Octoplus FRP Tool v.2.7.0 Release Notes:
Important policy changes
Added Repair IMEI, Enable ADB for Tecno / Infinix phones based on MediaTek (in ROM and Preloader Mode) (some new security patch levels could be not supported):
Tecno
Camon 11 (CF7, CF7k)
Camon 11 Pro (CF8)
Camon 11S (CB7, CB7j)
Camon 12 (CC7, CC7s) - tested
Camon 12 Air (CC6, KC3)
Camon 12 Pro (CC9)
Camon 15 (CD7)
Camon 15 Air (CD6)
Camon 15 Premier (CD8j)
Camon 15 Pro (CD8)
Camon 16 (CE7, CE9h)
Camon 16 Air (CD6s)
Camon 16 Premier (CD6j, CE9)
Camon 16 Pro (CE8)
Camon 16 SE (CE7j)
Camon 17 (CG6, CG6j)
Camon 17 Pro (CG8, CG8h)
Camon 17P (CG7, CG7n) - tested
Camon 18 (CH6, CH6h, CH6n)
Camon 18 Premier (CH9, CH9n)
Camon 18P (CH7, CH7n)
Camon 19 (CI6, CI6n)
Camon 19 Neo (CH6i)
Camon 19 Pro (CI8, CI8n)
Camon 19 Pro 5G (CI7n)
Camon 20 (CK6, CK6n, CK6ns)
Camon 20 Pro (CK8n)
Camon I 2 (ID5, ID5a)
Camon I 2X (ID5D)
Camon I Air 2 Plus (ID3K)
Camon I Click 2 (ID6)
Camon I Sky (IN2)
Camon X (CA7)
Camon X Pro (CA8)
Phantom 9 (AB7)
Phantom X (AC8)
Pop 1S (F4)
pop 1S Pro (F4 LTE)
Pop 2S (KB2, KB2h, RA8)
Pop 2S Pro (KB2j)
Pop 4 LTE (BC1s)
Pop 4 Pro (BC3)
Pop 5 LTE (BD4a, BD4i)
Pop 5 Pro (BD4h, BD4j)
Pop 6 (BE7)
Pop 6 Pro (BE8)
Pouvoir 2 Pro (LA7, LA7 Pro)
Pouvoir 3 (LB7)
Pouvoir 3 Air (LC6, LC6a)
Pouvoir 3 Plus (LB8)
Pouvoir 4 (LC7, LC7s)
Pouvoir 4 Pro (LC8)
Pova (LD7, LD7j)
Pova 2 (LE7, LE7n)
Pova 3 (LF7, LF7n)
Pova 5G (LE8)
Pova Neo (LE6)
Pova Neo 2 (LG6n)
Pova Neo 3 (LH6n)
Sky 2 (IN1 Pro)
Spark 3 (KB3)
Spark 3 (KB7j)
Spark 3 pro (KB8)
Spark 4 (KC2, KC2j, KC8)
Spark 4 Air (KC1, KC1j, KC6)
Spark 4 Lite (BB4k)
Spark 5 (KD7h, KD7s)
Spark 5 Air (KD6, KD6a)
Spark 5 Pro (KD7)
Spark 6 (KE7)
Spark 6 Air (KE6, KE6j)
Spark 6 Go (KE5, KE5j, KE5k, KE5s)
Spark 7 (KF6, KF6h, KF6i, KF6n)
Spark 7 (KF6j, KF6k)
Spark 7 Go (KF6m)
Spark 7 Pro (KF8)
Spark 7P (KF7j)
Spark 7T (KF6p)
Spark 8 (KG6, KG6k)
Spark 8 Pro (KG8)
Spark 8C (KG5j, KG5q)
Spark 8P (KG7, KG7h, KG7n)
Spark 8T (KG6p)
Spark 9 (KG5p)
Spark 9 Pro (KH7, KH7n, KH7s)
Spark 9T (KH6)
Spark 10 (KI5q, KI5qs)
Spark 10 Pro (KI7, KI7s)
Spark 20 (KJ5, KJ5n)
Spark 20C (BG7, BG7n)
Spark Go (KC1h)
Spark Go 2022 (KG5, KG5m)
Spark Go 2023 (BF7, BF7h, BF7n, BF7s)
Camon 11 Pro (CF8)
Camon 12 Pro (CC9)
Camon 15 (CD7)
Camon 15 Air (CD6)
Camon 15 Pro (CD8)
Camon 16 Air (CD6s)
Camon 16 Pro (CE8)
Camon 16 SE (CE7j)
Camon 19 Neo (CH6i)
Camon 20 Pro (CK8n)
Camon I 2X (ID5D)
Camon I Sky (IN2)
Camon X (CA7)
Camon X Pro (CA8)
