UPROM!)
14. SkHynix eMMC detection bug improvements (Thanks to hello-firmware.com)
Flash64 боксни бугун сотиб олиш - hereFlash64 full updtaes histioryшу ерда (https://mobilforum.uz/threads/flash64-updates.4669/)
