Flash64 Updates
Gsmservice Support
Staff member
Premium
UFS: Full compatibility with versions 1.0 to 4.1, achieving HS-Gear speeds up to 420 MB/s
eMMC: Versions 4.1 to 5.1, with up to 8-bit HS200 speeds of 200 MB/s.
Nano Memory Card (NM): Up to 4-bit 90 MB/s.
MicroSD: SDSC, SDHC, SDXC, and SDUC up to UHS-I speeds of 104 MB/s.
Flash64 Ultra also supports modern staple interfaces such as RFFE, JTAG, SPI, I2C, and UART that can be used to further diagnose problems found in modern-day electronics.
The Flash64 Ultra boasts cutting-edge connectivity and user-friendly features, including:
Dual USB 3.2 Gen 1 and USB 2.0 interfaces for fast and reliable connections.
Wireless BLE 5.0 and WiFi 4 for added convenience.
NFC-based warranty tracking for seamless service management.
A vibrant 1.69-inch IPS TFT LCD display for real-time monitoring.
Customizable RGB lighting to suit your workspace aesthetic.
Currently, Flash64 supports the following firmware/flash file formats for direct flashing:
Binary Files
IMG Files
Samsung Tar MD5 Files
Samsung Tar Files
Qualcomm XML Files
MTK Scatter Files
MTK XML Scatter Files
.BAT Batch Files
.SH Shell Script
Spreadtrum (Unisoc) PAC Files
OnePlus OPS Files
ASUS RAW Files
Motorola Flash XML
Motorola Service XML
Huawei Update APP Files
Sony Update XML Files
LG KDZ Files
Flash64 also supports Unpacking with Checksum verification for the following packaged files:
Android payload.bin
Oppo OFP Files
OnePlus OPS Files
Unisoc PAC Files
ASUS RAW Files
Sony SIN Files
Sony FTF Files
LG KDZ Files
Flash64 does support the newest version of MTK Scatter Files with Regional Provisioning in XML format used in the newest Oppo, Vivo etc 5G phones
Flash64 New Update! V1.02.01.2025!
02.01.2025 - Initial Update and Bug Fixes
1. Added Auto LBA Skip on UFS with Secure Write Protected Blocks
2. Added UFS Secure Write Protecttion Removal (WP Remove)
Use this option at your own risk
According to our tests, most UFS will suffer 100% Data Loss with
a very few exception listed below
Brand | UFS Specification | Data Status after WP Remove
Samsung | 2.0 | NO Data Loss
Samsung | 2.1 | NO Data Loss
Samsung | 2.2 | NO Data Loss
Samsung | 3.0 | NO Data Loss
Samsung | 3.1 | NO Data Loss
Samsung | 4.0 | WARNING 100% Data Loss on all LUNs !!! - make backup all LUNs !!!
YMTC | 2.2 | NO Data Loss
Other Brands (SkHynix, Micron, KIOXIA etc...) will experience 100% Data Loss on all LUNs !!! - make backup all LUNs !!!
Flash64 New Update! V1.02.05.2025!
Beta Releases
02.05.2025 - End User Requests and Bug Fixes
1. Added eMMC Boot Config Information in Connection Logs
2. Added Auto LBA Skip on eMMC with Secure Write Protected Blocks
3. Added Detailed Connection ERROR Resolution for UFS ISP
4. Added EMMC Firmware Contributed by End Users:Knotthailand
DV6DAB : KMDV6001DA-B620
GD6BMB : KMGD6001BM-B421
DC6DMB : KMDC6001DM-B625
5. Fixed GUI Freeze on UFS and EMMC Read Timeouts
Flash64 New Update! V1.02.14.2025!
Beta Releases
02.14.2025 - End User Requests and Bug Fixes
1. Fixed sboot target partition from PIT for the following Exynos SoC:
* Reported by MasterUnlockGSM from Venezuela
Exynos 1280
Exynos 1330
Exynos 1380
Exynos 1480
Exynos 1580
Exynos 2200
Exynos 2400
2. Added PIT File Support for UFS Provisioning
3. Fixed MTK Preloader Boot Relay Table for newer SoCs (UFS and EMMC)
* Reported by Knotthailand
4. Added SkHynix EMMC FFU files for:
hB8aP>
hC8aP>
hC9aP3
hDEaP3
* These eMMC Firmware will allow RPMB Key Reading, Unlimited Repartitioning, WP Removal and CID/CSD Write
* Performing FFU on SK Hynix eMMC will NOT result in data loss.