Phantom 9 (AB7)
Phantom X (AC8)
Pop 1S (F4)
pop 1S Pro (F4 LTE)
Pop 2S Pro (KB2j)
Pop 4 LTE (BC1s)
Pop 4 Pro (BC3)
Pop 6 (BE7)
Pop 6 Pro (BE8)
Pouvoir 3 (LB7)
Pouvoir 4 Pro (LC8)
Pova (LD7, LD7j)
Pova 2 (LE7, LE7n)
Pova 3 (LF7, LF7n)
Pova 5G (LE8)
Pova Neo (LE6)
Pova Neo 2 (LG6n)
Pova Neo 3 (LH6n)
Sky 2 (IN1 Pro)
Spark 3 (KB3)
Spark 3 (KB7j)
Spark 3 pro (KB8)
Spark 4 Lite (BB4k)
Spark 5 Pro (KD7)
Spark 6 (KE7)
Spark 7 Go (KF6m)
Spark 7 Pro (KF8)
Spark 7P (KF7j)
Spark 7T (KF6p)
Spark 8 (KG6, KG6k)
Spark 8 Pro (KG8)
Spark 8T (KG6p)
Spark 9 (KG5p)
Spark 9T (KH6)
Spark Go (KC1h)
Infinix
Hot 7 Pro (X625B, X625D)
Hot 8 (X650B, X650C, X650D)
Hot 9 (X655, X655C, X655D)
Hot 9 Play (X680, X680B, X680C, X680F)
Hot 9 Pro (X655F)
Hot 10 (X682B, X682C)
Hot 10 Lite (X657B)
Hot 10 Play (X688B, X688C)
Hot 10i (X658E, X659B)
Hot 10s (X689B)
Hot 10s NFC (X689, X689D)
Hot 10T (X689C)
Hot 11 (X662, X662B, X689F)
Hot 11s (X6812)
Hot 12 (X6817, X6819)
Hot 12 Play (X6816)
Hot 12i (X665, X665B, X665E)
Hot 20 (X6826B, X6826C)
Hot 20 5G (X666, X666B)
Hot 20 Play (X6825)
Hot 20i (X665C)
Hot 20S (X6827)
Hot 30 (X6831)
Hot 30 5G (X6832)
Hot 30 Play (X6835)
Hot 30 Play NFC (X6835B)
Hot 30i (X669C)
Note 5 (X604, X604B)
Note 5 Stylus (X605)
Note 6 (X610B)
Note 7 (X690, X690B, X690C)
Note 7 Lite (X656)
Note 8 (X692)
Note 8i (X683, X683B)
Note 10 (X693)
Note 10 Pro (X695, X695C, X695D)
Note 11 NFC (X663B)
Note 11 Pro (X697)
Note 11s (X698)
Note 12 (X663, X663C)
Note 12 (X663D)
Note 12 5G (X671)
Note 12 G96 (X670)
Note 12 Pro 5G (X671B)
Note 12i (X677)
Note 30i (X6716, X6716B)
S4 (X626)
S4 Pro(X626B)
S5 (X652, X652A)
S5 Lite (X652B, X652C)
S5 Pro (X660, X660B, X660C)
Smart 2 (X5515, X5515F, X5515I)
Smart 2 Pro (X5514, X5514D)
Smart 3 (X5516, X5516B, X5516C)
Smart 3 Plus (X627)
Smart 4 (X653, X653C)
Smart 4 PLus (X680D)
Smart 5 (X657C)
Smart 6 (X6511E)
Smart 6 HD (X6512)
Smart 6 Plus (X6511G, X6823C)
Smart 7 (X6515)
Smart 8 (X6525B)
Smart 8 Plus (X6526)
Smart HD (X612B)
Zero 4 Plus (X602)
Zero 5 (X603)
Zero 5 Pro (X603B)
Zero 5G (X6815, X6815B)
Zero 8 (X687)
Zero 8i (X687B)
Zero Ultra (X6820)
Zero X Neo (X6810)
Zero X Pro (X6811)
Hot 9 Pro (X655F)
Hot 10 Lite (X657B)
Hot 10s (X689B)
Hot 10T (X689C)
Hot 11s (X6812)
Hot 12 Play (X6816)
Hot 20 Play (X6825)
Hot 20i (X665C)
Hot 20S (X6827)
Hot 30 (X6831)
Hot 30 5G (X6832)
Hot 30 Play (X6835)
Hot 30i (X669C)
Note 6 (X610B)
Note 7 Lite (X656)
Note 8 (X692)
Note 10 (X693)
Note 11 NFC (X663B)
