OCGSM KEY Ⅱ_Software v1.0.13 released!
World's first perfect fingerprint retention payment, perfect solution
World's first Reset Huawei ID solution supporting Harmony OS 3.0,removed. Success need to be downgraded to below 2.0.0.230 for activation
Supports Kirin 710 Reset Huawei ID、Reset FRP、FAST Write Firmware 、Repair Chip is Damaged、Disable Updates
Supports Kirin 710H Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 810 Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 820 Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 970 Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 980 Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 985 Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 990 Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 990E Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
Supports Kirin 990_5G Reset Huawei ID、Reset FRP、FAST Write Firmware、Repair Chip is Damaged、Disable Updates
#ocgsmkey, #noneeddongle
  • Like
Reactions: zwm
