New Chimera Fixes and Samsung Improvements
New Chimera Fixes
Fixed Factory Reset procedure (available from normal mode) for old Motorola devices
Fixed Motorola Qualcomm Bootrepair procedure
Fixed some user interface-related problems to prevent crashes
Fixed appearance of long texts
Fixed Notification panel
Improved usage of the Utility page
Samsung Qualcomm Improvements
New programmers have arrived for Samsung Qualcomm. The following models and BIT versions are supported:
Samsung Galaxy A02s (SM-A025AZ) BIT7
Samsung Galaxy A02s (SM-A025U1) BIT5
Samsung Galaxy A02s (SM-A025V) BIT6
Samsung Galaxy A52 5G (SM-A526B) BITA
Samsung Galaxy A72 (SM-A725M) BIT9
Samsung Galaxy Z Fold 4 5G (SM-F936U) BIT7
Samsung Galaxy S21 FE 5G (SM-G990B) BITA
On the devices above, the following procedures are now available: Factory Reset, Remove FRP, Get Info, Remove FMM, Remove MDM, Repair Boot, Root, Repair Serial, CSC Change, Remove Knoxguard (*), Reset Battery Status.
Samsung Exynos Improvements
The following new Samsung Exynos models are now supported in EUB mode:
Samsung Galaxy A16 5G (SM-A166B, SM-A166E, SM-A166M)
Samsung Galaxy Tab Active5 (SM-X306B, SM-X308U)
Available procedures in EUB mode: Backup, Bootloader Unlock, Change CSC, Change Serial, Factory Reset, FMM Remove, FRP Remove, Set KnoxGuard State, Patch KnoxGuard, Get Info, Lost Mode Remove, Common Criteria Remove, MDM Remove, Remove Warnings, Security Backup/Restore, Network Factory Reset, Reset Battery Status.
*: The solution works until the February 2024 security update
Арзон нархда Chimera Pro or Samsung activation сотиб олиш - www.gsmservice.uz