Note 11 Pro (X697)
Note 11s (X698)
Note 12 (X663D)
Note 12 5G (X671)
Note 12 G96 (X670)
Note 12i (X677)
S4 (X626)
S4 Pro(X626B)
S5 (X652, X652A)
Smart 3 Plus (X627)
Smart 5 (X657C)
Smart 6 (X6511E)
Smart 6 HD (X6512)
Smart 7 (X6515)
Smart 8 (X6525B)
Smart HD (X612B)
Zero 4 Plus (X602)
Zero 5 (X603)
Zero 5 Pro (X603B)
Zero 8 (X687)
Zero 8i (X687B)
Zero Ultra (X6820)
Zero X Neo (X6810)
Zero X Pro (X6811)
Added Repair IMEI, Enable ADB in general methods for Tecno / Infinix / Itel - you need to select corresponding brand, then _Mtk Preloader / _Mtk Preloader V2.
Added Reset FRP for Itel phones based on Mediatek CPU with 2024 security patch, you need to select _MTK Preloader 2024 sec.
Added Enable ADB for Tecno / Infinix phones based on Mediatek Helio G99 CPU:
Infinix Note 12 (X676C)
Infinix Note 12 Pro (X676B)
Infinix Note 30 Pro NFC (X678B)
Infinix Note 40S (X6850B)
Infinix Zero 20 (X6821)
Infinix Zero 30 (X6731B)
Tecno Camon 20 Pro (CK7n)
Tecno Pova 4 (LG7n)
Tecno Pova 4 Pro (LG8n)
Tecno Pova 5 (LH7n)
Added Reset FRP / Enable ADB for the following phones based on Mediatek Helio G99 CPU:
Infinix Hot 40 Pro (X6837)
Infinix Hot 50 (X6882)
Infinix Note 30 NFC (X6833B)
Infinix Note 40 Pro (X6850)
Infinix XPad 11.0 (X1101)
Tecno Camon 30 (CL6k)
Tecno Camon 30 (CL6s)
Tecno Camon 30s Pro (CLA6)
Tecno Spark 20 Pro (KJ6)
Tecno Spark 20 Pro Plus (KJ7)
Added Reset FRP for the following Lenovo / Oppo / Realme / Xiaomi devices:
Oppo A3 (CPH2669)
Oppo A3 5G (CPH2639)
Oppo A3 Pro 5G (CPH2665) (thanks to Mr. kothamamun)
Oppo A38 (CPH2579)
Oppo A3x 5G (PKD130d)
Oppo A79 5G (CPH2557)
Oppo A80 5G (CPH2639)
Oppo Reno 12F 5G (CPH2637)
Realme 11 (RMX3780)
Realme 11 Pro Plus (RMX3741)
Realme 11x (RMX3785)
Realme 12 5G (RMX3999)
Realme 13 5G (RMX3951)
Realme Note 50 (RMX3834)
Realme V50 (RMX3783)
Lenovo Tab (TB-311FU)
Lenovo Tab (TB-311XU)
Lenovo Tab P11 (2nd gen) (TB-350XU)
Lenovo Tab P11 (2nd gen) (TB-350FU)
Lenovo Tab Plus (TB-351FU)
Lenovo Tab K10 (TB-X6C6F)
Lenovo Tab P11 (TB-J616X)
Xiaomi Poco C75
Xiaomi Redmi 14C
Xiaomi Redmi A3 Pro
Oppo A38 (CPH2579)
Realme 11 (RMX3780)
Xiaomi Poco C75
Xiaomi Redmi 14C
Xiaomi Redmi A3 Pro
Added Reset FRP for the following devices based on Mediatek V6 CPU:
Blackview A200 Pro
Blackview BV8100
Blackview BV9300
Blackview BV9300 Pro
Blackview N6000
Blackview Tab 18
Casper Via X40
Coolpad Cool 30 Play (CP36t)
Cubot King Kong 9
Cubot King Kong AX
Cubot Max 5
Cubot X70
Doogee S100