* Avoid performing multiple FFU operations on the same eMMC, as its firmware uses a static NAND page address.
This means the page cannot be relocated if bad blocks begin to develop.
5. Added the ability to set the working directory using the HOME button located at the lower right corner of the software.
* Suggested by MasterUnlockGSM from Venezuela
6. A separate rawprogram.xml per LUN will now be generated during partition backups.
7. Enhanced the speed of FFU reading for Samsung eMMC.
8. UFS VCC is now set to 2.80V by default.
9. Added support for UFS 4.1 new descriptors, attributes and flags.
Flash64 New Update! V1.02.23.2025! EMMC Firmware Added, New FPR and Bugs Fixed
02.23.2025 - End User Requests and Bug Fixes
1. Fixed GPT and SGPT Sizes for newer MTK based Soc
2. Fixed FRP on older Androids - Thanks to KUMAR VISHWAKARMA
3. Added EMMC Firmware Contributed by End User
3V6CAB : KM3V6001CM-B708 (by Bilal Akash)
4. Added New FRP Remove Option for persistent partition data fill
* You can now select to fill partition with 0xFF or 0x00
5. Added EMMC Firmware Contributed by End Users:
3V6CBB : KM3V6001CM-B705 (by yu luosheng)
6. UFS Amplitude Setting now defaults at 316 mV for more compatibility
⚡️Flash64⚡🔥 ISP AI CONNECT🔥! New Update! V1.03.21.2025d!
03.21.2025d - End User Requests and Bug Fixes
1. Fixed eMMC Qualcomm GPT file loading. (Thanks to SadaM)
2. Added eMMC RPMB Set Counter to match previous RPMB Counter on Qualcomm Phones (Requested by Ramana)
3. Fixed Samsung eMMC RPMB Size Change (Reported by Abdullah Rasheed)
4. Fixed eMMC RPMB Read Counter Stuck on ISP
5. Added automatic loading of Qualcomm gpt_main0.bin, gpt_main1.bin etc in partition list.
* With automatic Repartition.
6. Added Android Boot slot Change A/B
7. Remove Factory Reset Button in Partition List
* Now you need to use Erase User Data and choose the proper option best suited for
your phone. Do this AT YOUR OWN RISK.
8. Added Samsung eMMC Firmwares
CKTA42 : KLMCG2KCTA-B041
CUTA42 : KLMCG2UCTA-B041
DD68MB : KMDD60018M-B320
DH6DAB : KMDH6001DA-B425
DP6DBB : KMDP6001DB-B425
DUTA42 : KLMDG4UCTA-B041
DV6DBB : KMDV6001DB-B620
DV6DMB : KMDV6001DM-B620
DX68MB : KMDX60018M-B425
FE62MB : KMFE60012M-B214
GP6BMB : KMGP6001BM-B514
GX6BAB : KMGX6001BA-B514
QX63AB : KMQX60013A-B419
QX63MB : KMQX60013M-B419
9. Added SkHynix eMMC Fimrwares
H8G4a2
HAG4a2
HCG8a4
10. Fixed SGPT Generation for MTK and Qualcomm
11. Added AI Connect (Autonomous Interaction)
This feature will automatically reconnect if communication
errors are detected. This helps when connecting phones
via ISP using USB power only (No Vcc and VccQ). The feature
is enabled by default.
12. Added support for malformed GPT Headers from some Moto Phones.
13. Added EMMC Firmware Contributed by End User
QE63MB : KMQE60013M-B318 (by s.l.m.)
14. Fixed Erase of very small partition sizes
15. Remove nag Screen "Please click Yes 3 times"
16. Increased UFS Inactivity Timeout
⚡️Flash64⚡️ New Update! V1.03.29.2025!
1. Fixed Vivo Red State after FRP.
*** Always Select "FRP New Security (2024, 2025) for newer Android 14 and 15 phones
2. Added a more visible Location for the following information:
Boot Partition
Reference Clock
Configuration Descriptor (OTP)
Partition Setting Locked (eMMC)
3. Added dLUNumWriteBoosterBufferAllocUnits in saving and writing UFS provision.xml
4. Improved eMMC ISP Read Speed
5. Improved Samsung FRP Remove
⚡️Flash64⚡️ New Update! V1.04.30.2025!
