Octoplus Samsung Software v.4.2.6 is out!
Added support for Samsung devices with new security (2023-05-01 and above) for Unlock MDM (Apr. 2023) operation!
Note:
For Unlock MDM to work on devices with high security (2023-05-01 and above), the software disables the built-in lockscreen.
If you set up a password, pattern or PIN, the phone will NOT ask for it (it will only ask 1 time after the restart).
Banking or applications that require a password or biometrics WILL work.
You can use any third-party application to emulate lockscreen.
Improved MDM unlock operation (Apr. 2023).
For devices with security below 2023-05-01, a new unlocking method will be used.
All disadvantages of the old method have been removed:
- After the operation device will be fully functional. Smart Switch, Samsung Dex works
- You CAN perform a factory reset. The phone will NOT be re-locked
- The message “This device belongs to your organization” has been removed
- Problem with not receiving calls and notifications while screen is off, has been removed
- You CAN flash the device via download mode. We can't guarantee that the device will not be re-locked after flashing to newer firmware. It's at your own risk.
Notes:
- For safety, we disable OTA updates on the device, but you can update device using a download mode.
- Some devices do not support new method, so for them you need to use the old method.
Added the option to select the unlock method for Unlock MDM (Apr.2023) operation.
Some other improvements were introduced.
Buy Octoplus Samsung activation here - www.Gsmservice.center
#octoplussamsungupdate
Note:
Notes:
