[Major Update]MH Unlocker V5.2 Update Release
Date 01/02/2025
Added Spd | Unisoc Initial Features
● Added "Sim |Network|Permanent Lock Remove In Diag Mode"
● Added "Enter Device Into Diag Mode"
● Added "Device Information In Diag Mode"
● 2-Methods Added
● Added "Factory Reset Device In Diag Mode"
Added Direct Sim|Network|Permanent Lock Remove In Diag Mode For Following Devices
● Hisense U965 HLTE116E
● Mobicel P11 Plus
● Mobicel Star
● Mobicel Vibe
● Stylo Swift 4G
Added Simlock | Network Unlock Code calculate By IMEI For Following Devices
● Hisemse Y81 Pro HLTE122E
● itel L5007O (Nola Fun)
● itel L507LVU (V53)
● Vortex ZG55
Improved & Changes On HUAWEI Read,Write,ID Remove Functions For KIRIN 710x Devices
●Added HUAWEI MGA-LX3 Fix Keypad Which Damaged By Remove Huawei ID...
● Huawei Read Data Backup Will Save Now to Doucoments/MHUnlockerPro/ Destinations...
● Read Backup Data Now Will Save Each Device Backup Saperately...
● Read Backup Data Will Save Data Into Brief Detaild Folder Name...
● Restore Data Will Now Pickup Cirrect Data Folder Auto Acording To Device Details...
● Restore Data Will Now Prompt User To Select Desired Folder For data Restore If Auto Data Not Found...
● Device Integrity Check system added On BootLop Repair Feature, Tool Will Aware You If You Select Wrong BootLop Repair File...
Added Tecno Welcome Screen Bypass | Frp Bypass [ADB Mode]
Revised PREVENT KG RELOCK Feature
● It prevent RELOCK KNOX Guard For Devices Which Is Already Kg Bypassed
Added Info By IMEI Tab
● Added Simlock Status Check Information For iPhone
● Added BlackList Status Check For iPhone
Fixed 'Reboot To Recovery' Feature Bug
iMORTANT Note : For using this solution you have to do initial work by Jtag for enable ADB Mode of device in E-RECOVERY Menu....
MH Unlocker credit сотиб олиш www.gsmservice.uz
#mhunlockerupdate, #noneeddongle
MH Unlocker updates history - here