Doogee S100 Pro
Doogee S110
Doogee T30 Ultra
FOSSiBOT F102
LT M50 (9701)
LT S33
Oscal Tiger 12
Oukitel WP21
Oukitel WP21 Ultra
Oukitel WP27
Qilive QT23126BP
Teclast T50 Pro
Teclast TLG01
Ulefone Armor 17 Pro
Ulefone Armor 21
Ulefone Power Armor 19
Ulefone Power Armor 19T
Unihertz Tank 01
Unihertz Tank 2
Unihertz Tank 3
Zuum Sens G
Blackview BV8100
Blackview BV9300
Blackview N6000
Blackview Tab 18
Casper Via X40
Cubot King Kong 9
Cubot King Kong AX
Cubot Max 5
Cubot X70
Doogee S100
Doogee S100 Pro
Doogee S110
Doogee T30 Ultra
FOSSiBOT F102
LT M50 (9701)
LT S33
Oscal Tiger 12
Oukitel WP21
Oukitel WP21 Ultra
Oukitel WP27
Qilive QT23126BP
Teclast T50 Pro
Teclast TLG01
Ulefone Armor 21
Unihertz Tank 01
Unihertz Tank 2
Unihertz Tank 3
Zuum Sens G
Added Reset FRP for the following Samsung devices based on Qualcomm CPU via EDL Mode:
Galaxy A01 (SM-A015G) (Bit 6)
Galaxy A01 (SM-A015U) (Bit 9)
Galaxy A01 (SM-A015U1) (Bit 7)
Galaxy A02s 2021 (SM-A025A) (Bit 8)
Galaxy A02s 2021 (SM-A025F) (Bit 7)
Galaxy A05s (SM-A057G) (Bit 5)
Galaxy A05s (SM-A057M) (Bit 7)
Galaxy A11 2020 (SM-A115F) (Bit 6)
Galaxy A23 (SM-A235F) (Bit 9)
Galaxy A23 (SM-A235M) (Bit 9)
Galaxy A23 (SM-A235N) (Bit 8)
Galaxy A23 5G (SM-A236B) (Bit 9)
Galaxy A23 5G (SM-A236E) (Bit 9)
Galaxy A42 5G (SM-A426B) (Bit 8)
Galaxy A42 5G (SM-A426N) (Bit 7)
Galaxy A52 5G (SM-A5260) (Bit 8)
Galaxy A52 5G (SM-A526U) (Bit G)
Galaxy A52s 5G (SM-A528B) (Bit A)
Galaxy A52s 5G (SM-A528N) (Bit 6)
Galaxy A73 5G (SM-A736B) (Bit A)
Galaxy A80 (SM-A805F) (Bit 7)
Galaxy A90 5G (SM-A908B) (Bit 9)
Galaxy F23 5G (SM-E236B) (Bit 8)
Galaxy M14 4G (SM-M145F) (Bit 6)
Galaxy M23 5G (SM-M236L) (Bit 9)
Galaxy M42 5G (SM-M426B) (Bit 9)
Galaxy M52 5G (SM-M526B) (Bit 5)
Galaxy M52 5G (SM-M526BR) (Bit 5)
Galaxy Note 20 5G (SM-N981N) (Bit 6)
Galaxy Note 20 Ultra 5G (SM-N986N) (Bit 6)
Galaxy Note 20 Ultra 5G (SM-N986U) (Bit A)
Galaxy S20 (SM-G981N) (Bit 6)
Galaxy S20 (SM-G981U) (Bit 8)
Galaxy S20 FE 5G (SM-G781B) (Bit E)
Galaxy S20 FE 5G (SM-G781N) (Bit 9)
Galaxy S20 FE 5G (SM-G781U) (Bit I)
Galaxy S20 Plus 5G (SM-G986N) (Bit 6)
Galaxy S21 5G (SM-G990U3) (Bit A)
Galaxy S21 5G (SM-G991U) (Bit E)
Galaxy S21 FE (SM-G990B) (Bit 8)
Galaxy S21 FE (SM-G990B2) (Bit A)
Galaxy S21 Ultra 5G (SM-G998U) (Bit E)
Galaxy S22 Plus 5G (SM-S906U) (Bit 7)
Galaxy S22 Ultra 5G (SM-S908E) (Bit 8)
Galaxy S22 Ultra 5G (SM-S908N) (Bit 6)
Galaxy S23 5G (SM-S911N) (Bit 4)
Galaxy S23 Plus 5G (SM-S916B) (Bit 7)