1. Fixed Android Info Reading for Motorola Phones
2. Fixed Boot Mode eMMC FFU to not change CID
3. Fixed Micron UFS Provision Bug
4. Added UFS Erase all LUNS Button
* Use this to fix "slow" UFS IC
* This is a safer option than Provisioning the UFS
* Does not require OTP Unlock
* Does not Erase RPMB Data
* Does not Erase Write Protected Areas
5. Added eMMC Erase All Partitions Button
* Use this to Erase all Data from the eMMC
* Resets eMMC BOOT Config
6. Added Samsung eMMC Firmwares
DUTB42 : KLMDG4UCTB-B041
3H6CAB : KM3H6001CA-B515
DP68MB : KMDP60018M-B425 (by 0x9k)
DV6DAB : KMDV6001DA-B620 (by 0x9k)
7. Added Generic Android OEM Unlock
* Additional Steps may be required to
fully unlock the bootloader of the phone
depending on the phone brand/manufacturer
8. Added RPMB Write for UFS
9. Improved Read/Backup Partition file (rawprogram.xml)
10. Added EXT_CSD as part of eMMC Partition List
11. Added Primary GPT and Backup GPT Check upon IC Detection (Thanks to KHUMAR ALOK VISHWAKARMA)
12. Improved GPT Generation for Dimensity and Qualcomm UFS and eMMC (Thanks to Mr.UPROM)
13. Automatic Boot Slot Selection when using flash_all.bat mi Factory Firmwares
14. Added Adjustable EMMC VCC On delay via Settings.ini EmmcVccInitDelay=2000 Entry
* This value is in milliseconds
* Adjustable from 40 upto 8000 milliseconds
⚡️Flash64⚡️ New Update! V1.05.19.2025!
1. Fixed a MAJOR erase bug on small eMMC partitions (Thanks to hello-firmware.com).
2. Added MTK Direct Preloader Header Generation for manually loaded files (Thanks to hello-firmware.com).
3. Improved Android Security automatic backup file saving (Thanks to Giovanni Lucas Da Paz).
4. Improved rawprogram.xml universal backup file format (Thanks to Master Unlock GSM).
5. Moved BOOT A and BOOT B eMMC partitions to the top (Thanks to sohrab ezi).
6. Fixed BOOT A and BOOT B raw partition writing (Thanks to sohrab ezi).
7. Fixed Unisoc SPL loader flashing for Samsung factory files (Thanks to Nguyễn Diện and Giovanni Lucas Da Paz).
8. Added "Backup Security" button** in the Partitions tab.
9. Moved "Erase Before Write" option in the Partitions tab.
10. Added "Fake" Health Repair firmwares for SK Hynix hB8aP>, hC8aP>, hC9aP3, and hDEaP3
* These FFU firmwares do not repair health, but only make the eMMC report that its health is "Perfect."
* These FFU firmwares have "\_HR" at the end of the filename, e.g., 30_HYNIX_hB8aP__0060_PATCHED_FINAL_HR.fw.
11. Samsung eMMC FFU Filename now includes the IC Marking (Thanks to sohrab ezi).
12. Added New Samsung FFU:
QE13MB : KMQE10013M-B318 (by 0x9k)
QX63AB : KMQX60013A-B419 (by 0x9k)
MCG8GC : KLMCG8GEAC-B001
DH6DMB : KMDH6001DM-B422
RX14MB : KMRX10014M-B614
QX13MB : KMQX10013M-B419
RX1BMB : KMRX1000BM-B614
RX64MB : KMRX60014M-B614
13. Improved MTK Preloader IC Check for supported UFS / EMMC check
14. Added MBR/GPT repartition support for Phones that does not use BackupGPT (Kirin based) (Thanks to Mr.UPROM).
15. Fixed UFS Provisioning of LU Dedicated WriteBooster (Thanks to Giovanni Lucas Da Paz).
Flash64 боксни бугун сотиб олиш - шу ерда
⚡️Flash64⚡️Xiaomi XRING O1 New Update! V1.06.02.2025!
