Griffin-Unlocker Released V2025.10.27 Released
️ Changelog:
Update Direct Samsung Change Security Data
No Need ROOT Just ADB OR MTP Mode
Direct Change/Repair Serial Number For KG Operations
Direct Change CSC And PreConfig CSC
All Android Versions (Android 5 to Android 14+)
All Security Patches up to July 2025
All Processors (Exynos, Snapdragon, MediaTek, Unisoc, etc.)
Update Remove Samsung KG LOCKED on ALL devices with:
Just 1 OneClick
Only Using USB in MTP Mode
No Need Patch in EDL or JTAG (Work Perfect With LOCKED)
No Files, No Downgrade Firmware
Safe, Fast, and Fully Automated
️ Supports:
Auto Disables: System Update & Factory Reset
Change Device from KG LOCKED To Active in seconds
100% Clean Unlock — No Knox, No MDM triggered
️ Add New Samsung Loaders Security Patchs Level to Supported :-
- All Operations Direct Using EDL ( Qualcomm )
- Read Informations / Remove Samsung FRP Lock
- Flash/Read Firmware and Partition
- Read/Write/Erase GPT Partitions
- Read/Write/Backup/Erase EFS Partitions
- Factory Reset For All Models Even Have MDM/IT Admin/Locks
- Bypass KG [ Reset KG Samsung ] / Remove Lost Mode SAMSUNG
- Factory Reset Samsung [Safe Mode] / Unbrick Samsung [EDL DEBUG]
- Samsung KG To Broken [ Remove KG ] / Reset Knox
- SAMSUNG REMOVE KG [SMART METHOD] [FAST METHOD] [STEPS METHOD]
- Direct Repair/Change/Patch Device Model Name [By USB][EDL]
- Direct Repair/Change/Patch Customer Code[CSC][By USB][EDL]
- Direct Repair/Change/Patch Serial Number [By USB][EDL]
- Direct Repair/Change/Patch Unique Number [By USB][EDL]
- Direct Change/Patch Device ID (IMEI)
Change/Patch Device IMEI Using For Security Data Not Repair IMEI
====> For Following Models :
Galaxy A05s [SM-A057G] (BIT_8)
Galaxy A23 [SM-A235M] (BIT_C)
Galaxy S21 FE 5G [SM-G990B] (BIT_G)
Galaxy S21 FE [SM-G990U1] (BIT_J)
Galaxy S21 FE [SM-G990U] (BIT_J)
Galaxy Tab S6 Lite [SM-P613] (BIT_8)
Galaxy S22 Plus 5G [SM-S9060] (BIT_9)
Galaxy Tab S7 FE 5G [SM-T736B] (BIT_9)
Galaxy Tab S8 Ultra 5G [SM-X906B] (BIT_9)
Galaxy M55 5G [SM-M558B] (BIT_2)
...And many other Models!
Griffin 3, 6 or 12 months activation сотиб олиш
www.gsmservice.uz
#griffinunlockerupdate , #noneeddongle
Griffin Unlocker update history-
here
