F64 Realtime Hex Editor, Themes, Image Viewer, Speed Graph and 2026 Flashing UpdatesV1.02.26.2026 Update!
1. Added Realtime Hex Editor for direct partition editing
* Partitions larger than 1GB will not have the auto-backup feature. Manually SAVE file using the Save Button.
* Partitions smaller then 1GB will have the auto-backup feature.
2. Added Application Theme selection (Night, Graphite, Light)
3. Added Image Viewer
4. Added Line Graph for showing Transfer Speed Logs (Minimum, Maximum, Average and Current Speed)
5. Added Country/Provider Variant selection for Vivo factory files (MTK, Qualcomm and SPD/Unisoc) (Requested by D Stealth Warrior)
6. Added full display of all files used when a partition is flashed with more than 1 file (Requested by D Stealth Warrior)
7. Added Qualcomm rawprogram.xml type selection (unsparsed, no_qcn etc...)
* This will select the correct combination of XML files based on the first file selected by the user
8. Added new option "Restart USB" when closing application
* This will automatically Cycle the used USB Port in case a stall has occurred
* The application with automatically restart with the newly refreshed USB Port
9. Bug fixed for Android Verified Boot (AVB) Process on UFS Qualcomm Phones
10. Bug fixed for flashing multi-sparsed files
11. Bug fixed for Factory Provisioning Micron UFS 4.0 and UFS 4.1
12. Bug fixed for MTK MT6833 preloader loading (Reported by Samim Vai)
13. Bug fixed for MTK MT6768 preloader loading via scatter.txt (Reported by Giovanni Lucas Da Paz)
Flash64 full updtaes histiory 👉 шу ерда (https://mobilforum.uz/threads/flash64-updates.4669/)
Flash64 боксни бугун сотиб олиш - шу ерда