1. Added Support for Xioami Xring O1 Devices (Xiaomi 15S Pro, Xioami Pad 7 Ulta, etc)
* UFS Provisioning supported via gpt.img (Xioami GPT File)
* Full Firmware Flashing supported via flash.bat / flash.sh
* Full Firmware Flashing supported via fdt_sec.xml (Xioami XML File)
2. Added Support for SPD/Unisoc FileList.ini Flashing using Official Firmware
3. Added Motorola UTAG partition parsing (Thanks to Mr.UPROM)
4. Added SKU to Phone Model matching for Samsung, Vivo, Realme, Oppo, Nubia and Xiaomi_models
5. Added skip Userdata option for RAW Partition Reading (Thanks to Mr.UPROM)
6. Added quick access to eMMC Boot Configuration in Partition Tab (Thanks to yu luosheng)
7. Fixed Exynos impoper parsing of partitions inside SUPER (Thanks to Giovanni Lucas Da Paz)
8. Improved "AI Connect" for eMMC ISP Flashing Sparsed Files (Thanks to hello-firmware.com)
9. Improved eMMC Erase Function
10. Improved COMBO_BOOT detection on MTK Preloaders (Thanks to hello-firmware.com)
11. Added New Samsung FFU:
GP6BAB : KMGP6001BA-B514 (by 0x9k)
CUTB42 : KLMCG2UCTB-B041 (by hello-firmware.com)
GX6BMB : KMGX6001BM-B514
RD64MB : KMRD60014M-B512
RH64AB : KMRH60014A-B614
RE1BMB : KMRE1000BM-B512
RC1BMB : KMRC1000BM-B809
FE12MB : KMFE10012M-B214
BWBD3R : KLMBG4WEBD-B031
⚡️Flash64⚡️ New Update! V1.06.16.2025!
1. Added Support for adding Custom Watermark to Software GUI
2. Added Option to use Calibration Trim for a more accurate VCCQ setting
3. Added Support for Samsung sec_efs information parsing (IMEI*, SN* etc) *if available
4. Added Support for Unisoc UFS Devices Flashing using Official Firmware
5. Added Support for Motorola Unisoc UFS/eMMC Flashing via .bat files Official Firmware (Thanks to Giovanni Lucas Da Paz)
6. Improved eMMC Android Sparse Flashing (Thanks to KUMAR ALOK)
7. Improved UFS Android Sparse Flashing
8. Fix MBR Repair button for eMMC (Thanks to KUMAR ALOK)
9. Fix GPT Generate button for eMMC (Thanks to KUMAR ALOK)
10. Added SKU to Phone Model matching for Infinix
11. Added support for reading Android Information on Exynos 1580 phones (Thanks to Efrén Hernández)
12. eMMC and UFS Health report will now be shown in Bright RED if 80% or above (Thanks to KUMAR ALOK)
13. Fixed eMMC RAW Write for BOOT A and BOOT B (Thanks to hello-firmware.com)
14. Added Samsung FFU Erase Option
15. Added New Samsung eMMC FFU:
3P6CMB : KM3P6001CM-B517 (by Rathna Mobiles Tamilnadu)
MAG2GC : KLMAG2GEAC-B001 (by FarshiD)
Q313MB : KMQ310013M-B419 (by FarshiD)
4X6KMB : KM4X6001KM-B321 v0.9 (by hello-firmware.com)
16. Added New Micron eMMC FFU:
MICRON_G1C155
MICRON_G1C156
MICRON_G1J38E
MICRON_G1J39E
MICRON_G1J9P8
MICRON_G1J9Q9
MICRON_G1J9R8
MICRON_G1J9S9
MICRON_G2C213
MICRON_G2C214
MICRON_G2C215
MICRON_G2C218
MICRON_G2C219
MICRON_G2M211
MICRON_G2M212
MICRON_S0J97Y
MICRON_S0J9D8
MICRON_S0J9K9
MICRON_S0J9N8
⚡️Flash64⚡️Server Update! V1.07.04.2025!
1. Updated Server Authentication
Important Notice: Software Compatibility Update
Older versions of the F64 Software will no longer be
able to connect to the server.
If you are registering a new box, please download and
use the latest software version available from our official
website: www.flash64.com.
Older software versions will continue to work with new boxes
as long as the box firmware version is supported.
