NCK Box Premium v2/ NCK Pro Android MTK v0.8.6 Released - [22/09/2023]
Added Motorola - Read Simlock unlock codes from MTK Motorola
1. Select flash mode connection.
2. Select Read Simlock Info
- This solution must be universal and supported on many MTK phones.
Can be selected phone from list or simple selected by CPU method with SECURITY BYPASS & SOFTWARE
will Autodetect phone.
Added Remove FRP and format userdata for MTK Motorola phones in FASTBOOT mode.
- To use this solution not need to unlock bootloader.
Solution will temporary unlock bootloader and remove FRP or Format userdata.
This solution must work on many models and must be universal.
It s located in FRP tab.
GENERIC CPU Selection:
Added Simunlock/Read Simlock Info/Repair IMEI in flash mode for Generic CPU Selection
- This solution use default MTK Simlock Algorithm used by many brands what use MTK CPU.
If Algorithm is modified by vendor, this way will not work.
Known brands what use own Algorithm can be OPPO, Xiaomi, Samsung etc...
Updated save security backup and restore security backup function.
Buy NCK 1 year support here - www.gsmservice.center
#nckdongleupdate
