NCK Dongle / NCKPro Spreadtrum Module v2.1.9 update released - [09/03/2023]
Added:
Motorola
E6i
E7i Power
E20
E30
E32
Supported Functions:
Read info, Reset FRP, Factory reset(wipe), backup/restore phone security, read firmware, write saved firmware, write pac file.
Simlock and repair imei is not supported for now.
In case of other sprd Motorola phones, please make boot info and post log in forum.
- Added possibility to exclude save nv backup for flashing phones with erased or corrupted filesystem,
phones will not allow to read backup and exe will give reading backup error.
-- In this case need to uncheck this setting to perform flashing.
- Added remove simlock and imei repair on selecting custom loader.
-- Please note, not all loaders support this function, if exe will give error,
this mean custom loader is not supported.
- Added possibility to disable format userdata on writing saved firmware, if user will restore only few files, format userdata not need.
-- In case of full flash, need to perform format userdata.
- Improved read firmware function.
-- Now exe will read and save partition info and will allow to make repartition using saved firmware.
- Improved backup/restore phone security, now exe will backup/restore also prodnv, vendor_efs, sec_efs if this partitions exist.
- Improved flashing stability for phones what have super partition.
-- Now this partition must be flashed correctly and more fast.
#nckdongle