To continue using an older version of the F64 Software,
you can copy the Activation folder from the newer version's
directory and paste it into the older version’s folder.
2. Format Partition as EXT4 added for both eMMC and UFS
3. Format Partition as F2FS added for both eMMC and UFS
4. Initial Amlogic eMMC Partition Support for Android TV (Thanks to Diện Nguyễn & Romeo Tabios)
* Full Read Android Information Reading for non Encrypted Devices
* eMMC Resize via MBR button
5. Initial MStar eMMC Partition Support for Android TV (Thanks to Diện Nguyễn & Romeo Tabios)
6. Initial LG Web OS eMMC Partition Support for Android TV (Thanks to Diện Nguyễn)
* Full Partition Info Reading
7. Fix GUI hang during Micron eMMC FFU
8. Fixed IMEI Detection on Samsung Exynos
Flash64 full updtaes histiory - шу ерда (https://mobilforum.uz/threads/flash64-updates.4669/)
⚡️Flash64⚡️Android TV Supported!! V1.07.04.2025!
07.04.2025 - Server Update
⚡️Flash64⚡️GPT Master Tools Update! V1.07.29.2025!
07.29.2025 - GPT Master Tools Update!!
1. Improved FRP Handling for phones that transitioned from Android 14 to Android 15 (Thanks to Giovanni Lucas Da Paz)
2. Added Automatic FRP Disable in Settings -> Advanced Tasks Tab (Requested by Lemor PH)
3. Now shows FRP Status (Active / Not Active) if FRP is used by the phone (Requested by KUMAR ALOK VISHWAKARMA)
4. Added support for RAW Binary Image file dumps from other Tools. (Requested by Mr.UPROM)
* As of now, only GUID Partition Table is supported. More partition formats will be added soon.
* PrimaryGPT can be selected or unselected
* All Partitions inside the RAW Binary Image dump can be selected or unselected
5. Added Android Slot A/B Change for Qualcomm SoC-based Phones (Requested by hello-firmware.com)
6. Added GPT Master Tools (GUID Partition Table) (Requested by 元亿科技)
These features are accessible by right-clicking any partition in Partitiion Table List
* Resize any existing Partition (Change First LBA or Last LBA)
* Rename Partition
* Change GUIDs
* Change Flags (Priority, Tries Left, Successful, Read Only etc...)
* Manual GUID Input and Random GUID Generation Supported
* Delete Partitions
* Create New Partitions using Free Space markers (free_space_X)
7. Added Android File Tools (Requested by hello-firmware.com)
* Convert Binary Dump into Android Sparse File img (img2simg)
* Convert Single Sparse File into Binary Dump (simg2img)
* Convert Multiple Sparsed Files into 1 Binary Dump
example: super.img_sparsechunk.0
super.img_sparsechunk.1
super.img_sparsechunk.21
* Optional Data Trim for trailing blank space
8. Added Automatic Box Firmware Download from server via "Write Box Firmware" or Box Firmware Update
* DFU and Normal Mode supported
* Just make sure DFU Mode is not using Android Device drivers.
Uninstall + Delete Android Device Drivers if necessary
9. Now you can use a Custom CompanyLogo.bmp for the User Interface
* Bitmap Files with 500 x 500 pixels are supported
* Replace the file 'Image\CompanyLogo.bmp' with your Personal Logo
10. Fixed Android Sparse File Bug on Moto Firmware (Thanks to Master Unlock GSM).
11. Added Boot Partition display in Logs for UFS (Thanks to KUMAR ALOK VISHWAKARMA)
12. Fixed preloader Boot Relay Table for Vivo Y02T and Y21 (Thanks to hello-firmware.com)
13. Added "Do not Write to Disk" option in Software Settings
* This can be used to read the entire IC memory without saving it to your PC Storage
* This is useful if you want to perform a complete IC Read Memory Test
14. Added Android Slot Write Option after Firmware Flashing
15. Initial HiSilicon eMMC Partition Support for Android TV (Romeo Tabios)
* Full Read Android Information Reading for non-encrypted Devices
16. Initial U-BOOT eMMC Partition Support for Android TV (Thanks to Nghĩa Trần Đình)
* Partition Information Only
* Android/Linux Information not yet available
17. Added New Samsung eMMC FFU:
FNX2MB : KMFNX00012M-B214
8GTF4R : KLM8G1GETF-B041 (by Diện Nguyễn)
RH64AB : KMRH60014A-B614 (by Ahmed El-Zawawy)
3V6CBB : KM3V6001CB-B708 (by Ahmed El-Zawawy)
18. Added new Software GUI Language Packs (Machine Translated):
*** Warning : These are machine translated by Gemini 2.5 Pro and may contain errors in translation ***
Arabic, Bengali, French, German, Hindi, Indonesian, Portuguese,
Russian, Malay, Turkish, Ukrainian, Urdu, Vietnamese
⚡️Flash64⚡️ DUAL FRP, Box Firmware Update! V1.08.27.2025!
