KG Killer v3.0 - Official Release Changelog
The biggest update in the history of KG Killer!
️ Completely rewritten engine and massive Qualcomm expansion.
What's New in v3.0
️ Lag-Free UI: Entire engine rewritten with background threading. The tool never freezes, ever.
Built-in Auto-Updater: Seamless OTA update system with download progress bar.
Brand New Dark UI: Premium dark theme with cyan accents, smooth animations, and modern design.
Samsung Operations
Knox Guard (KG) Bypass
KG Remove — Android 15
KG Remove — Android 14
KG Remove — Android 13 (ALL Patch Method)
KG DNS Bypass Method
### 🛡 MDM / IT Admin Removal
IT Admin / DPC Removal (Method 1)
IT Admin / DPC Removal (Method 2)
IT Admin Operation (Advanced)
PayJoy Lock Removal
MDM Lock Removal
FRP Bypass
FRP Bypass via ADB (Method 1)
FRP Bypass via ADB (Method 2)
FRP Erase via Fastboot (New Method)
### 🗑 Account & Lock Removal
Samsung Account Removal
Screen Lock Removal
SIM / Carrier Setup Wizard Removal
Samsung Knox Removal
Demo Mode Removal
Samsung Utilities
Read Device Info (ADB)
Read Device Info (MTP)
Read Device Info (Fastboot)
CSC Region Change
Enable Diagnostic (Diag) Mode
Disable Samsung OTA Updates
Disable Samsung Services
Disable Factory Reset Protection
Factory Reset via ADB
Run Odin (Built-in Launcher)
Hide Developer Options
Xiaomi / Redmi / POCO Operations
Redmi IT Admin / Axio Lock Removal
HyperOS IT Admin Removal
MIUI IT Admin Removal
Mi Cloud Account Removal
Anti-Relock Protection
Enable Diag Mode (Xiaomi)
Disable OTA Updates
Reboot to EDL Mode
Vivo Operations
Vivo IT Admin Removal
Vivo Demo Mode Removal
Vivo Exception Erase
Vivo FRP Bypass
Oppo / Realme Operations
Disable Oppo OTA Updates
Oppo Carrier Switch
Motorola Operations
FRP Bypass via Fastboot
Bootloader Unlock/Relock
Tecno / Infinix Operations
Tecno IT Admin Removal
General / Universal Operations (All Brands)
Device Information
Read Full Device Info (ADB Mode)
Read Full Device Info (MTP Mode)
Read Full Device Info (Fastboot Mode)
Reboot Controls
Reboot to System
Reboot to Recovery
Reboot to Fastboot / Bootloader
Reboot to Download Mode
Reboot to EDL (Emergency Download)
App Management
List All Installed Apps (with Icons)
Uninstall Selected Apps
Disable Selected Apps
Install APK from PC
Pull / Backup APK from Device
Advanced Utilities
Erase Userdata via Fastboot
Set Active Slot (A/B Devices)
OTA Update Control (Enable / Disable)
Download USB Drivers (Built-in)
QR Code Scanner (Multiple Methods)
Qualcomm Snapdragon — EDL (9008) Mode Support
Brand new Qualcomm EDL engine with Sahara + Firehose protocol! Flash raw XMLs, read/write partitions, and bypass FRP/KG at the deepest hardware level.
Supported Chipsets
| Series | Chipsets |
Snapdragon 400 | 425, 430, 439, 450, 460, 480 |
Snapdragon 600 | 625, 632, 636, 660, 662, 665, 675, 678, 680, 695 |
Snapdragon 700 | 710, 712, 720G, 730G, 732G, 750G, 765G, 778G |
Snapdragon 800 | 835, 845, 855, 865, 870, 888, 8 Gen 1, 8 Gen 2 |
Supported Brands (EDL Firehose)
Xiaomi / Redmi / POCO — Full auth bypass, rawprogram0.xml flashing, persist erase (FRP)
Vivo — Flash raw partitions, userdata wipe, FRP unlock
Oppo / Realme — Sahara/Firehose protocol support
️ Samsung (Snapdragon) — Firmware flashing, KG partition modification
Motorola — Blank flash, fastboot-to-edl, FRP bypass
Qualcomm EDL Operations
Auto Detect Device in EDL (9008) Mode
Custom Programmer / Firehose Loader Selection
Loader Tester (Test Firehose Compatibility)
Flash Raw
Read / Backup Partitions
Write / Restore Partitions
Erase Partitions (FRP, Userdata, Persist)
Full Firmware Flash
What's New in v3.0
| Series | Chipsets |