Galaxy S23 Ultra 5G (SC-G20) (Bit 1)
Galaxy S23 Ultra 5G (SM-S918B) (Bit 7)
Galaxy S23 Ultra 5G (SM-S918N) (Bit 5)
Galaxy S24 Ultra (SM-S928N) (Bit 4)
Galaxy Tab A 8.0 (SM-T295) (Bit 6)
Galaxy Tab A 8.0 (SM-T297) (Bit 6)
Galaxy Tab A9 Plus (SM-X216B) (Bit 5)
Galaxy Tab S6 Lite 10.4 Wi-Fi (SM-P613F) (Bit 7)
Galaxy Tab S7 FE Wi-Fi (SM-T733) (Bit 8)
Galaxy Tab S8 Ultra (SM-X900) (Bit 9)
Galaxy Z Flip 4 (SM-F721N) (Bit 5)
Galaxy Z Fold 2 5G (SM-F916B) (Bit 7)
Galaxy Z Fold 3 5G (SM-F926N) (Bit 6)
Added Reset FRP for the following devices:
Acer One 8 (T4-82L)
Blackview BL8000
Bmobile BL62
Casper M35
Cloud Mobile Stratus C8
Coolpad CP03
CWOWDEFU P12W
Doogee S200
Doogee S95
Doogee V Max Plus
Doro 8042
Doro 8200
Energizer U652S
Eudora E10 Pro
Eudora E65 Pro
Everis E0115
FOSSiBOT DT1
FOXXD A55 (thanks to Mr. ThePhoneTechDoc)
FOXXD P8
General Mobile G314
Hisense E33 (HLTE243E)
Hisense H60 Zoom (HLTE323E)
Hisense U60 (HLTE108E)
Hot Pepper Puya (HPP-AP33)
IKU T8
Infinix Hot 50i (X6531B)
Itel S18 (S663L)
Kalley Black C Pro
Kruger & Matz Live 10S
KXD A11
LT C60
LT X9
Lush Mint LM5734G
Mintt Coolmintt A7
Nokia 7 Plus (TA-1046)
Novey Alpha A10
Nuu A15 (S6512L)
Nuu B10 (S6505L)
OnePlus 7 (GM1905)
Onn 100135794
Orange Doro 8042
Oscal S70 Pro
Oukitel K9 Pro
PEAQ Pet 101-H232E-13
PEAQ PET-10181-F464E
Phoneix OneTab
Ravoz V8
Samsung Galaxy A11 2020 (SM-A115A)
Samsung Galaxy A32 5G (SC-G08)
Sigma Mobile Tab A1025 X-treme
SIMI S8001
Sky D63
Sky Elite D65
Smartec Silex
TCL 1T 7" (9309X)
TCL 501 (T433D)
Teclast T30
Tecno Phantom V Flip 5G (AD11)
Trident A54
Ulefone Armor Pad Pro
Vivo Y93 (PD1818)
ZTE A5 2019-T
ZTE Libero 2 (602ZT)
Blackview BL8000
Bmobile BL62
Casper M35
Coolpad CP03
CWOWDEFU P12W
Doogee S200
Doogee S95
Doogee V Max Plus
Doro 8042
Doro 8200
Energizer U652S
Eudora E10 Pro
Eudora E65 Pro
Everis E0115
FOSSiBOT DT1
FOXXD P8
General Mobile G314
IKU T8
Itel S18 (S663L)
Kalley Black C Pro
KXD A11
LT C60
LT X9
Lush Mint LM5734G
Mintt Coolmintt A7
Novey Alpha A10
Nuu A15 (S6512L)
Nuu B10 (S6505L)
OnePlus 7 (GM1905)
Onn 100135794
Orange Doro 8042
Oscal S70 Pro
Oukitel K9 Pro
Phoneix OneTab
Ravoz V8
SIMI S8001
Sky D63
Sky Elite D65
Smartec Silex
TCL 1T 7" (9309X)
TCL 501 (T433D)
Teclast T30
Trident A54
Vivo Y93 (PD1818)
ZTE A5 2019-T
Improved connection for:
ZTE 8050
Oppo Reno6 5G (CPH2251)
Octoplus FRP Tool activation сотиб олиш - www.gsmservice.uz
#octoplusfrp, #noneeddongle
Octoplus FRP Tool full updates history - here