📅 𝟎8.27.𝟐𝟎𝟐𝟓 𝐔𝐩𝐝𝐚𝐭𝐞 𝐃𝐞𝐭𝐚𝐢𝐥𝐬
🚀 Software Update Released: August 27, 2025
We're excited to roll out a major update packed with powerful new features,
critical fixes, and significant improvements based on community feedback.
Thank you for your continued support!
F64 Box Firmware & Updates
Improved F64 Box Firmware Update Process:
Now supports default Windows Drivers and Android Device Google ADB Drivers.
Features a simple 1-Click Operation when the F64 Box is in Normal Mode or DFU Mode.
New F64 Box Firmware (MCU: 08.15.2025):
Added support for a custom start-up logo.
Fixed a critical crash issue related to the UART scan.
New RPMB & UFS Features
Dedicated RPMB Tab: A new, dedicated tab has been added for both eMMC and UFS operations to streamline your workflow.
Universal RPMB Data Erase for UFS:
*** WARNING: This operation also erases all LUN data. Proceed with caution. ***
Supports all UFS versions for Samsung brand ICs.
Supports UFS 3.1, 4.0, and 4.1 for other brands when OTP Configuration is not locked.
SAM RPMB KG Analyzer/Modifier:
*** You must AGREE to the F64 EULA before using this feature ***
Added for both eMMC and UFS.
Note: This feature is for educational purposes only. An RPMB Key is still required to change the KG status.
Automatic Reconnection Loop: Added a new automatic reconnection feature on the UFS tab to improve stability during operations.
General Features & Fixes
File Loading for RAW Binary Dumps: You can now load files for raw binary dumps, supporting both single RAW images and individual GPT partitions. (Thanks, Mr.UPROM!)
DDR (RAM Tuning) Erase Button: A new button has been added to erase DDR tuning data, which is useful when changing a device's memory IC. (Thanks, Mr.UPROM!)
Custom Address Sizing: Added size selection when using custom addressing for RAW reads on both eMMC and UFS.
Dual FRP Unlock: Added support for unlocking Dual FRP on Samsung devices. (Thanks, Giovanni Lucas Da Paz!)
Fixed: Corrected an issue with the Dimensity BROM layout header. (A special thank you to Mr. UPROM!)
Default Setting Change: The "Switch to SLOT A after flashing" option is now UN-CHECKED by default to prevent accidental changes. (Thanks, Mr.UPROM!)
F64 Box Activation File will now be saved in System Registry as well. (Suggested by Mr 1R0niC);
F64 Box Calibration File will now be saved in System Registry as well. (Suggested by Mr 1R0niC);
New Samsung eMMC FFU Added:
3P6CMB : KM3P6001CM-B517 (Contributed by 0x9k)
New Languages Added:
Marathi, Punjabi, Telugu, Swahili, Hausa, Italian, Polish, Romanian, Japanese and Korean
A huge thank you to our community for the valuable feedback and contributions that
made this release possible. Your insights help us improve the software for everyone.
Flash64 full updtaes histiory 👉 шу ерда
Flash64 боксни бугун сотиб олиш - here
⚡️Flash64⚡️ UFS RPMB, Writebooster, Box Firmware Update! V1.10.22.2025!
*** Box Firmware Update is Recommended before using this updated software ***
1. Enabled Scripting support for Custom Made Solutions
* Big Thanks to the contributors Lemor, MK MOBILE MASTER, Diện Nguyễn and pham ka di.
* Trainer Scripts updated in the "Scripts" folder
* User made (3rd Party) scripts can be downloaded through unofficial links
* You can Lock and Encrypt a specific Script to work only to a specific F64 Box Serial Number
* Use 3rd Party Scripts at your own risk
2. Added Support for SkHynix UFS 2.2 and UFS 2.1 Erase RPMB Data
* Entire IC will be ERASED including data from ALL LUNs
3. Added Support for UFS 3.0 Erase RPMB Data when OTP is not Locked
4. Fixed Samsung UFS 2.2 RPMB Data Erase (Thanks to Diện Nguyễn)
5. Fixed Factory Provision for Micron UFS 2.2 (Thanks to MSC Solotov)
* This DOES NOT Erase RPMB Data
6. Added Support for WriteBooster Automatic Configuration during UFS Provisioning via XML, CSC, PIT and Scatter Files.
7. Added Support for WriteBooster Automatic Configuration during UFS Provisioning via Mi gpt.img for XRING O1.
8. Added Support for NEW Exynos Boot Control switch between Slot A to Slot B
9. Added NEW Exynos Master Boot Record Support for eMMC and UFS
10. Added NEW Mediatek Master Boot Record Support for eMMC and UFS
11. Added GPT Support for BMW Automotive. (Thanks, Mr.UPROM!)
12. Improved Vivo MTK and UniSoc Flashing (Y16, Y21, Y04 etc) (Thanks to hello-firmware.com)
13. Improved Itel, Infinix and Tecno MTK and Unisoc Flashing (Thanks to Giovanni Lucas Da Paz)
14. Enabled dual Slot A and B Flashing for Qualcomm rawprogram.xml files.
15. Improved Qualcomm Boot Slot change (A/B)
16. Fixed backup folder name for Samung UFS with a generic "FD10000" serial number
* Current RPMB Counter will now be appended to the serial number
17. Added High Light to Secure Write Protected Regions in UFS LUNS (Thanks to Diện Nguyễn)
* Write Protection can sometimes be removed via ISP multiple Detection
18. Added Configuration Lock OTP Status to the main logs for convenience (Thanks to Diện Nguyễn)
19. Added an option in Settings to "Show Larger UFS Transfer Speed"
20. EMMC Specifications updated to align with JESD84-B51B (SEPTEMBER 2025)
21. Added New Samsung eMMC FFU:
4FEACC : KLM4G1FEAC-C031 (Contributed by 0x9k (Ciruit Knight X))
4FPD3R : KLM4G1FEPD-B031 (Contributed by 0x9k (Ciruit Knight X))
4FTE4R : KLM4G1FETE-B041 (Contributed by 0x9k (Ciruit Knight X))
8GME4R : KLM8G1GEME-B041 (Contributed by 0x9k (Ciruit Knight X))
8WMB3R : KLM8G1WEMB-B031 (Contributed by 0x9k (Ciruit Knight X))
AJNB4R : KLMAG1JENB-B041 (Contributed by 0x9k (Ciruit Knight X))
CJNB4R : KLMCG1JENB-B041 v0.6 and v0.7 (Contributed by 0x9k (Ciruit Knight X))
CJTD4R : KLMCG4JETD-B041 v0.4 (Contributed by 0x9k (Ciruit Knight X))
QN16BB : KMQN10006B-B318 (Contributed by 0x9k (Ciruit Knight X))
[Improvements of using SoC Firmware 10.20.2025 + ASIC Firmware 10.21.2025]
22. Targetted IC Detection
* If the Software is currently in the UFS Tab, the F64 Box will only try to detect using UFS Protocol (Suggested by hello-firmware.com)
* If the Software is currently in the eMMC Tab, the F64 Box will only try to detect using eMMC Protocol (Suggested by hello-firmware.com)
* If the Software is NOT in the UFS or eMMC Tab, the F64 Box will try to detect using both UFS and eMMC Protocol
23. Support for TX_N resistance selection via software control is now available for compatible FPC and ISP Adapters
24. Enabled Recovery Mode in F64 Box by pressing the Right button then connecting the USB Cable.
* This will Perform a Factory Reset on the box and can fix common box settings issues such as Boot Loop or strange LCD Colors.
Flash64 full updtaes histiory 👉 шу ерда (https://mobilforum.uz/threads/flash64-updates.4669/)
